Question about HP Pavilion a1620n (882780664494) PC Desktop
PC fan running loud & constant - HP Pavilion a1620n (882780664494) PC Desktop
  • 2,692 Answers
Change fans. Fans do not have a long life.
Posted on Dec 15, 2008
Why are my cooling fans for radiator running constantly?
The cooling fans are supposed to run any time the a/c is on in order to keep air flowing across the condenser. Your a/c will not work properly at idle if they quit.
Jul 27, 2015 | 2010 Ford Escape
Asus x50sr fan on full constantly
That laptop have no to much space to get the air , and when the cpu get hotter , the cooler starts to go faster and than he make noise to much , watch the cooler , take off the dust , and take care of the cpu .
Oct 20, 2012 | Computers & Internet
Loud fan
Chances are you have dirt buildup, get a can of compressed air, attach straw and give the cooling fan a few good blasts, blow out open ports. If no change, the laptop must be dismantled down to the motherboard level to do a complete cleaning and the cooling fan may need to be changed, the old thermal paste will need to be removed and fresh applied. Go to Type: make and model of laptop, refine search to cooling fan.
May 10, 2012 | Toshiba Satellite L555D-S7910 Notebook
My HP Pavilion dv6 WW146AV runs hot!
In order to address this the unit must be taken apart, remove fan and clean with compressed air, next remove the heat sink, four spring loaded screws turn one "small amount" go diaganal do the same and the next two until removed from the processor ic, blow out any dirt, next remove old silicon grease with rubbing alcohol, apply fresh thermal grease to the ic and heat sink "small amount" and assemble.This will solve most issues.
Mar 05, 2012 | HEWLETT-PACKARD Computers & Internet
My computer runs constantly its loud and annoying
I assume you mean the cooling fan on the CPU, this model uses a smart fan technology, it is meant to spin up faster to provide cooling. If is is doing tis constantly, it means the CPU is not getting adequate cooling (overheating), to check this, remove the side panel, clean all the dust and debris build up from the cooling fan and see if that helps
Jan 22, 2011 | HP Pavilion a1000n (PS567AA) PC Desktop
Desktop computer fan runs constantly
Desktop fans do run constantly, you cannot avoid this.
The reason they get loud is because there will be a build up of dust on the fan blades.
To rectify this problem turn off the computer and remove the power cord from the rear. Then you need to remove the side panel from the base unit to expose the motherboard.
You will see that inside the case it is full of dust. Look at the CPU fan (the fan on the motherboard) also take notice of any case fans too, they are at the back.
To clean the fans and the case you can use a clean dry paintbrush or compressed air.
Once the inside of the case is cleaned you will see a noticeable drop in noise.
Jul 03, 2010 | HP Compaq Presario SR2150NX PC Desktop
Fan constantly running,have comp presario sr1420nx about 4 yrs
If blowing the dust did not help your only other options are replace the fan or replace the heat sink with a newer one that incorporates a quieter fan.
Jun 09, 2009 | HP Compaq Presario SR1420nx...
Fan runs constantly
one reason that a CPU fan may be running constantly is that it may not be able to cool the cpu down. usually this could be due to dust or debri clogging the incoming or outgoing vents or even dust accumulated on the fan itself or the heatsink.
Jun 03, 2009 | HP Pavilion a1110n (PX743AA) PC Desktop
Fan runs loud,constant on HP a1620n
cheek the cable of cable properly plug in
OFF YOUR pc and system cell put out for 10 mint put back in to the system and stat your system
cheek out fan for electric shot
repaly me if i solve your problem
Dec 13, 2008 | HP Pavilion a1620n (882780664494) PC...
My Emachine T5212 has a loud fan constantly running
sounds like a fan is going out .. with the case open can you identify which fan is making the noise?
Mar 10, 2008 | E-Machines eMachines Desktop PC
HP Pavilion  a1620n (882780664494) PC Desktop Logo
414 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
