Question about 321studios DVD X Copy Platinum (200000) for PC
Copy When I make a copy - it copies then tells me to put in a blank DVD - so I do and it doesnt read the DVD so it wont light up the start button. Am I supposed to use a DVD RW? I have a maxell dvd+r 4.76b singele side recordable. We got this years ago - and only used it once. I thought it went quick. What am i doing wrong?
    Problem Solver:
  • 5 Answers
Maybe your dvd's are dvd-r and it will only take dvd+r or your setting in 321 platnum is set for reading the wrong drive try that cheers steve
Posted on Mar 19, 2007
SOURCE:
Goes straight to burn and doesen't copy
Which Program? There is a difference between Burn and Copy.
Copy means you have a CD or DvD that already has something on it such as a music CD or a movie DvD and you want to copy it. The system normally reads the CD or DvD and copies the contents to disk then asks you to put in a blank CD or DvD to make the copy.
Burn means you have Data Files, Documents or Music that is already on the disk drive and you want to put it on a Cd or DvD. Normally you just put in a blank CD or DvD then either Drop and Drag, Browse or Copy and Paste the files you want on the CD or DvD.
Mar 30, 2012 | Computers & Internet
Tip
How Can I Copy DVD Files Easily on Mac?
Have you ever troubled with how to backup, clone or copy your favorite DVD to computer as a DVD folder, or an ISO image file, or even to another DVD disc directly? Furthermore, are you still griping about whether copying DVD entirely or just copying DVD with main movie?
more information:mac dvd copy
iSkysoft DVD Copy for Mac is extremely easy-to-use DVD copying software to copy any DVD movie with excellent DVD copying quality in Full Disk Mode or Main Movie Mode. It can copy DVD movie to computer as DVD folder, ISO file, copy DVD to DVD disc; burn ISO file or DVD folder to DVD disc.
Guide - How to copy DVD files easily
Step1. Select DVD Source
Download iSkysoft DVD Copy for Mac and install it. In the “Select Source” field, click and select “Select source DVD folder”. Then browse your computer hard disc and select your DVD movie (either in a folder or from your DVD ROM).
Step2. Select DVD Copy Method
iSkysoft DVD Copy for Mac allows you to copy DVD to a folder on your hard disc or directly burn DVD to a new DVD disc.
In the “Select DVD Copy Method” field, click to select a method to output the selected DVD movie:
If you want to output your DVD movie to a folder on your hard disc, you can select the “Output DVD Folder” option, and specify a directory to save the copied DVD movie.
If you want to directly burn your DVD movie to a new DVD disc, you can just select the DVD ROM where you have inserted a blank DVD disc.
Step3. Program Settings
Set Buffer Directory: Specify a directory on your hard disc as the buffer directory to store the temporary files generated during the conversion. We recommend that you select a folder on a hard disc that has relatively big free space.
Select Language: Select an interface language for the program. The currently available languages are English and Simplified Chinese.
Step4. Start to Copy DVD
Click the Start button to start to copy DVD movie and/or burning it to a new DVD disc.
Note: If you are copying a DVD disc from your DVD ROM to a new DVD disc, iSkysoft DVD Copy for Mac will ask you to insert a blank DVD disc when the program gets ready to burn. Then you can just take the original DVD disc out and insert a blank DVD disc.
on Jun 21, 2010 | Computers & Internet
Tip
How to copy DVD Movie on Mac OS X?
This step-by-step guide is dedicating to demonstrate how to backup DVD movie (copyright protected included) to computer and copy DVD to a new DVD disc with no protections on Mac OS X (leopard included)
The tool you need is Aimersoft DVD Copy for Mac, which you can download for free from here.
It’s very easy to use, just with three simple steps then you can easily copy DVD on Mac.
After you install and lunch Aimersoft DVD Copy for Mac, put the DVD disc into your DVD drive. Click the “Select Source” drop-down list to browse your computer and located your source DVD movie (either in a folder or from your DVD-ROM).
Step2: Select DVD Copy Method
Aimersoft DVD Copy for Mac allows you to back up DVD to a folder on your hard drive or directly copy DVD to a new DVD disc. In the “Select DVD Copy Method” field, select a method to output the selected DVD movie according to your need:
If you want to back up your DVD movie to a folder on your hard disc, you can select the “Output DVD Folder” option, and specify a directory to save the copied DVD movie.
If you want to directly copy your DVD movie to a new DVD disc, you can just select the DVD Burner where you have inserted a blank DVD disc.
Note: If you are copying a DVD disc from your DVD Burner to a new DVD disc, Aimersoft DVD Copy for Mac will ask you to insert a blank DVD disc when the program gets ready to burn. Then you can just take the original DVD disc out and insert a blank DVD disc.
But if you have two or multiple DVD Burner, you just need to change object DVD to another DVD burner and insert a blank disc into it , then Aimersoft DVD Copy for Mac will automatically copy DVD movie to the new DVD disc. No need to wait for the conversion to insert a new blank DVD disc.
Step3: Program Settings (optional)
Set Buffer Directory: Specify a directory on your hard drive as the buffer directory to store the temporary files generated during the conversion. We recommend that you select a folder on a hard drive that has relatively big free space.
Step4: Start Copying DVD
After all things done, click the Start button to start copying your DVD movie or burning it to a new DVD disc. That’s all.
on Feb 10, 2010 | Computers & Internet
My DVD/CD ROM is showing no Disk in the drive (E:), while there is.
is it a blank cd? if so try going to the start menu my computer right click on drive (E:) properties and make sure writing on this device is enabled if its not a blank cd but a copied one it may be the disk thats the problem not your computer. if its a shop brought music cd copyright protected it may not read it because of copyright laws!!! if its like this with all cds then you laser may be faulty
Jan 11, 2011 | Acer Aspire 5315 Notebook
Hi does anyone know about dvdfab 6
For that you have need dvd burner software and dvd rom righter.
You can downlaod nero from this link.
http://www.soft82.com/download/Windows/Nero
downlaod then install in your compurter.
Then open nero start smart then clik on add button then add those files which you want to copy to dvd.
Then click on finish.
Then clcik on burn thats it then wait .
Aug 22, 2009 | Computers & Internet
Cannot copy DVD because no write speed is selectable
Try to uninstall and reinstall the roxio software in the system and it will fix the issue.
Hope this Help
Cheers!!!
Jul 16, 2009 | Roxio Easy DVD Copy 4 Premier
My dvd burner wont read or recognize a copyed disk is in drive
My Optorite DD0405 will not burn a DVD+R DL disk? is this because its not supported by the burner? I have Nero 9 and would like to burn 4.8 GB of a file from my desk top to a DVD DL with 8.5 GB space. How can I do this
Thank You
Dec 03, 2008 | Optorite (dd0405) DVD±RW Burner
Burning problem
When you open Nero select copy dvd. Select the dvd-rom as the read drive. Put the dvd to be copied in there. Select the dvd-rw as the write drive and place a blank dvd r or dvd rw in it the select copy.
Mar 01, 2008 | LG GSA-H10N DVD±RW Dual Layer Burner
Recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Jan 20, 2008 | Televison & Video
Was able to make copy but wont play on Dvd player
it might be an older DVD player that can't read computer-made discs, or it could be a disc incapability... Try in videohelp.com - where you can put in your TV's DVD model # and it will tell you which DVD formats it supports based soley on the users findings. Good luck!
Dec 22, 2005 | 321studios DVD X Copy Platinum (200000)...
321studios DVD X Copy Platinum (200000) for PC Logo
56 people viewed this question
Top 321studios Computers & Internet Experts
Peter Dragonetti
Alun Cox
Darial Jr Lasaria
Darial Jr Lasaria
Are you a 321studios Computer and Internet Expert? Answer questions, earn points and help others
