Question about Lanzar 2H 1000W MOSFET AMP Car Audio Amplifier
Rca jacks when i hook up both jacks to amp speakers sound terrible but with one it works eaither side but not both what could br the problem
I have a proview model 3200 is it possible to hook up a set of good house speakers to it because the sound is terrible when listening to music? There are so many jacks on the back it seems do-able.
Hook up the audio output of unit to the stereo audio inputs of your receiver (U need amp to drive any speaker) using the appropriate cord and adapters.
Oct 28, 2015 | Audio Players & Recorders
Getting no sound hooked up to pre-amp and 2 rotel 200w amps with snell speakers
You didn't say whether the player is connected by 2 RCA cables (analog) or by digital cable. If by RCA, does the player have a headphone jack? I had a player once with a piece of a headphone that broke off inside the jack, muting the analog outputs.
May 16, 2014 | Sony CDP-CX300 CD Player
Hooking up the speaker to an amp, using the rca line out of the amp i have no volume control from the amp knobs, can i hook the speakers up to the amp from the speaker out ?
You should NOT under any circumstances connect an audio input lead to a speaker output jack!
The RCA jacks you are trying to take output from ore "pre fader" which would be solid "line level" and not controlled by volume controls. Tap off the INPUT to the amp... you should be using balanced lines for the interconnects. RCA jacks are unbalanced lines. You can drive several inputs from a line level output of a mixer for example using a splitter cable.
Aug 23, 2011 | Harbinger APS12 12 Powered PA Speaker
How do you hook up a amp with a factory radio.. a 2002 impala
1- you need to provide a fused power wire from battery to amp
2- provide a ground wire from amp to car body or frame (be sure to clean off paint if connected to body)
3- connect your remote wire to your fuse box (16 to 22 gauge wire will be fine)
4- connect a line output converter which will allow you to use rca jacks (one side connects to the speaker wire in your car and the other to your rca jacks)
5- finish by connecting your speaker wires and rca jacks
if helpful please rate 4 thumbs up.
Jan 15, 2011 | 2002 Chevrolet Impala
How can i test my rca output jacks with a test light? pioneer deh p3100ub. hooked up spkr, nothing. tried one rca plug to white(lt) and then red(rt). Unit has 4 rca jacks, 2 for subwfr and 2 for front...
:) the rca jacks have to be connected to an amplifier,, their signal is too lay to even light a bulb.. you have to connect it to a car amplifier and then from the amplifier to the speakers..
Just so you'd know,, once your deck plays and you hear music on your speakers through your normal speaker wires,, RCA jacks work..
Ok you have 4 jacks,, 2 subs and 2 front.. These should connect to a preamp,, which takes 4 inputs and allows you to equalize or adjust how the music should sound,, now from the pre-amp,, it runs to an amplifier,, thats powers the subs and another that powers the speakers.. Some amps have 4 inputs so you can use one amp for your subs mids and heights..
for example a basic music system is
1 cd player
1 pre amp
1 amplifier (4 inputs, 4 channel out)
you bridge 1+2 and connect this to 1 12" double coil sub woofer
the next 2 connect to 2 mid speakers example "rockford or ev 5 / 8 " and 2 tweeters for heights..
Thats a kicking tricked out basic car audio system,,,
Hope that helps you understand how it works..
Mar 12, 2010 | Pioneer DEH P3100UB Car CD/ MP3 Player
My akai lcd tv model lct2721ad sound will not work.
We need to verify if the problem is in the preamp or poweramp sections. Hook up the powered PC speakers to the AUDIO Line out RCA jacks and verify that sound is OK there, if it is OK, The problem will be in the power amp sections that drive the speakers. If it sounds bad at the RCA jacks, the problem will be in the sound processor board which mean the main board will have to be replaced, same if the power amp is bad.
Nov 06, 2009 | Akai LCT2715 27 in. LCD Television
No surround sound on normal tv just dvds
Do you have a cable box or satellite box? If you do, try hooking up your TV sound through the box. Look for audio out in the back of box (white/red RCA Jacks). Hook RCA cable from cable box to surround amp. Even if the audio out jacks are being used already, you can use Y connectors to hook up the surround amp to the box.
Hope this works for you!
Jul 23, 2009 | RCA Audio Players & Recorders
Pioneer DEH-P2600
blue and white wire on a pioneer is usually the power antenna wire, most people use it as the lead for power to turn on the amp that is installed, the amp should be hooked up to the RCA jacks on the back of the player to the input RCA jacks on the amp. then the outputs vary, some amps are bridgable which means that you can hook up one speaker to both output speakers this will almost double the watts to the speakers. you must know which side would be positive and which side negative to set it up like this. also important is it a two or four channel amp. this all matters. if you can provide more info I can assure you the best hookup possible for premium sound.
Dec 11, 2007 | Pioneer DEH-P6900UB CD Player
No sound comming from car speakers
What kind of car? What kind of system? More details will help me assist you better. If it is an aftermarket in-dash stereo, it sounds like the blue/white wire is not hooked up correctly. This powers up the car's amplifier and lets the sound through.
Sep 20, 2007 | Car Audio & Video
Car Audio & Video Logo
19 people viewed this question
Top Lanzar Car Audio & Video Experts
Mike Duncan
Mike Duncan
Morne Olivier
Joe Alexander
Joe Alexander
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
