Question about Honeywell HY-048BP Tower Fan
Pressed power button and fan would not turn on.
Yes, we did check the electrical outlet. Could it be that the motor burned out? Fan is a honeywell oscilating tower fan with remote, about 2 years old.
  • Anonymous Mar 04, 2009
    I am dealing with this too.
Buffalo12980
  • 625 Answers
SOURCE: I am trying to fix an Oscillating Tower Fan.
Most fan motors for fan over running have an internal overload. once it trips, it will not reset. it is a solid state device. it looks like a flat device or a small bullet device. if you've figured out how to take the fan apart, you could just remove the device and connect the two wires together and the fan will run. you won't have any protection on the motor however. the windings run warm, but if the bearings run dry the motor will slow down and the windings will get hot. this is the reason for the overlaod device - protection. its your call what you want to have.
Posted on Sep 05, 2007
SOURCE: how do you open up a BDTF101B Tower Fan?
first you have to remove the two plugs on top behind the buttons remove the two screws next you have to remove the base stand and their is one screw you have to remove then you can remove the front cover and you can get to the motor and fan.
Posted on Jul 12, 2008
SOURCE: Fan stopped working
It's possibly a lubrication problem. I can't seem to keep mine lubricated, so good luck with yours.
Posted on Jul 30, 2008
SOURCE: LASKO fan problem
Check for a loose wire in the wiring harness
Posted on Sep 04, 2008
SOURCE: hello,help please
My fan is doing teh same thing. I have been taking the cover off and spinning the fan blade manually. It takes about 1 minute of constant manual vigorus spinning but as soon as its warmed up the fan blade spins easy and just takes off and starts working. Im sure its not the safest thing to do but it does get the fan running for the rest of the night. Once the fan has been turned off for a while the blade is hard to spin again and I have to start over with teh manual process. I am thinking its the motor being I can manually get it started by spinning the fan blade and think I will check on the cost for a new motor
Posted on Jan 04, 2009
Can we add a dimmer switch to Honeywell ceiling fan AC552
If the lights are on a separate switch then yes. If the motor and lights get power from the same circuit, then no. The motor cannot be run on a light dimmer for long before it will burn out. Installing an aftermarket remote control will solve the problem.
Oct 13, 2018 | Honeywell Electrical Supplies
Remove c-24 errorminolta di450/500
Sir/Mam,
C0F24 Code is the code for the sensor that monitors the drum. I would remove the drum cartridge two black screws pull out the drum assy. Remove the drum be careful do not nick or harm the drum the sensor is located on the left side of the to the rear of the of the drum looks like to little eye of a bug. Dust with a brush NO VACUUM static could destroy it. Re-install drum and re-install cartridge. When the last time a PM was done Developer replaced and Drum replaced?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 14, 2014 | Minolta Office Equipment & Supplies
He360 fan and water run continuously
Check yor wiring, make sure you have sail or pressure switch wired in series with humidistat to humidifiers 24V power. Pressure or sail switch will disconnect humidifier when furnace fan is off. Humidifier (110V) could be connected to any closest electrical outlet.
Nov 10, 2013 | Honeywell HE360A1027 Whole House...
Hi,I have a travel trailer 37ft. Problem with my ac, the fan starts good but my compressor does not kick on. My next door neighbour says it's the compressor that is done. Could you help me?
see this causes and fix it. God bless you
Motor Trouble Cause Diagnostic Procedure Repair Procedure Electrical Power is Off Check that all service switches for the equipment are in the "on" position.
Check for voltage at the pump motor or pump controls. If no voltage is found, check for voltage at the electric panel.
If power is on to the building, check fuse or circuit breaker serving the electric motor that won't run.
Check for local reset button on the motor (popped out = off )
Check for other power reset or power off buttons such as an access door compartment safety switch that turns off power to the equipment (found on A/C blower compartment doors)
Turn on "off" switches.
Replace bad fuse. Reset circuit breaker; if necessary replace bad circuit breaker.
Let hot electric motor cool down, then push in its reset button.
Be sure all safety interlock switches such as on compartment doors are depressed and that the doors are securely shut. Replace a bad safety switch.
See
ELECTRICAL POWER SWITCH FOR HEAT
FAN AUTO ON Thermostat Switch
WATER PUMP ELECTRICAL SWITCHES
CIRCUIT BREAKER FAILURE
ELECTRIC PANEL INSPECTION
Blown fuse, tripped breaker Replace fuse or breaker - does the pump run and keep running normally? Be sure proper breaker or fuse size in ampacity is installed - ELECTRIC PANEL INSPECTION Low voltage to the motor Check with VOM at the pressure control switch or at the motor wiring Be sure the proper size of wire is used for the ampacity and length of circuit; Test for low voltage to the building. Loose, improper, or broken motor wire Check wiring against the motor installation manual diagram, check all connections for tightness, shorts, burns, damage Rewire or repair or replace wWhen a sealed compressor motor has "burned out" this means that the internal wiring of the motor has become irreparably damaged: the compressor motor windings may be burned and shorted together or shorted to the steel shell of the motor, or the windings may have burned and simply become "open" or disconnected. If the motor has burned out in either of these ways it needs to be replaced.
Oct 08, 2012 | Dometic Rooftop RV Air Conditioner
I have an Acer AX1700-U3700A and I was working online and stepped away came back and the computer was turned off. I Pressed the power button but nothing turn on .... I have not idea what happened .... Is...
  1. Check your computer is getting power, (reconnect power from outlet)
  2. if power is ok, then open your computer cabinet, disconnect motherboard power (24 pin), then make short Green and Black wires and check power supply fan is working or not, (Switch off computer when disconnecting)
  3. if fan is not working replace power supply (SMPS) and check (working fan means SMPS is ok, but in some occasions Fan may work in defective SMPS )
  4. if the power section is ok you need check you mother board
Thank you...
Please rate me if it is valuable
Aug 28, 2011 | Acer Aspire AX1700-U3793A PC Desktop
Plug the new fan motor, nothing
Sounds as if the Fan Switch may also be faulty. Or the new fan motor is defective. Is the flame function on the electric fireplace working? If the flame function is working, than obviously the fault is either in the fan switch or the new fan motor.
If the motor has a regular receptacle type plug on the end of the cord, try plugging it directly to a wall outlet and see if it works. If you're able to do that, then the problem is in the fireplace's fan switch or in the wiring circuitry going to the fan motor. Perhaps, this is what was wrong all along and not the fan motor, itself.
If nothing is working, check the wall receptacle that the fireplace is plugged into, by plugging in an electric lamp. If the lamp won't turn on, then there's a circuit breaker tripped in your homes circuit breaker panel. Check the circuit breaker panel for a tripped breaker and with nothing plugged into the offending receptacle, reset the breaker. Plug the fireplace back into the receptacle, turn it on and see if it trips the circuit breaker. If it does, there's an electrical short some where in the fireplace. Look for burned or frayed wiring, as well as bad connections.
Hope this helps solve your problem.
Feb 15, 2011 | Dimplex DF3003 Electric MidSize Heater
Plugged in my fan, but it does not work. Is there a fuse that may have burned out?
First, is there power at the outlet? If so, try another outlet. There's a reason for this, but I'm trying to keep this simple. Now, let's say that the outlet isn't working, then check and see if there's a switch operating this outlet. If so, then turn it on, and you should have the outlet working again, along with the fan. In addition to this, also check your circuit breaker to make sure it hasn't been tripped. Also, it's a stretch - but if there's no power at the outlet, you could have a tripped GFI breaker (normally in your bathroom) that is wired through your rooms for added grounding protection. Okay, you've done all of the above - and still nothing. With the fan unplugged, take apart the fan and see if all the connections are good. If so, your fan motor could be bad. Its at this time if you see if there's a fuse in there. I'm not sure, but you'll see a fuse holder in the housing when you take it apart. But I'm not sure if they have a fuse with this fan. Also, there could be a reset button, but again, with this model, I'm not sure. But being an electrician, I usually find a lot of problems with fans being something other than the fan itself. This is why I check the other factors first. It takes a few minutes, and easy to work with before having to take apart the fan. Good Luck to you, and I hope this helps you. Feel free to contact me again if you have any further questions. Jim
Apr 08, 2010 | Honeywell HFT114B Wall Mount Fan
My Lasko Pedestal fan just stopped working completely
Its probably something simple, plug it into another outlet and make sure that outlet work also, if that dont work it will be in the control switch and i doubt the motor is burnt up. You can take srew driver and open up the control cover to see if there a fuse and check the wiring connection from the outlet to the control switch and make sure the fan is unplug before you open up the cover. Jiggle the wire inside the control unit than press and play with the button couple of time and plug it back into the outlet and see that will work. if not than have somone test the the motor with a volt meter making sure the motor still good. I believe it be more likely in the control swith unit. hope that work for ya
Jul 10, 2009 | Honeywell HFS641P Stand (Pedestal) Fan
Hot wire to radiator fan is burning
most likely if that is happening it depends on where the wire is burning. Yes it is grounding somewhere so if it is burning right before the fan than most likely the motor went on fan. For instance if you know the side that is getting the power and say 2 foot away is where it is burning start from there and work you way toward the fan and see if anything could cause the grounding. If not then i would lean toward replacing the motor. Best instance of this is to disconnect the fan connector and knowing what temp your fan usually kicks on take note of. Now let engine idle until it goes past this temp by 10 - 15 degrees and see if wire shorts out if not then its the motor. Turn off motor immediatley and reconnect fan.
Feb 19, 2009 | 1987 Chevrolet Camaro
Honeywell HY-048BP Tower Fan Logo
73 people viewed this question
Top Honeywell Dryers Experts
Rob Sinbad
Rob Sinbad
Jay Finke
Jay Finke
chargerhp
chargerhp
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
