Question about Symantec Procomm Plus 4.8 for PC
Recently procomm plus 4.8 cannot uninstall
Procomm plus doesn't see modem in com 3 (working modem), but only lists "'direct connect - com1/2/3 etc" ports Tried to uninstall procomm plus using both:
start/programs/procomplus/utilities/uninstallprocmplus
and
control panel/ add/remove pgms/uninstall
both failed. I turned off virus protect and firewall - still no good. Programs just don't respond. When I open procommplus, i get and error Windows Telephone Warning: Windows telephony operation has failed. Verify that the modem is powered on
and properly connected to the computerand the phone line.
Help!
It has been working fine until recently - not sure when it stopped as I use it once every 5 wks when I go on call.
  • Anonymous Feb 20, 2009
    When I am opening the procomm,it does not Saying anything.but when I try to connect with any Telephone number Its throwing the error as "Telephony Operation has failed.Verify that the modem is powered on and properly connected to the computer and the phoneline"
PCTServices
  • 120 Answers
SOURCE: downloads
Norton 360 has the entire norton protection suite built into it. On top of the firewall, phishing protection, and e-mail protection it also has norton antivirus built right into it. So yes, you have to uninstall antivirus to install 360, but 360 just installs antivirus again. If you ever decide to go back to using just antivirus you can simply redownload it off their web site. Peter
Posted on Oct 04, 2007
SOURCE: Winfax pro problem
go to http://www.getfaxing.com Winfax pro support area
they have a fix available for this
Posted on Jul 01, 2008
nsindian
  • 137 Answers
SOURCE: Cannot uninstall WinFax Pro 10
try using ccleaner, which can be downloaded for free from ccleaner.com. it has a tools section where you can remove programs. it can also fix registry issues, which i think you may have with this Norton.
Posted on Jul 03, 2008
  • 84 Answers
SOURCE: I installed Norton 360 and
Well may be you must chek for norton updates or you have bought the older version....
Look for updates in homepage at norton.com
Posted on Dec 10, 2008
GetFaxing
  • 143 Answers
SOURCE: cannot close controller to allow re-install of winfax pro 10.02
Control-Alt-Del and end tasks Wfxctl32.exe, wfxsvc.exe , wfxmod32 ...and faxmng32.exe
This can be any number of problems, like corrupt logs, too many entries in your default log structure,. You can check this link regarding rebuilding your logs:
http://www.getfaxing.com/cgi-bin/ib315/ikonboard.cgi?act=Help;CODE=01;HID=30
WinFax Tools has many fixes for WinFax that are automated.
http://www.getfaxing.com/cgi-bin/ib315/ikonboard.cgi?act=ST;f=17;t=412
Posted on May 29, 2009
Telephony device has been removed...
That means you took the fax modem out, or the drivers are missing
Nov 30, 2013 | Symantec Procomm Plus 4.8 for PC
My Tata Photon Plus USB Modem is not being detected in my laptop. Previously it used to work (for almost 3 months). But now all of a sudden,it is not being detected no matter what. It works on my other...
I just solved the same problem on my laptop with the help of Tata's tech support -
first, plug in the Photon plus modem, remove any other usb devices (mouse, etc)
right click on My Computer, select "manage". Click on Device Manager, expand the list of Serial Bus Conductors.
Right click on each "USB Composite hub" (not root hub) and uninstall.
after all composite hubs are uninstalled, go to the "computer" section at the top of the list in the Computer Management box. Right-click on "Computer" and click on "scan for hardware changes". Yiur system will reinstall the drivers and give you a notification at the bottom right corner of your monitor. Once u get the message "drivers successfully installed", open the Photon plus dialler and connect. It worked for me, hope it works for you too!
Jan 28, 2010 | Computers & Internet
I Cannot set up my wireless G plus MIMO router !
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 27, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Im trying to connect my ps3 to my wireless router. it has recently stopped working. is there anything i can do?
Sure! Try this:
1 Turn your network off. Modem router, computer, printers etc. turn them off.
2. Leaving the wireless router connected to the modem with an ethernet cable (modem power off) , turn your wifi router on and let it cycle up.
3. After the router is cycled up, turn power on to your modem , leaving the ethernet cable connected to the wifi router's internet port. Let the modem cycle up .
4. After this, turn on all computers, routers and etc... no particular order.
This should allow your modem to find the wifi router and direct it to your computer via wifi or ethernet..
Dec 08, 2009 | Computers & Internet
How to set this routuer
Know who is ur ISP(internet service provider)and what type connection.Is it come through TV cable or telliphone line
If it is cable type and if u have a modem
Firt u need to have 2 ethernet cables (RJ45 cable) connect ur laptop directly to to router number 3 slot and and connect ur modem to modem slot to back of the router .power cycle the modem and router,that is turn OFF the router and modem both and turn ON first modem and then router it should work
Take out the cable between the laptop and router and connect the computer to the wireless network .......... finish............
Jan 30, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My procomm plus issue
Procomm Plus and norton 360 are compitable to each other but r not not compitable to work on your operating system .u will just need to format your pc and clean the Procomm Plus files from it and then also delete the norton 360 from your operating system.and then u will be able to reinstall the Procomm Plus after formatting the pc.then instead of norton 360 install any other antivirus software like symantec or avg
Dec 10, 2008 | Computers & Internet
New ADSL Modem on Windows 2000 Generates Error 692
1. Check to make sure the correct modem is selected in the dialer.
2. Make sure there are not multiple modems installed.
3. Uninstall and reinstall the modem.
4. Make sure that no other programs are using your modem. Fax software, Supervoice, etc...
5. Get a new modem, send it back.. Your computer is just fine.
was i helpful enough?
Nov 23, 2008 | Computers & Internet
Unable to detect modem for nokia 6070
download 6020 cable modem drivers from http://europe.nokia.com/A4144316 (yeah, no modem drivers for 6070). then go to device manager and update modem drivers to downloaded one.. that only will do.
Jan 25, 2008 | Nokia 6070 Cellular Phone
Symantec Procomm Plus 4.8 for PC Logo
481 people viewed this question
Top Symantec Computers & Internet Experts
Tony
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
