By M0nica L - usenet poster
I have a set of cordless headphones, but I've lost the power cord. How can I determine the input voltage so I can get them powered again?
Solution #1
posted on Aug 08, 2005
Ryan - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
The specifications for your power cord would be listed on the unit itself if not in the owner's manual. If you look around the unit near the area where the power cord plugs in or if you look on the bottom there will be some sort of requirement that says something to the effect of "12VDC or 15VAC etc." or whatever the voltage and miliamperage is required to power it. Then you can take that information to Radio Shack or some other electronics retailer who can help best match a power supply for the unit. Also you could contact the manufacturer on their website. Most times they keep things like that as extra stock to sell to customers who have a situation like yours.
After that if all else fails, get a universal power adapter. and start with the lowest voltage and gradually move the switch to the next higher voltage. If that does not work, switch the polarty of the adapter and start from the lowest voltage again until it works for you.
A device like that usually operates anywhere between
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Slider Kyocera SE47/ Portable
Email this problem
Email this problem
This Problem Also Relates To:
Ericsson FREE Logitech 980150-0403 Mobile Over Ear Blue- OEM Headset
Kenwood KCA-BT100 Wireless Headset
Motorola HS850 Consumer Headset
Motorola Bluetooth Hands-Free Speaker T305 Wireless Headset
Motorola Razrwire Bluetooth Headset - Silver Frame Headset
Motorola H700 DOLCE & GABBANA Limited Edition Wireless Headset
Motorola HS500 Wireless Headset
Can you Help with these Headsets problems?
Repair Service
Find Headset Repairman Near You:
