Question about Toshiba Televison & Video
Cannot get TV to make connection and play a DVD
New Toshiba TV June 08; combo Toshiba DVD/VCR cassette recorder is, at the most, 4 years old (and has always worked well). Played a series of movies a month or two ago - everything worked fine.
However, I can not get the CD to play on the TV????????
    Novelist:
  • 152 Answers
Hello, it seems your new tv will not work as a standalone audio amp or just for audio amplification. with no video signal it will seem to the tv video processor as a insuficient video source this will cuase no detection of video not allowing the selected source input to operate for sound only. if it is a dvd music video or movie it does becuase the tv is sensing incoming video signal and allows the selected input circut to operate.
you may want to connect your dvd player audio outs to your audio amp or surround sound processor first if you want to play cd,s with no video or use the dvd/cd player with your sound system when playing back music cd's.
hope this helps
Posted on Dec 15, 2008
  • 108 Answers
First, check all connections carefully while consulting the manual. This is usually the solution. Then run the CD on your computer to make sure it is OK. If so, disconnect the cable from the DVD port and replace it with the CD player. If this works, then you need to install an A/B switch so that each device can be used separately.
Ray
    President:
  • 2,110 Answers
HAve u checked all the cables connected to TV ...then if it is OK,then It seems ur dvd player lens needs cleaning...
    Genius:
  • 1,847 Answers
Do you get any error message ?
  • Toshiba Master
  • 19,396 Answers
Toshiba has one year factory warranty, if it is malfunctioning get a replacement.
  • Ginko
    Ginko Dec 15, 2008
    If the Toshiba is not reading some CDs or DVDs, it can have a dirty lens problem.
    Try using a len cleaner , like the ones here.
    Check also all connections , and ensure that TV input is on the right channel.
    If this does not work call the number listed on the owner manual to get assistance, the unit should be under factory warranty.
    Try cleaning the lens first.
  • Ginko
    Ginko Dec 15, 2008
    Sorry I read 4 months before, clearly warranty is expired.
    Try lens cleaner , like the ones here,
    Check connections and tv input settings.
Govideo DVD/VCR combo, vcr side not playing properly and won`t release the tapes.
MAKE THIS TEST AND FIX IT. God bless you
1.
    • 1
Make sure the device is plugged into the household power supply and is switched on if no indicator lights are illuminated on the control panel. Watch for any power-saving technology that can shut the recorder down when it's not being used. Try the "Power" button again.
    • 2
Verify that the media you are using is compatible with the device. Most combos record to DVD-RAM/-R/-RW/+R/+RW Discs on the disc side. VHS cassettes can have erasure tabs, so check that the tab is still there if you can't record to the cassette. Watch out for copy-protection technology on either the tape or disc. Often it's indicated on the packaging. Copy protection is designed to stop illegal reproductions, so may block many recordings of copyrighted material.
    • 3
Connect a television to the "Video Out," "S-Video Out" or "Component Video Out" jacks on the DVD-VCR combo if you can't see video from the combo playing on the television.
    • 4
Forcibly eject a disc if it is stuck in the combo. Often, manufacturers will create a sequence of buttons to use that accomplishes this. On a Panasonic, you force the combo into "Standby" by pressing "Power" for 10 seconds. Then press and hold "Stop" and the "Channel Up" button together for five seconds, and the disc should eject.
Oct 30, 2013 | Televison & Video
I would like simple steps to transfer VHS to DVD on my Toshiba DVR620KY. I want to copy with the unit alone. Would appreciate your help. Thanks.
Hi ,
Please follow the instructions below to record from VHS to DVD. You may not be able to record from some pre-recorded VHS cassettes due to copyight protection embedded into the recording. You should stick some tape over the copy-protection tab on cassettes prior to recording if the tab has been removed. On some cassettes, there may be a slide switch which needs to be moved to the record/rec position. All pre-recorded cassettes will have the copy-protection tab removed.
1. Switch on the TV and DVD/VCR and select the correct input on the TV for the player.
2. Set the player for the recording direction, i.e. VCR to DVD . . .
- Press the SETUP key on the Toshiba remote to open the on-screen menu
- Use the UP/DOWN arrow keys to highlight GENERAL SETTING then press ENTER
- Use the UP/DOWN arrow keys to highlight RECORDING then press ENTER
- Use the UP/DOWN arrow keys to highlight DUBBING MODE then press ENTER
- Use the UP/DOWN arrow keys to highlight VCR > DVD then press ENTER
- Press the SETUP key again to close the on-screen menu
3. Press VCR to select VCR mode.
4. Insert the cassette you wish to record and fast-forward or rewind it to the position where you want to start recording from. Allow at least 5 seconds extra if not starting the recording from the beginning of a cassette.
5. Press PLAY then press PAUSE immediately.
6. Press DVD to select DVD mode
7. Insert a blank DVD
8. Press the REC MODE button to select the recording mode (XP / SP / LP, etc)
9. Press the DUBBING key to start the recording.
You can watch the VCR while it's recording. When you reach the point where you want the recording to end, press the STOP key. You do not need to repeat step 2 every time you record. The player will stay in VCR > DVD recording mode unless you change it.
Hopefully, you will now be able to record from VCR to DVD. If you need further assistance, please let me know.
Regards,
BElectric
Mar 26, 2011 | Toshiba D-VR4 DVD Recorder/VCR
Can i convert vcr to dvd with my Toshiba mw20F52? there are instructions for other way around, dvd to vcr, but i would like to put old cassettes onto discs.
I called Toshiba. Combo CANNOT record DVDs, just play them. My misunderstanding. Please cancel my account and remove my info from your database. Thanks in advance, Teletanti
Feb 06, 2010 | Toshiba Televison & Video
I have a Toshiba DVR19DTKB DVD & VHS Recorder with Freeview , A SKY + Box, A Panasonic NV-SD240BL Video cassette recorder, A Samsung PS42B450B1W 42'' Plasma TV, and would like see a diagram of how all...
connect the aerial to the dvd/vcr/freeview combo, connect a scart from that to the tv, from the scart out socket.
you can then connect the sky from the scart marked tv to either the tv direct or to the combo if it has a second scart.
Note. a scart socket with an arrow going into a box is an input, coming out of the boe is an output and a double arrow is a two way scart.
if you use scart 2 on the tv to connect the combo, the combo will recieve a signal from the tv for recording.
Jan 21, 2010 | Televison & Video
Can a tape be recorded
the machine that youare going to play the tape in you should use the video out and the audio out to the video in and audio in on the machine that you are going to record on or tape on which ever you want to call it.
Mar 07, 2009 | Panasonic AG-520G 20" TV/VCR
DVD Recorder VCR combo, VCR will stop after 23 sec of play or rec
necesito saber que tecla presiono para desactivar el modo progresivo scan
Feb 14, 2009 | Philips Magnavox DVD/VCR Dual Player
DVD/VCR Combo
your model is "tuner free" that means it does not have the RF screw in connector. Buy one that has a tuner, preferably both ATSC(USA digital) and NTSC(USA analog)
Jul 17, 2008 | Philips Magnavox DVD/VCR Dual Player
Hook-up
first you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV:
cable coax output or if that cable have video/audio ouput is going to INPUT >to combo VCR / DVD player video / audio output is going to INPUT > to TV,.that's the time you can record and playback;
click below for more information in hooking up:
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ...If i have helped,please click fixya,it is the only way i get paid for my work ,also please consider leaving feedback...
Good luck ,and Thank you in advance:
Jul 15, 2008 | Televison & Video
Toshiba TV Combo MW24FP1, DVD player doesn't work on some discs
This is a common problem for all combo units. The high voltage of the TV section attracts large amounts of particulate dust from the air and often it collects inside the DVD unit. The best way to deal with this is to clean the lens of the DVD unit u sing a cotton swab and alcohol. The store bought "cleaners" MAY work, but that is rare. These cleaners are nothing but small brushes embedded into a disc. They attempt to brush off hte dust. This rarely works. Open up the unit (if you feel comfortabel in doing so) to access the DVD section. Remove the top cover and carefully clean the lens. That should resolve the problem.
Dan
May 21, 2008 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
Actually, it's an MW24FP3 VCR unresponsive
After Checking Toshiba FAQ, it turns out that the record button must be turned off to do anything, including playback.
Mar 31, 2008 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
Televison & Video Logo
22 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
