Question about Xerox Phaser 3130 Printer Laser
Printing problem the printer print from dos but not from windows
  • niri bensaadon Mar 21, 2007
    how do I locate the driver in order to turn on the bi-directional?
  • 944 Answers
First check in windows device manager in case the device is not listed or has been disabled (right-click on my computer, click properties and then device manager) Go through the windows hardware troubleshooter and see if you get any joy here is the link to the manual if you need it; http://www.office.xerox.com/userdoc/P3130/pdfs/user.pdf.en and here is the link for driver downloads and updates; http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=3130&Xlang=en_US&Xcntry=USA&source=XOG&prodName=Phaser%203130 I believe that updating/reinstalling your driver should solve the problem, if you get no luck in windows - often other software can interfere with driver files. If you have access to another machine, then try installing it on that using updated drivers and see if you have the same problem. On your machine, depending on the printer connection option you are using, try a different port and/or cable. DOS is not looking for problems in the same way that windows does, so you may find a minor connection issue is the problem. Page 114 of the manual suggests checking that bi-directional communication is turned on in the driver software - DOS would not require this to be on, but windows does. Page 131 - if you have the DOS remote control panel installed, try uninstalling this in case it is causing a clash, although none appear to have been reported. Hope this helps :)
Posted on Mar 17, 2007
WHY DOT MATRIX PRINTER NOT PRINTING DOS BASE PRINTS
It can't.
DOS printing need LPTx parallel port because DOS don't understand/support USB.
YOU can share the printer with windows printer driver, then
go to CMD prompt
Type
Net use lpt1 \\<computername>\<printersharename>
Then print DOS job to LPT1
May 12, 2014 | Parallel USB Print Server 2 Port USB&1...
NOT PRINTING OUT OF DOS PROGRAM
The problem is, the DOS program tries to print to LPT1, which is your parallel port. We need to redirect this to your USB Port. First, you have to set up printer sharing: Go to Control Panel | Printers | Your printer and share the printer. Assuming that you share it with the share name "MYPRINTER" and the computer is called "MYCOMPUTER", then type go to Start | Run and type in: NET USE LPT1: \\MYCOMPUTER\MYPRINTER /PERSISTENT:YES That should do the trick, unless there's a driver problem, which is unlikely for a dot matrix printer. If that doesn't work, let me know and I can troubleshoot further.
Sep 09, 2007 | Panasonic KX-P2130 Matrix Printer
"how to print settings for
If you are talking about one of the TallyCom print servers there is a small blue test button on the side of the box, press this when the print server is connected to a printer that is online. If you press the test button for over 9 seconds the print server will be reset to factory settings. If you want to print from DOS to a network printer as I recall you have two options; 1) Install the printer in Windows and share it, you can then print to the share name 2) Use "NET USE" command in DOS to map a local port to a network port, this is nessesaey if you can not print to LPT1 or COM1 from the application. For help of NET USE go to DOS and use the help options.
Jan 05, 2011 | Tally (43555) Print Server
Posted by rhung33 on Jan 16, 2009 Under Window DOS prompt and Unix Sun Solaris 8 Station , using LPR -p command to print txt file to cause Lexmark T644 printer '' Flushing buffer '' and...
The printer can't handle the data it received and flush it out of its buffer. Goto Menu->Settings->Postscript Settings and turn "Print PostScript Erro" on. When the same print job prints, you should get a page printed out telling you what the printer doesn't like. You may also want to try forcing the printer into Postscript mode. Your PS file probably contains a PJL to set the device to PS mode before it prints. When the printer expects PCL data and received PS data(or vise versa), you can get this behaviour
Jan 16, 2009 | Lexmark T644 Laser Printer
DOS PRINTING DRIVER
you need a dos printing software that will print in Windows
try these
http://www.printfil.com/english.htm?gclid=CKGbrPGd_pQCFQIyxwodyzo6cA
www.freedownloadscenter.com/Best/dos-printing.html
Aug 08, 2008 | Sharp AR-5316 Advanced Digital Imager...
Help me with Zebra TLP 2844
The printer only understands EPL code. (Eltron Programming Language) If you are trying to print text from DOS it wont understand (interpret) the txt codes.
To verify that the printer is working.
Open a DOS box, start the dos editor. Type Edit. Dos editor will open.
Type a single capital letter U. and print. Send to printer. The printer will print a configuration label.
EPL code to reset printer is
^default.
If you want to print a text file. use the Zebra Universal Driver. Zebra TLP2844. Open any windows application. E,G, Notepad. type text and send it to printer. Print as normal.
Jul 24, 2008 | Zebra LP 2844 Thermal Printer
USB printing through DOS mode
Google for DOS PRINT USB, and you'll find some utilities that do this.
Or, you can include some commands in your batch file.
First, get the device name:
In a DOS window, type NET VIEW ComputerName (or use 127.0.0.1)
Once you know the printer share name, you use it in a batch file.
NET USE lpt1: \\ComputerName\ShareName /Persistent:Y
This captures the print queue to the shared printer.
You must also go into Printer Properties/Advanced/Print Processor and set it to TEXT
Your copy, print and other commands will work.
Jul 12, 2008 | Computers & Internet
ML-1610 Laser Printer
hello sir first u install dos base drivers from your printer cd -see below
go control panel printers and faxes select dos base defalt print ok by if any problem uday_uday2004@rediffmail.com
May 19, 2008 | Samsung ML 1610 Laser Printer
Konica Page Pro 1350 - Not printing from DOS
When you install your printer, you may notice an message asking whether you want to print from DOS based programs. If you answer yes You could print from DOS based programes too. To do this you may need to unistall and re-install your printer again ! If it doesn't work you should download any ultility from the internet to get the printer supported on DOS.
Oct 06, 2007 | Konica Minolta PagePro 1350W Laser Printer
Printing from Dos Prompt
1. Save your text file (.txt).
2. On the command prompt navigate to that directory
3.Type "Lpr -S 192.168.1.200 -P lp text.txt"
Substitute 192.168.1.200 for your copier's ip
Substitute text.txt to filename.
Or you can: to print from MS-DOS apps.
1. Share the printer on a networked windows computer. Make sure you make the name MS-DOS compatible.
2. At a DOS prompt, type the following command:
"net use lpt1: \\servername\printer_share/persistent:yes"
NOTE Servername=computer name
printer_share=printers share name
Sep 28, 2007 | Office Equipment & Supplies
Xerox Phaser 3130 Printer Laser Logo
89 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
quennie732
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
