Question about Nokia 1100
Nokia 1100 increase no. of rings before going into voicemail
I've got the above phone on an Oz prepaid service and want to increase the number of rings before it goes into voicemail.
How do you do this?
thanks.
    Brigadier General:
  • 7,752 Answers
You can not do that only your provider can assign the number of rings before going to VM...so contact them and have them do that for you....
Posted on Dec 27, 2008
How do I increase the number of times the phone rings before it goes to voicemail
Turn your voicemail off ? thru setttings then call.? or try this
type this into your phone
**61*101**30#
press call
this will extend the ringtime from the default of 15 seconds to 30 seconds
Change How Long Your Phone Rings Before Sending Calls to Voicemail
May 04, 2015 | Samsung Galaxy Centura Android Prepaid...
How can I get my nokia 206 asha on sainsburys mobile to ring for longer before going to voicemail?
call like you are checking your voicemail, there are sometimes options with your carrier to adjust as you check voicemail.
Jul 31, 2014 | Nokia Asha 206 Dual Sim GSM Unloced With...
Turn off voicemail 6408D+
Turning off voicemail is usually done by the voicemail administrator, they can reset passwords and add or delete a mailbox on an extension. The number of rings before going to voicemail is usually system wide, and that program is changed by whoever programs your phone system.
Apr 21, 2014 | Avaya Definity PBX Phone 6424D+ Gray
Increase number of rings before voicemail, vtechcs6419
The CS6419 isn't an answering machine. The phone will ring until you answer, an answering machine or voicemail system picks up, or the caller hangs up.
To change the ring count on an answering machine or voicemail system, refer to the documentation for that system. If you require further assistance, please add a comment to this question and identify the answering machine or voicemail system.
Jan 28, 2014 | Vtech DECT 6.0 Digital Cordless Phone
How do i change the number of rings before voicemail picks up on a samsung rugby
For all of you that want a real answer here ya go. This isn't something you can change on your phone this has to be changed with your service provider. If you are with AT&T, like I am, then this is the solution for you (link of where I found it below as well). 1. enter *#61*11# and press send/talk on your phone.
2. write down the number your calls are currently forwarded to (usually +1401#######, but not always). this is your voicemail deposit number.
3. decide how long you want the phone to ring in 5 second intervals. the maximum time is 30 seconds. i'd recommend 25 seconds or less, as using 30 may cause you to be billed for a minute of airtime each time someone is forwarded to voicemail.
4. now enter **61*[number from step 2]*11*[number from step 3, use 2 digits]# and press send/talk.
example
voicemail deposit number is +14015551212
you want it to ring for 20 seconds
you would enter **61*+14015551212*11*20# and press send/talk.
if you have trouble with the above procedure, you can always call customer care at 800-331-0500 to change it.
OR QUESTION: How can I adjust the number of times my wireless phone will ring before the caller goes to voicemail? ANSWER: Contact Customer Care at 1-800-331-0500 or dial 611 from your wireless phone to change the amount of time your phone will ring before going to voice mail. The adjustments made by Customer Care are based on the traditional ring heard by the caller, not the unique Ringtone you hear from your phone. I just wanted to add that increasing the ring length to 30 seconds will not cause you to be charged a minute should the caller go to voicemail. This was confirmed by an AT&T technician.
http://forums.att.com/t5/Voice-Mail/Increase-the-number-of-rings-before-a-call-goes-to-the-voicemail/td-p/2576651
Aug 11, 2011 | Cell Phones
THE ANSWERING SYSTEM WON'T RECORD MESSAGES,ALL MESSAGES GOES INTO POOVIDERS VOICE MAILE, AS IF MY PHONE IS BUSSEY?????? I CHECKED AND RECORD TIME IS NOT SET TO ANNOUNCE ONLY ANS ALL MESSAGES HAVE BEEN...
This happens when the number of rings to answer of the provider voicemail is less than the number of rings to answer that the answer machine is set for. For example: if your provider voicemail rings to answer is set for 3 rings and the answer machine is set for 4 rings then the voicemail answers before the 4th ring, therefore the answer machine will never get a message. I would call the service provider's customer service number and request they increase the rings to answer above the number of rings to answer that the answer machine is set for. If you don't want voicemail to answer any calls(when your line is busy or when the answer machine is turned off) ask your service provider to disable voicemail.
Mar 30, 2011 | Uniden Cordless Phone
Does not wait for the 4th ring; sends call to verizon voice mail box after the second ring
Sounds like your service provider(Verizon) has your phone line setup to forward to voicemail on no answer after 2 rings. Call your service provider's customer service number and request that the number of rings for forward no answer be increased to at least 5, then your answer machine can receive and answer your calls after 4 rings but if your line is busy callers can leave a message with your Verizon voicemail service. If you don't want Verizon voicemail to answer any of your calls, you could have them disable the voicemail service. When you call the service provider have a recent bill ready because they may request your account number before they will make any changes.
Feb 25, 2011 | Uniden EXA15580 Cordless Telephone
I can call out on my phone just fine, but when people call me the phone doesn't ring. Every call goes to voicemail.
Contact your service provider (AT&T, Verizon, whoever) and have them check your call forwarding settings. I work in AT&T technical support and that is the issue 98% of the time. The calls are set to forward directly to voicemail without even ringing, just have them check it out. :)
Nov 20, 2009 | Nokia 1100
Nokia 1100 Logo
310 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
Damen Wong
Damen Wong
