Question about Western Digital 500GB My Book World Edition 500 GB Hard Drive
Ethernet cable Hi do I need the ethernet cable with the usb or is it optional
  • 6,487 Answers
Its just optional if you like to use a Ethernet cable for this device , for us long the device is connected via USB its definitely fine....
Posted on Dec 15, 2008
Trying to set up broadband on my computer now
we have three options to set uop broadband
1 with ethernet cable which has similar ends
2 usb cable
3 wireless
best option is to connect with ethernet, because we dont require any drivers with this option, just connect the cable, one end to the back side of computer another end to router, so in simple words it s the cable connectivity between computer and router and you will be connected
Thanks
Sep 07, 2011 | Computers & Internet
Hi, I cannot connect my Lacie "EDmini Ethernet 400 gb" on to my laptop (dell with windows 7) via the Ethernet option? The blue light goes on but the disk cannot be found by my laptop. Could you...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Feb 02, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
How can i connect my laptop bought 2 weeks ago to my cable modem its a sb5101 cable modem by motorola
This modem is USB or Ethernet. I strongly reccomend using the ethernet and not the USB option as USB will lose some speed.
An ethernet cable is a standard RJ45 Jack'd cable (both ends) - check google images if unsure but you'll see the plug in the modem that is the same as one on your laptop.
If you dont have an ethernet port on your laptop (possible but unlikely) then you'll have to use the USB option - this is a usb cable similar to a printer usb cable (square usb end at the modem and flat usb to the laptop)
Hope this helps! please dont forget to rate :)
Nov 03, 2010 | Arris SURFboard® SB5101 Cable Modem
Connect ethernet without a network card
Actually what you need is a USB ethernet adapter. Then you connect a standard ethernet cable to the USB dongle and to the router or DSL or cable modem. Tigerdirect.com has both 10/100 and gigabit ethernet devices of this type. Since USB 2.0 is limited to 480Mbs, stick with the 10/100 type. Other stores will also have these devices; just read the specs to check that Win2K is supported.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=589&name=10-100%20Ethernet%20USB
The Belkin in that list has Win2K support in the specs. In some cases, these work better when directly plugged into the computer, not a hub.
I hope this helps.
Apr 15, 2010 | Computers & Internet
What are my options to configure Canon i850 for wireless printing
Hi
I looked at the specs of you printer and it does not support ethernet/ wireless connectivity your best bet would be to connect your printer to your router with usb cable that's if your router supports it else you can buy what they call a wireless print server and connect wirelesly to your router or pc
Nov 17, 2009 | Canon i850 InkJet Photo Printer
What is the difference between connecting a computer to a DSL modem via Ethernet and connecting a computer to a DSL modem via USB?
They are just two different methods of connecting a router. I always choose using an Ethernet over USB if I have the option. USB connections are more prone to problems with drivers.
Sep 23, 2009 | HP Pavilion dv6000z Notebook
Connect kyocera fs680 to laptop
it depends on what laptop you have. the fs680 only has a parallel connection so your laptop needs to have a parallel port or you need a usb to parallel converter.
Jan 13, 2009 | Kyocera Mita FS 680 Laser Printer
Ethernet cord
no that is a optional funtion...you do not need to that to do the main funtion of the HDD
Dec 15, 2008 | Western Digital 500GB My Book World...
Hard ware problems
HI Barry
You need something called an ethernet cable. One end of the cable goes in the router and the other end goes in the ethernet poet of the computer.
This is an ethernet cable
512c92e.jpg.
This is the network port (ethernet) of the PC
If you dont have an ethernet port on ur pc u may need to pay an ethernet pci card like this and get it installed on your computer
Hope this helps
Cheers
JigSaw
XoXo
Aug 10, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Trying to get router to work
U can use
USB Ethernet Adapters.Visit:
http://www.ramelectronics.net/network/network-cards/usb-ethernet-adapters/c40000-c43000-c43004-p1.html
Dec 27, 2007 | Computers & Internet
Western Digital 500GB My Book World Edition 500 GB Hard Drive Logo
69 people viewed this question
Top Western Digital Computers & Internet Experts
Alun Cox
Marvin
Marvin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
