Question about Epson Stylus CX6600 All-In-One InkJet Printer
Still getting blank pages.
Prints blank pages. I looked all over your website but could not find your:
" I have the latest version of SSC Service Utility to download directly onto your computer and instructions on how to use it, what to click on etc etc. "
Maybe that would help me. I did try to print/copy in color, and all I got was a vague print all in magenta...no other colors. All my cartridges are full. I've done all the head cleaning, nozzle cleaning, etc. Still no print. It acts like it's printing, even sounds like it, but still blank pages. I deleted and reinstalled printer,..no print.
  • 1 more comment
  • davidwright2 Jan 20, 2009
    My printer seems to have all correct procedure, but absolutely nothing will print onto a sheet of paper. I have replaced the ink, I have run all of the head cleaning procedures as listed in the previous solution, yet I cannot get anything to print?
  • James W Chappel Apr 06, 2009
    I had the same problem, but running the head cleaning utility 4 times as suggested solved the problem.
  • rexoxley Apr 14, 2009
    I have the CX6600 too. I was doing a large printing job of about 400 pages. I was almost finished printing these full color pages and then I noticed the last 6 printed with the magenta missing -- so the image was green. Then, I started the head cleaning process and from there the whole thing went down hill and now I can't get anything to print. The test print gives me nothing but if I do a full page color copy (from a catalogue) then I do get the other colors. It's strange, one minute it was great and then next it was bad. Please help.
    Novelist:
    Sniper:
  • 68 Answers
You have air or dry ink in the nozzle chambers, you use the head cleaning facility but when it finishes it asks you to print a nozzle check pattern, click the finish button.
You need to do 4 head cleans and cancel the nozzle check print after each until the 4 are done then allow it to print the pattern.
This will prime your heads and clear out any air locks.
The only other thing I need to check, but it's a bit of a numpty suggestion. If you have not removed the yellow 'tear off' strips, no ink will flow and your chambers will be full of air. If this is what happened, remove the 'tear off' strips and carry out the procedure above.
I hope this helps.
You don't need the utility for this but it would be handy for you to have.
It is quite easy to find, it's on our home page and on the Epson page just below the big blue drop down menu box. It's simply a 'click here' link along side the text "If your printer needs resetting" etc etc.
Nige
The INK Store
Posted on Jan 17, 2009
  • Aeronautical Jan 17, 2009
    Sorry I forgot to give the address incase you're going to the wrong site: The INK Store website is: http://www.the-inkstore.co.uk
  • Aeronautical Apr 08, 2009
    I'm afraid to say, if you have not used your printer for about a year, then sometimes it is unserviceable as, the fixed print heads will have dried so much that they couldn't be cleared with a hammer & chisel. The problem lies in the printing process where ink passes through chambers that have heat plates within and heat up to about 1000 degrees to cause the liquid ink to boil and bubble. It is the bubbles that eject from the head nozzle holes onto the paper forming your text or pictures, which is why the first [inkjet] printers that were made by Canon were called [Bubblejet] printers. When static, the ink in these chambers is exposed to the air through the head nozzle holes underneath, where it will start to dry. The longer you leave the printer without use, the more it will dry.
    * IMPORTANT*
    The big problem is then caused by the user when trying to print anything after leaving the printer ink to dry for a long period (1 month or more), because now the heads are blocked stopping any flow of ink through the ink chambers and when the plates heat up to 1000 degrees, all this succeeds in doing is hardening the ink in the chambers because it can't bubble out of the nozzles. Had the user 'Primed' the heads before trying to print, the printer heads may have been saved, but the instant the user tries to print with blocked heads the printer becomes useless and very difficult to recover from, if at all.
    I'm sorry if this sounds like "locking the stable door after the horse has bolted" but I just hope that some people get to read this before making that fatal mistake.
    *REGULAR USE IS THE BEST MAINTENANCE*
    If users find themselves in an unrecoverable situation with their printer heads and priming makes no difference, then it would be wise to try cleaning cartridges. These are available for a lot of the older models, but newer models are difficult to get hold of due to the fact that new printers shouldn't really need major recovery yet and production has not been initialised due to low demand. If you are desperate for a cleaning cartridge which is not yet available, use an almost full ink cartridge of the same colour as the blocked colour, blow out the ink into a sink by blowing through the air channel / hole at the top of the cartridge (Careful as ink goes everywhere) then buy cleaning solution and inject it into the cartridge through a drilled hole at the top of the cartridge reservoir. Insert the ink cartridge as normal and carry out the priming process mentioned earlier. Leave the cleaning cartridge in the printer for 24 hours then try a nozzle check print. You will only see a faint dye colour printing the pattern if cleared. If still blocked, you'll see absolutely nothing.
    When cleared, you'll have to insert a new ink cartridge and then prime the head, as it will be full of cleaning solution.
    Hopefully you've now done what everybody says can't be done and the printer didn't have to be stripped to do it either.
    If still blocked after 24 hours, try 48 hours or even a week, but if no nozzles clear after this time, there is either an electronic break-down to that colour print head or the blockage is so bad that it will never clear. For this I have no cure!
Why blank page print in canon LBP-3300
To help you troubleshoot the issue about Canon Laser printer 3300 prints blank page, please follow the steps given below:
- First step is to ensure that you have installed the latest drivers for the printer, downloaded from the Canon Support website or you can find the link given below to download and installed latest drivers from the website given below:
http://www.canon.co.uk/support/consumer_products/products/printers/laser/i-sensys_lbp3300.aspx?type=drivers&language=&os=WINDOWS%207%20(32-bit)
GuruAid.com
Jun 13, 2016 | Canon LASER SHOT LBP 3300 Printer
My cx 6400 prints blank pages why
WON'T PRINT CX400 SAYS IT HAS AN ERROR WHEN ASKED TO PRINT
Sep 24, 2008 | Epson Stylus CX6400 All-In-One InkJet...
R265 resetting
you can use the ssc service utility by download the software from this link
http://www.ssclg.com/epsone.shtml
Mar 28, 2008 | Epson Stylus R265 InkJet Photo Printer
EPSON STYLUS C4OUX
Please go to my website http://www.the-inkstore.co.uk . I have the latest version of SSC Service Utility to download directly onto your computer and instructions on how to use it, what to click on etc etc. Click any of the Epson links if you can't find it, everything you need to know will be there, including printer Firmware resetting which sorts out a multitude of problems.
The 'maintenance required' problem with Epson printers has absolutely nothing to do with which cartridges you are using, it is a built in page counter in your printer firmware, which has a different maximum amount for each Epson model. Don't listen to old wives tales and heresay, we are the experts and it's an Epson scam to cause a lot of people to pay for maintenance or throw their printers away.
I haven't found a model that can't be reset with the latest version of SSC Serve or the manual reset on my site.
For Epson RX500 users there is also a manual reset on my site, as the SSC Serve software won't do it for you.
When using the program & choosing your printer from the list, it may have a weird name with 'x' in the model number, this is because some configurations are for many models in a series. For example, the C46 will be listed as C4x as it is for the C42, C44 & C46 models.
I hope this helps all Epson users to overcome the Epson scam of page counting and locking out until you pay their dealers money for maintenance.
If you like what I've done for Epson users, please show your appreciation by spreading the word and perhaps buying your ink from my site.
Happy trouble free printing
The INK Store (UK & Europe)
Jan 15, 2008 | Epson Stylus C40UX InkJet Printer
Service required. parts inside your printer are at the end of their service life. see your printers documentation for details. manual says to contact dealer. have tried using the SSC service utility...
I held down the 'stop' and 'B&W' button while pressing the 'On' button.  this cleared the error message and I was back in business again. This was for the RX620 model.
Gordon
Dec 29, 2007 | Epson Stylus Photo RX700 All-In-One InkJet...
Epson r230 2 red lights blinking and wont print
download the epson ssc service util
http://www.softpedia.com/get/System/System-Miscellaneous/SSC-Service-Utility.shtml
install it set for r230 then using the tray icon right click the tray icon choose protection counter from the menu then choose reset protection counter then turn off the printer then turn the printer back on
Dec 16, 2007 | Epson Stylus RX425 Multifunction...
Where can i get the ssc service utility program downloaded from ?
Oct 25, 2007 | Epson Stylus Photo R220 InkJet Printer
All lights flashing
Oct 24, 2007 | Epson Stylus RX425 Multifunction...
Resetting Printer Chip
Check your reference book[on the Cd] to try to determine the cause of the particular error. If you have used ssc[righ click on the icon in the tool bar] and thern reset all. Also take a look at www.fixyourownprinter,com and type Epson stylus C86 in the search bar.
Sep 22, 2007 | Epson Stylus C86 InkJet Printer
Epson Stylus CX6600 All-In-One InkJet Printer Logo
289 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
