Question about Roper RAS8445KQ Top Load Washer
CYCLE STALLS THE WASH CYCLES STALL AT THE PAUSE OPERATION AND WON'T CONTINUE ON. I HAVE TO TURN THE KNOB AROUND A FEW TIMES AND FIND A SPIN CYCLE TO WORK. AND THEN TURN TO A RINSE CYCLE TO START UP AGAIN.
  • mhpinball85 Apr 28, 2009
    I put the soap in and the washer will fill up,but won't go on to the next cycle. I tried to turn the knob to rinse or spin but the washer will not spin out. Now the washer is filled with water and I don't know what to do.
  • michael32369 May 01, 2009
    the washer fills with water and agitates, but does not stop agitating.
  • 686 Answers
Change your timer
Posted on Apr 04, 2009
Hi my washing machine works perfectly fine but the water don't pump out srew out bottom filter is clean and I clean it on a regular basis. Defy 1300 laundromaid. Thanks please help
You probably have a rock or some object stuck in the pump blades. Take out the pump and turn the blades get out the obstruction
Nov 26, 2014 | Washing Machines
Have Error Code E20 - won't drain. How do I approach?
The diagnostic test is used to check individual component function only. TO START THE TEST: • Turn the Program Knob to the start position, Spin Only. • Press Start/Pause to start the cycle and save it. • Press Cancel to stop the cycle and turn off the LEDs. • Press Cancel again to turn on the LEDs. • Within 5 seconds, press and hold the Options and Start/Pause buttons until LEDs start sequentially chasing, then release buttons. 1. All the LEDs will sequentially light. Pressing a button below a light cluster will light all the LEDs in that cluster at one time to confirm functionality. 2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water should enter through the detergent compartment. 3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water should enter through the bleach compartment. 4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and cold water should enter through the softener compartment. 5. Turn the program knob (4) clicks from the start position. The door lock solenoid will deactivate and the loading door can be opened.When the door is opened, the drum light should turn on. 6. Turn the program knob (5) clicks from the start position. The washer will fill and tumble. Once tumbling has started, the Boost Heater (if so equipped) will turn on. 7. Turn the program knob (6) clicks from the start position. The drain pump & door lock solenoid will activate and the washer will operate in high spin. 8. Turn the program knob (7) clicks from the start position. The control will signal the last error code. Exiting Diagnostic Mode There are two options for exiting theDiagnosticTestmode and returning the washer to normal operation: a) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord OR b) Turn the program knob clockwise 2 or 3 clicks after the start position. Press Options and Start/Pause buttons together for a few seconds until wash cycle LEDs appear.
Dec 26, 2010 | Frigidaire Affinity ATF7000E Front Load...
Kenmore Series 90 washing machine, won't start cycle
First, see the Sears Parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26912691&pathTaken=partSearch
Next, see the Whirlpool / Kenmore Service manual for top load, direct drive washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
I hate to say it but it sounds like a Timer problem.
I'd use the troubleshooting section of the Service Manual and the timer testing procedures to confirm the problem.
Note that there are two types of timers with different procedures to remove them.
Also see the following for how to release the console for access to the timer and other controls.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=5216f244d51176ce1069bbf148b14335
May 07, 2010 | Kenmore Washing Machines
Dishwasher stalls
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
May 31, 2009 | Bosch SHU4006 Dishwasher
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
regards
Michelle
Jan 24, 2009 | Indesit W 123 Front Load Washer
No high speed spin cycle
I just had a similar problem. The washer would just shut down prior to the high spin cycle. I had a service guy in and he had a diagnostics sheet. Did you get an error code? If you have the electronic. Turn the knob to the Drain/Spin mode and press both the "Options" and "Cancel" buttons simultaneously until all control panel lights are lit and flashing. Then turn the knob clockwise in click and the washer will then go into its diagnostics mode. With every click it should do something (i.e. fill, pump, drain, spin, etc..) continue turning 1-8 clicks. On the 9th click you should then get an error code. My code was E47, which I have already posted another possible solution. I could be either the door switch or the control panel. Remove the door switch by removing the wire around the rubber seal, then remove the 2 screws for the door switch and unplug the 3 plugs. Check the readings on the PTC (white plug on doorswitch). If the switch reads around 1500 ohms, then the problem is most likely the control panel.
To exit the diagnostics mode, the easiest way is to unplug the washer, wait 10 seconds, and then plug it back in.
The reading on my switch was 1398 ohms, which is close to 1500, so I ordered a new control panel. Hopefully, this will work.
Jan 03, 2009 | Frigidaire GLTF2940ES Front Load Washer
Agitator not working 90 series model # 11026912691
Hello aksward,
Welcome to Fixya.
Here are some suggestions for any Kenmore washers
Let me know how it goes. I'm still thinking and searching my repair manuals!
Huuum
Please remember to leave a rating!
KENMORE ELITE TOP LOAD
Washer stops, won't fill, rinse or agitate
• Check the following:
Is the power cord plugged into a grounded 3 prong outlet?
Is the indicator on the Cycle Control knob properly lined up
with a cycle? Turn the Cycle Control knob to the right slightly
and pull to start.
Are the water inlet valve screens clogged?
Are both the hot and cold water faucets turned on?
Is the water inlet hose kinked?
• Does the water level seem too low, or does the washer
appear to not fill completely? The top of the agitator is
much higher than the highest water level. This is normal and
necessary for clothes to move freely.
• Has a fuse blown or is the circuit breaker open? If problem
continues, call an electrician.
• Are you using an extension cord? Do not use an extension
cord.
• Is the washer in a normal pause in the cycle? The washer
pauses for about 2 minutes during certain cycles. Allow the
cycle to continue. Some cycles feature periods of agitation
and soak.
• Is the washer overloaded? Wash smaller loads.
• Is the lid open? The lid must be closed during operation.
Washer will not agitate or spin with the lid open.
Oct 06, 2008 | Kenmore 22422 Top Load Washer
GE Adora front load washer overloaded now won't start
Washers - Resetting Electronic Controls on a Washer
If there is a pause in the washer cycle, the controls will lock up. The pause can occur because of a power failure or it was put in the test mode at the factory.
Also, if the washer was stopped before the cycle was complete or the consumer has pushed the stop/pause button to temporarily stop the cycle and the cycle is not reset. Over a period of 24 hours, the washer will pump out and spin, but will stay in the final spin.
To correct the situation, shut off the circuit breaker for 30 seconds or unplug the washer, then turn the timer knob around and back to any position other than final spin. Verify the water is turned on and restore power. This should resolve the issue.
Apr 23, 2008 | GE WSXH208A Front Load Washer
Maytag neptune won;t rinse
Check latch mechanism for alignment. Often operation of machine loosens latch mechanism causing internal switch for "door open (or ajar)" preventing rinse or spin cycle. Opening and closing door presses latch mechanism closing internal switch allowing for continue processing to rinse or spin cycles.
Mar 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
ATF6700FS - Affinity? 3.5 Cu. Ft. I.E.C. Capacity Washer Won't Start
ERR=An error has been detected
PAU=Cycle has been intrupted
58=High current on motor phase
To clear latest stored error code:
• Within 5 seconds, press and hold the Option and Start/Pause buttons until LEDs start sequentially chasing, then release buttons.
• Turn the program knob clockwise 7 clicks from the Start Position. The control will signal the last error code.
• Press and hold the Options and Start/Pause buttons for 3 seconds. The code will be cleared.
• Exit Diagnostic Mode to return the washer to normal operation.
b) Turn the program knob clockwise 2 or 3 clicks after the Start Position. Press Options and Start/Pause buttons
Feb 25, 2008 | Washing Machines
Roper RAS8445KQ Top Load Washer Logo
173 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
