Question about Euro-Pro Shark SC-505 Handheld Steam Vacuum
Steam comes out the handle
When you squeez the trigger more steam comes out at your hand then out the tip
  • buy_n_sell Dec 15, 2008
    This is a model SC-505
  • 108 Answers
You need to disassemble the wand and apply thread sealant tape to all joints. This should solve the problem.
Ray
Posted on Dec 15, 2008
Install upper control rod
Hi, it's Jeremy from Crucial Vacuum.
To attach the upper handle to your Hoover Steam Vac remove the clean solution tank (upper tank) from the deep cleaner. Then, attach the upper handle to the lower handle by pushing the upper handle down onto lower one. Use the provided bolts to secure the handles. Push the bolts into the accompanying holes on the front of handle. If the bolts do not go through the holes easily, your handle is not pushed completely down. When the handle sections are completely together, squeeze the trigger on the upper handle to snap the trigger rod into place.
If you require further help with your assembly, you can find a step-by-step manual at: http://www.searspartsdirect.com/partsdirect/user-manuals/f5865900-hoover-parts-steam+vac-manual
You can also purchase all of your Hoover Steam Vac replacement parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=hoover+steam+vac
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jun 10, 2014 | Vacuums
Light comes on, feel some heat around water tank, but no steam comes out when pump handle
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the
Shark Manuals that you need.
heatman101
';;'[p[p
Jan 22, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Eureka HotShot 350A heats up great but no steam when I press button.
Remove water fill cap. Remove rubber washer under cap. Unscrew three phillips head sscrews, one on end of handle, two under rubber washer. Take handle apart. remove clip holding rubber hose onto steam flange. Unloosen plastic steam flange and remove. Using a large pair of pliers or channel locks gently squeeze valve together. It will only move an eighth to a quarter inch. Dove several times until you can depress the pin by hand. Reassemble.
Jan 18, 2011 | Eureka 350A Handheld Steam Vacuum
Steam coming out handle instead of bottom
heatman101
Dec 11, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Steam coming out from handle not mop pad
Hose is off or broke at bottom of handle...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Aug 13, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My mop would produce steam. It gets hot but when
heatman101
xxxx
Jan 24, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Bissell Proheat Problem
Take the top part of the handle off, make sure that the rod in the handle is moving up and down when squeezing the trigger. The lower part of the handle has a valve that the handle rod pushes on, it make be stuck in the open position.
Jul 15, 2008 | Bissell 1699 ProHeat Clear View Upright...
When squeezing trigger and Depressing Clean surge Button on Upper handle of the Hooover Steam Cleaner F5914-900 there is no "snap" indicating trigger rod is in place. Everything else went in as...
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=552215
Generic problem for all Vacuums
Posted by lnikol6 on Apr 28, 2008
Hoover Steam Cleaner F5914-900
When squeezing trigger and Depressing Clean surge Button on Upper handle of the Hoover Steam Cleaner F5914-900 there is no & quot; snap& quot;
indicating trigger rod is in place. Everything else went in as instructed. The screws and bolts were no problem
this concerns me because the main complaint I read about this model was leaking from the trigger and clean surge and the problem was not getting the rod in place. No matter how many tries or people (three) it still doesn't occur.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
I would suggest getting a schematic, owners manual or product breakdown to see what you are doing wrong or to check with the Hoover tech support line to see if the can either mail, fax or email the schematic to you so that you can complete your service job. There is something definitely happening with the serv job that we are overlooking and the schematic or product breakdown will help in the serv job you are doing, it sounds to me that you are doing things right but there could be another broken part or while installing the current part may not have been install properly, or is in need of an adjustment. Feel free to contact your local vac dealer or contact the Hoover Tech Line listed below:
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Apr 28, 2008 | Vacuums
No steam coming out
The fall might have damaged or moved the trigger so that it does not depress the valve on boiler.
Try removing the screws which hold the handle together. The cap needs to be removed to allow the handle to separate.
Once the handle is apart check the trigger piece looking for any broken parts.
Jul 07, 2007 | Euro-Pro Shark SC-505 Handheld Steam...
Euro-Pro Shark SC-505 Handheld Steam Vacuum Logo
57 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
