Question about Maytag Washing Machines
My maytag w-11 will agitate only on the delicate setting. Is it the timer?
  • hasmodius Dec 15, 2008
    Quick answer. Thanks.
  • 750 Answers
Hello hasmodius
Welcome to Fixya
My name is Huum,
You said, Your Maytag w-11 will agitate only on the delicate setting. Is it the timer?
This sounds like you have come up with the correct diagnoses.
It sounds to like the timer is the problem, too!
Thank You For trusting us with your guestion
Please remember to leave a rating before you leave!
Posted on Dec 15, 2008
  • Neil Golan
    Neil Golan Dec 15, 2008
Maytag LAT8426AAM agitator only works in delicate cycle
Best guess is a timer contact problem, usually caused by advancing the timer by hand without pushing the dial in to stop the machine first.This causes burnt contacts.
Aug 27, 2017 | Maytag LAT2301AAE
My LAT9635AAE washer will only agitate on the delicate cycle. the timer goes thorugh the cycles on the other settings, but the agitatior will not move
You have a problem with the contacts in the timer and it will need to be replaced. Here is the part to order. To replace the timer remove the cover on the back of the console.
The part comes with a 365 day, any part, any reason return policy.
Nov 10, 2012 | Maytag Washing Machines
Maytag PAV2300AWW, ONLY WORKS ON REGULAR CYCLE. ON DELICATE CYCLE CLICKING NOISE LIKE SWITCH OFF AND ON AND AGITATOR WILL MOVE SLIGHTLY WHEN CLICKS. MY SON HAD IT ON A WHILE BACK ON THE DELICATE CYCLE AND...
Your timer is bad on that cycle. It is okay to use on regular cycle, but I would not use it on the delicate cycle, or will you burn up your timer. You should be home when using this, so if it does act up you can catch it.
Dec 01, 2009 | Maytag PAV2300 Top Load Washer
Maytag washer, lat9606aae only works in delicate cycle and hand washable
My girlfriend's LAT9704 had the EXACT same problem. I replaced the timer module an now it works in all cycles. Part wasn't cheap though - $80
Dec 18, 2007 | Washing Machines
Maytag performa
Sounds like you may have a bad timer. They can work perfectly in one setting, and not work at all on an other. They can sometimes get a "flat spot" in one area that will stop them from moving or working. Good Luck!!! Jim
Sep 08, 2007 | Maytag Performa PAV2200
Washing machine wont work on certain settings
the selector switch for loads is just a switch that connects parts of the timed cycle to the timer circuit. if the timer is not rotating then nothing will work. check the connections through the selector switch. burnt or melted contacts within the switch calls for a new switch. try repair clinic dot com for a replacement.
Apr 19, 2007 | Maytag Dependable Care LAT9706
Washing Machines Logo
87 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
