Question about Frigidaire 24 in. FDB126RB Built-in Dishwasher
Dishwasher pours water out of the grey line coiled on side of it
  • 334 Answers
Thats because its the drain line.
It's supposed to be installed into your homes drain system.
Thats usually done under the kitchen sink, hooked up to the dishwasher drain nipple on the garbage disposal or on the pipe coming off the bottom of the basket strainer.
Posted on Dec 15, 2008
Water will not flow into the G 650 SC dishwasher. Power comes on and the dishwasher hums away but there is no water getting in - Guess it's the Solenoid on the tap end of the hoes
Could be a loose connection on top of the solenoid or a faulty coil on the solenoid if it's humming it's probably a faulty coil, contact Miele at fern tree gully rd scores by they will be able to send out a new coil for you, you need to be aware there are two different sorts of coils they go by colour either grey or red.
I hope this helps
Mar 31, 2014 | Miele Dishwashers
Gsd2000j01ww leaving residue not draining properly
At the bottom of the dishwasher (older GE) you see a plastic cover with rounded corners and two 'grill' shaped sides. Remove the screws (1\4) and lift the cover. There might be a huge amount of grey clog and dirt stuck on the inside already. Remove it with a fork or long brush and rinse it. There is another grill in the water hole pull it out and clean it as necessary. You may also want to reach into and check the water hole for debris. If you are not comfortable doing so you can remove the water by pushing an old towel into the hole first. Once all parts are clean put them back in place and fix the cover with the screws. Pour 2-3 table spoons of bleach into the machine and let it run twice on heavy duty cycles.
Apr 10, 2012 | Dishwashers
I have sasui mobile type ari condition uni. there is a problem with water coming out from back side. water not going though drain line. cooling dosent have problem.
Check the elevation of your a/c unit. The elevation at the back should be lower than the front. Test by pouring water from the cooling coil and check if the water you pour goes to the condensate drain line. If water does not comes out, check if it has a small drain pump and a float switch to activate the drain pump. The float switch that does not actuate if water level rises may be the reason why water does not comes out of the drain line.
Sep 09, 2011 | Heating & Cooling
Water wont drain every time
Hello
When a dishwasher won't drain, that usually means that the appliance's drain line is clogged. The drain line, which connects the dishwasher to the garbage disposal, must be cleared of debris before the dishwasher will resume its normal operation. If the drain line is the problem, clearing it is simple and requires only a few standard household products.
Turn off the power to the dishwasher, if possible. Remove all the dishes and the racks. Put on a pair of rubber gloves and use towels to soak up most of the standing water in the bottom of the dishwasher.
Unscrew the rotating sprayer arm in the bottom of the dishwasher. Rinse off the arm and all its seals and screws in the sink and set it aside.
Locate the filter screen in the back of the dishwasher's floor. Pop off the screen, using a screwdriver to loosen any bolts that may be holding it in place. Rinse off the screen, then wipe the dishwasher floor with paper towels to remove any large pieces of food or other debris. Wipe the area clean with a damp sponge.
Replace the screen and the sprayer arm. Locate the drain line; it should be near the back of the floor of the dishwasher, right underneath the filter screen. Pour 1/2 cup baking soda into a cup and add enough water to make it into a pourable paste. Pour the paste into the drain line through the screen. Add 1/2 cup vinegar to the drain line and let the solution fizz for 15 minutes.
Boil a quart of water. Remove the pot from the heat, allow the bubbling to subside and pour the water into the drain line to clear the baking soda solution. Watch the water go down the tube; if it seems to be draining slowly or not at all, repeat the baking soda treatment.
Replace the racks and make sure that everything is put back together properly. Turn the power back on and run the empty dishwasher through one normal cycle to see if the drainage problem is fixed. If not, repeat the process a few more times. If the issue still isn't resolved, the problem may be with the pump or another electronic part. A professional is best suited to deal with an issue like that.
Sep 07, 2011 | Dishwashers
GSD2000J01ww dishwasher leaves heavy residue on dishes
Aug 24, 2011 | GE GSD2000J Dishwasher
The water wont drain from our whirlpool slimline, and the tablet will not come out and wash the dishes
Hello
Aug 09, 2011 | Dishwashers
Water continually pours out of right side bottom
water continually pours out right side lower vent.dishwasher won't do anything else. no display lights on console.
May 05, 2010 | Viking DFUD042P Built-in Dishwasher
Water keeps pouring out from left side inside dishmachine will not stop pouring out even in off position flooded kitchen and basement awith water.
You have a leak in the water feed to the dishwasher or in the soleniod fill valve..
Here is a tip that I wrote about leaking dishwashers...
http://www.fixya.com/support/r4546178-leaking_dishwasher
heatman101
Apr 15, 2010 | GE Nautilus 24" Built-in Dishwasher
No water from water dispenser
I have a GE GSH22JFTA side by side and my water dispenser just stopped working after about a year. The selenoid for the pump is buzzing, and when I disconenct the water line at the bottom on the freezer door, it water dispenses fine. the water is freezing IN the freezer door. I got some plastic sheathing and duct tape and opened my freezer door and sealed the freezer compartment so the food would not defrost and left door open to thaw out. in about 2 hours, voila.. my dispenser was working again. I suspect I'm not the only one with this issue.
Mar 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Preventive maintenance?
You should buy some c.l.r. (calcium,lime,rust) remover.It's packaged in a grey bottle at any supermarket,drug store,ect.Pour a cup in and run a cycle once a month.This will prevent any lime build up from scaling the dishwasher due to hard water.
Mar 19, 2009 | Dishwashers
Frigidaire 24 in. FDB126RB Built-in Dishwasher Logo
126 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
