Question about Samsung HLP4663W 46" Rear Projection HDTV
Samsung DLP coloring issue after color wheel replacement. Colors pulse and change constantly. I adjusted the cca values to those that are on the sticker, but the problem continues.
  • 76 Answers
Sounds like a warped or damaged color wheel. See the pictures here.
http://guides.fixyourdlp.com/samsung/bp96-01579a.php
Posted on Jul 16, 2009
I replaced my Samsung hln567wx color weheel about a year ago due to the tv making an odd sound. Changing the color wheel did fix the sound but after a year has past the picture is replacing all red with...
Tv have colors flashes back and forth some time u get a normal pictures again?Yes,u must take the tv aparts than check the colors wheel again.Check it out it condition only don't touch the colors wheel itself.U have compression air machine blow some light compression air into tv colors wheel it self might have acumalate dust on the wheel,don't solved the problems.Might have to change the colors wheel again.
Aug 27, 2011 | Samsung DLP HL-P5663W 56" TV
Samsung HLP4663w. After replacing the Ballast, Bulb and Color Wheel (color wheel came without the CCA values and the Actuator and Index delay values) we still have the same color and picture problems. Do...
if the picture is blue green there is a jumper to be removed on the dmd board on connector cn810--the index delay should be between 40 and 50 for optimum color --or adjusted for best flesh tone also in the options the cw setting should be set for cw2
Feb 06, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung DLP HLP-4663WX/XAA. Colors green after wheel replacement.
I have Samsung DLP HLP-5063WX/XAA. I have the same problem. I did change another color wheel, but not any help. Please help! I appreciate
Sep 10, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Changed samsung hlp6163 colorwheel now all the colors are off alot of blue
There is a place for a jumper on your DMD (the module that the color wheel plugs in to) If the jumper is there remove it. If there is no jumper install one. On later models the pins are gone but solder pads are still there, solder it. Some wheels have air bearing and others have fluid bearing. You really should buy a service manual for that set. New color wheels sometimes come with CCA values that you must change in the service menu
Good Luck
Dec 17, 2008 | Samsung DLP HL-P5663W 56" TV
Need to fix CCA Values for my Samsung DLP HLP50563W, got a new color wheel
The new color wheel should have come with a sticker that has a table on it with a bunch of numbers filled in. I think you enter these numbers into the TVs maintenance mode: using the remote with the TV turned off, press
mute 1 8 2 power
The TV powers up and you will see a menu on the left side of the screen. I don't know the exact procedure, but look for something called CCA and then enter the numbers from the sticker.
I just replaced my color wheel and it came with the sticker, but I did not know what it was for. I lost the sticker (probably got thrown out with the packaging). Now must buy a new color wheel and take better care of the sticker.
Oct 17, 2008 | Televison & Video
Samsung Color Wheel
Here's a good article on the Color Wheel
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
It says if your red and blue colors are reversed removing the jumper should fix the issue.
Aug 27, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung hlp4663wx/xaa (after replacing the color wheel)shadowing
If the color wheel you replaced was the BP96-00674A, it would have come with the proper cca adjustments for that particular wheel. You must enter the service menu and reset the cca's for proper color.
Feb 20, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP4663W 46" Rear Projection HDTV Logo
110 people viewed this question
Jerry Greenberg
Jerry Greenberg
