Question about Avanti BD6000 Stainless Steel
Avanti bd6000 my kegerator will only cool to 63 degrees. i have made sure there is plenty of clearence for air circulation, adjusted the thermostat, but it won't cool to below 63 degrees......help!!!!
Did you ever find an answer? I have the same problem.
Posted on Feb 23, 2010
  • MartinB28 Feb 23, 2010
    Did you ever find a solution to this problem? I am dealing with the same thing.
I have 1f86-344 White & Rodgers thermostat that both the heat set temp and the actual room temp read 63 degrees it is actually 69 degrees on 4 therms at same location. Is there a charge for answer?
download the manual. step 6 will let you calibrate the tstat up or down 4 degrees max. does get you closer, be sure to seal hole in wall where wire comes through. possibly use air duster on tstat internal parts.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Apr 09, 2018 | Heating & Cooling
I have a carrier furnace and it seems to be only blowing out lukewarm or cold air and my house only gets up to 63 degrees
Make sure your filter is clean and that your heat registers are open and the cold air return is not blocked. So if you turn your thermostat up to 70 degrees is the burner shutting off before the house gets up to temp? If the thermostat has batteries are they new? Out side of that you may need a service tech.
Jan 01, 2018 | Carrier Heating & Cooling
How do i adjust AC temperature variance on a Honeywell TH5220D1003 thermostat
If you are talking about the difference between heating mode and cooling mode and the room setpoint, you can not change it. It comes from the factory with a 3 degree difference. In other words if you raise the heat setpoint until it is within 3 degrees of the cooling setpoint, for every degree you raise the heat setpoint the cooling will raise a degree.
About all you can do is increase the distance between the heat and cooling setpoint. To do this either lower the cooling setpoint to 3 degrees higher than the heat setpoint you want and then increase the cooling setpoint the desired setting. For example heat and cool setpoints are 67 and 70 respectively, and you want 65 and 73. Lower the cooling setpoint to 68 and then raise the cooling setpoint to 73. Now your heating will come on 3 degress lower than 68, the 65 you wanted and cooling will come on at 73. Remember, the thermostat new setpoints will turn on the cooling at 75 and turn back off at 73 and heat will turn on at 63 and turn off at 65.
You can perform the same using the heating setpoint, just have to look at it backwards. If you need to lower the difference I recommend a 8000 series thermostat. They are the most functional thermostat that Honeywell makes, be in mind they are about 3 times more expensive and many of the setting require a well trained tech to interpret and set properly.
Hope this helps.
Aug 24, 2014 | Honeywell Th5220d1003 Non-programmable...
Over heating and sputtering
kohler engine air cool they will over heat if fuel system lean carburetor clogged out of adjustment causing lean fuel mixture,air cool engine need plenty air to keep cool, make sure air filter clean and make sure cooling fins not clogged with debris make sure shrouds and blower housing are tight so air can circulate. air cooling engines kinda remind you of 1963 corvairs
Sep 09, 2012 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Refrigerator temperature won't cool items lower than 41 degrees.I assume this is caused by a faulty thermostat.It is a Maytag Plus model MTB2156AE.
Not necessarily the themostat. It could be the internal fan that circulates the air from freezer to fridge or you have ice blocking the air flow.
Sep 13, 2011 | Maytag Refrigerators
Refrigerator cools, but not cool enough, even with temp adjustment turned to coldest setting. Freezer only gets down to 0. Fridge at 44 degrees
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 06, 2009 | Refrigerators
MSD2454GR Side by Side refrigerator- freezer side fine, refrigerator side will not cool below 50 degrees; lots of condensation
Jul 01, 2009 | Maytag MSD2454G Side by Side Refrigerator
Avanti BD6000 Stainless Steel Logo
347 people viewed this question
Top Avanti Refrigerators Experts
Marvin
Marvin
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
