Question about RCA P61960 61" Rear Projection Television
TV has a mind of its own
Television will not turn on automatically using the remote or manually(pushing power button on tv). It takes a couple of trys to get it on and once it is on the menu screen automatically pops up in spanish and it will not go away. It's like the tv has a mind of its own. I manually press the buttons on the tv and it does not do the function I selected. For example, if I press the volume button the channel will turn and if I press the power button (to turn it off) the menu screen will come up or some red numbers and letters that read: P O 1.2 V O Any advice?
  • tank1222 Dec 05, 2007
    I have the same thing as the above,it is just the same thing.I cannot use the remote,so I bought a new remote. It worked once and then it would not work any longer. To turn it on manually you must first hit menu on the front panel then on or off,the same to turn it off. The same code shows on the screen as the above after being on for a while. garykindell@comcast.net
  • 61 Answers
The front panel buttons are your trouble,you can disconnect these,first unplug the unit and remove the back cover,just below the top screws you can look under and see the top of the pictures tubes,in front of the middle tube is a small board,unplug the top right cable,this will disconnect the front buttons and you can use your remote to control the set,hope this helps
Posted on Mar 07, 2008
I have a 32 in trutech monted to the wall. Lost the remote and don't know how to turn it on.
Turn on the tv by pushing the manual button,power on manual button like to the right or left sides of the tv manual power on button.Or try website like Remote.com to buy a replacement of an original remote.
Mar 21, 2011 | TruTech PLV16190 Television
My tv is block and i dont know wat to do. how can i unblock it?
Don't use the remote control the signal it block.Go to ur manual contol on the tv right side.Push the power button to turn tv on.Push button Menu now U in the tv Menu,Use the volume + or - button move the Menu function to OPTION,now use the Channel + or - go down to the word said Operation lock out(ON) Now push manual contol button said INPUT.Now the word said Operation lock out(OFF).Now remote control is relase,u can use the remote control now.Tell me this work ok.This is how i unlock the Sharp Aquos tv.
May 09, 2010 | Hisense TL1700 17 in. LCD Television
Ihave jumbo Brookstone remote but changed batteries and l
Try this, just be patient as it might take a couple of minutes to program.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Aug 07, 2009 | Brookstone 538744 Remote Control
Remote won't work and power switch pushed inside the television
No, sorry, not from this distance. But if I were actually there, I would try to put the switch back where it belonged, IF it was not broken!
May 15, 2017 | Sharp 25N-S100 25" TV
Hello,I need codes to the remote!
Instructions on how to use the CODE SEARCH button:
In this example we will say we are setting up the TV button for our television set.
1. Manually turn the power to your television set ON.
2. Hold down the Code Search button on the remote for 2 or 3 seconds until the light on the remote stays on (aka stays solid).
3. Push the TV button on the remote.
4. Point the remote at your television and slowly press POWER until the television turns OFF.
5. Press the ENT button on the remote. (It is under the number 7 button.)
or for your actual codes, go to:
PHDVD5 CODES
http://www.replacementremotes.com/store/productdetailp.cfm?productid=6113
Jan 29, 2009 | Philips PH-DVD5 Remote Control
Dish network remote code for Disney 13" TV
On your dish remote, press and hold the tv button until all 4 buttons light up, then release. push either of the power buttons once. Now start pushing the down channel button, It's the one right below select, continue pushing it until tv turns off. When tv goes off push down button one more time then push up button, when tv turns back on stop and press # key, tv light will flash 3 times and should be set. Note....if u press down button and tv does not turn off after going through all codes( tv light will start flashing) press cancel and try again only channel up this time. hope this helps.
Dec 31, 2008 | Disney 13" TV
Codes to program the RCA Universal remote control for a Magivox T.V.
My dear friend if your remote control got the code search button try with this.
Push and hold code search button until the led stand lit,now release him push and release the tv button the you need to push and release the power button until the tv set turns off push and release the button set and the code get in the memory of the remote.
You need to turn the tv manually.
Good luck
Sep 13, 2008 | Televison & Video
1lo-26hd tv
Try to buy a universal remote control. I reccomend a philips.
Feb 19, 2008 | iLO V27DMBX Television
Sony KV-32FS200
I read the manual and it says in the FAQ.
Q- TV doesn’t turn on
after disconnecting
the TV and timer
LED flashes
❏ Press the POWER button on your remote control or in the TV front
panel, one more time.
Tell me if it works...
Oct 09, 2007 | Sony FD Trinitron WEGA KV-32FS200 32" TV
RCA P61960 61" Rear Projection Television Logo
131 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
