Question about Off The Wall Heating & Cooling
Wall heater is on then loud noise and flames comes out the side
I have a dual wall heater. When the heater is on it makes a loud noise and flames come out of the side and a funny smell. The heater never goes out it just makes this noise
  • 108 Answers
You have a fire hazard here! Do NOT use the device until it has been checked by a technician! There is no way I can diagnose this problem on line. You don't need a fire just before Christmas, and thats what will happen!
Ray
Posted on Dec 15, 2008
  • 3,037 Answers
What kind of wall heater do you have and what color is this flame shooting out?
    President:
  • 2,110 Answers
A repairman needs to sit in front of the unit & watch it make the noise (Ball of fire). Then it can be fixed. Sounds like delayed ignition to me. That only takes a minor adjustment to fix. BUT, it will sound bad & scare small children & animals until fixed. I am assuming it only does the "noise", every once in awhile. Until a repair guy can see the furnace act up, he can not fix it. Does this help?
    Genius:
  • 1,199 Answers
Turn off the heater at once and turn off gas flow to the unit! this sounds like a valve has been damaged and is spraying gas into the sides of unit!
Cozy dual wall heater, makes loud noise and shakes heart when it starts
check gas pressure, natural gas 3.5 and propane 11, also if you have stainless steel burners drill out the first series of holes on the carry over tube to match other holes use 1/64 drill bit.
Feb 27, 2015 | Cozy Heating & Cooling
Flame effect electric fire loud clicking noise
You need a new synchronous motor. This is the small motor which turns the flame effect rod. They are notorious for becoming noisy.
Nov 06, 2012 | ACE Dimplex (r) Compact Electric Fireplace...
I have an older Coleman in wall propane furnace, Model 2343.
compressed air or take apart and blow out also check gas pressure
Jun 28, 2012 | Coleman Propane Forced Air Heater...
When gas wall heater lights a ball of flame comes
Lets get a tech in there to get it cleaned and the gas pressure checked.
Jan 18, 2010 | Off The Wall Heating & Cooling
Heard popping noise and circuit to stove blew. could not set time or oven temp when reset breaker
Hi
Sounds like your oven heater failed. Not sure if its a fan oven or static type. If you hear a fan inside the oven then its classed as a fan oven
Nov 16, 2009 | Frigidaire PLCS389DC Dual Fuel (Electric...
Refrigerator
the fan behind the ice maker is iced up poss fault defrost heater gone try total defrost faor a list 36 hrs restart it noise come back then you need to repace the defrost heater hope this helps
Nov 13, 2008 | Samsung RS2630SH Side by Side Refrigerator
Loud Knocking
If the noise is not coming from the fan as Buffalo suggests, it is most likely the expansion and contraction of the heat exchanger. The old school way to lessen the noise of expansion is to bank the combustion chamber with a hammer. I don't recommend it today because the metal is so thin (thus all the noise) and you may damage it. You will get used to it and the noise may soften the more it is used. You will never get it to stop.
Dec 04, 2007 | Williams 3003622 Ceramic Wall Mounted...
Toyostove Laser 56 (F type) making loud humming noise
the toyostove is basically a glorified monitor heater.  its components are a combustion blower, an air circulator fan, a flame pot, a flat wick or burner mat, a solenoid pump, an ignition element, double  walled intake, exhaust pipe.   the combustion blower is a glorified vacuum cleaner motor. it sucks in cool air and channels it to the combustion chamber along the sides (round cylinder) kero enters on the burner mat where it ignites. the solenoid pump keeps adding kero until the flame detector spots or heats up. air flow to the pot is regulated by a damper in the combustion air blower line. if the "O" ring in the damper is missing or hardened it will not regulate the air flow which is necessary for combustion.  replace this "O" ring should take care of your problem.
Oct 17, 2007 | Rinnai Toyostove Direct Vent Heater:...
Heating & Cooling Logo
85 people viewed this question
Top Off The Wall Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
Are you an Off The Wall Heating and Cooling Expert? Answer questions, earn points and help others
