Question about Kenmore Elite 45986 Front Load Washer
Reply Great, thank you very much. Do you have a link or recommendation where to purchase a new Door Lock Assembly? Regards
  • 1 more comment
  • psgolfer70 Dec 15, 2008
    Thanks for all your help, if you need any audio video advice, let me know.
    What I would do first is to check the wiring and ensure that maybe something hasn't clipped it. Do you have a tester for line voltage or continuity?
    You may have received a faulty pair of speakers too. Try hooking them up to a shelf stereo system and see if they crackle or pop.
    My guess is that it's something with the wiring if you have tried another pair and still have the same crackling issue.
    Lastly, to get you by for now, turn your fader to your rears and don't use the fronts till you have diognose what exactly the problem is.
    Good luck
  • psgolfer70 Dec 16, 2008
    I can't think of anything else other than trying another pair of speakers for your car and try a bench test with your existing speakers to try and determine if it's speakers/wriing/or deck/.
    Good luck.
    Also, everything seems fine with our washer. I did a reset on it yesterday (just left unplugged for 1/2 hour) and manually released the door. Now it works like a charm. There was a brief hickup with 5 mins left in the cycle, error code f11, just hit cancel and resume, wash finished fine.
    Tell me, the washer we have is the Kenmore Elite Front loader model on the recipt is 45862, is that basically the same as what we have been discussing?
    Cheers
  • 5,911 Answers
Check with the following web sources:
searspartsdirect.com
repairclinic.com
pcappliancerepair.com
appliancepartspros.com
All offer great service and competitive pricing. I hope this helps you.
Posted on Dec 15, 2008
  • Jeff Rockwell
    Jeff Rockwell Dec 15, 2008
    Glad I could help you. Keep me in mind for any future problems you may have. I'm familiar with your washer model as I have worked on it numerous, numerous times and I personally own one.
    It's funny that you are offering audio advice, because I am having a problem with some stereo speakers in my car. I have a factory installed stereo in my Hyundai Santa Fe. The front two door speakers make a cracking and popping noise (especially with the base turned up). I tried replacing the speakers (thinking they had gone bad), but the problem continued with the new ones. Is this a simple grounding issue? Or, do I have something going on internally with the stereo? I'm stumped. Can you provide me with an assist?
  • Jeff Rockwell
    Yes, I have a multimeter to do continuity checks with. I have already set the fade to the rear speakers for the time being. I was hoping to avoid tearing the dash apart to trace the wires, but it looks like I may have to in order to determine if I have any wire chaffing anywhere. Thank you for your reply.
What does the F93 code mean and how do we fixt it
i know that it can be very difficult to have issues with your oven. the f93 on this model of kenmore range indicates that you have a problem with the oven door lock assembly (see image below). this can be caused by a failed oven door lock assembly, a wiring failure or a bad electronic oven control board.
i recommend that you unplug the range and check the wiring between the components first. you can remove the upper back panel of the range to access the electronic oven control board in the console. you may need to remove the lower panel to access the door lock assembly on the back of the range. the image below shows the wiring diagram and other information that should help you check the wiring connections. check for a mechanical binding of the door lock assembly as well. if the wiring connections are okay, you will likely need to replace the oven door lock assembly. if you need further assistance, please reply to this thread. thank you for using manage my life.
May 23, 2015 | Kenmore Elite 30" Slide-In Gas Range White
My control light blinks and beeps when pushing the start button. I have already replaced the door lock and switch assembly. Door lock light does not illuminate at any time.
Hello friend, thank you for your post!
Based off the information you have provided it sounds like it could be a possible issue within the control panel of your Frigidaire washer. I understand that you have replaced your door lock and switch assembly but it could also be an issue with the keypad of your appliance. I would recommend having a professional come out to properly diagnose your appliance to avoid unnecessary part purchases. I hope this is helpful. - Matt
Aug 21, 2014 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
PAU error code comes on when iI test it it shows e41 door lock
Hello, welcome to FixYa
Based on the info you provided, specifically the E41 error, It sounds like the unit is detecting an unlocked door, loose wire, or the control itself is bad. (E41= Shorted or open. Defective door lock assembly.Around 1500Ohms. Defective control board.)
The PAU simply indicates the control thinks it has been paused...that may be just a side affect of the door lock assembly.
Here's how to check...
**Unplug the unit from the wall first...safety first**
Remove the door lock assembly and measure the resistance of the PTC. Should get a reading of around 1500ohms.
Attached here is a great tutorial for accessing the assembly for testing and replacing.
http://www.repairclinic.com/PartDetail/Door-Switch-Assembly/131763202/1531974
Let me know if you need further assistance going forward or if anything is not clear.
Thank's again for visiting FixYa today. Good luck.
Regards,
Macmarkus :)
Jun 16, 2011 | Frigidaire Affinity ATF7000ES Front Load...
I have a Affinity frigidaire front load washer and need to replace part number 131763202. The model number of the washer is ATF6000FS1 Thank you in advance
Disconnect power then open the door and remove the spring-hoop assembly that secures the door gasket. Peel off the part of the door gasket near the door lock and switch assembly. Remove the screws securing the door lock and switch assembly to the front panel then pull the door lock and switch assembly out. Transfer the wires to the new door lock and switch assembly then install into place. Put the door gasket back and secure it with the spring-hoop assembly. Click on the link below for the detailed procedure.
Replacing the Door Lock and Switch Assembly on Frigidaire Affinity and Gallery Front-Load Washing Machine
Nov 12, 2010 | Frigidaire ATF6000ES Front Load Washer
My machine wont start ,unless i really have to slam the door real
Either the switch striker/actuator on the door is worn or the door lock/switch assembly on the right side of the door opening is faulty. It is recommended to replace both parts when one is faulty or worn. The door lock/switch assembly is part number 1094190 and costs about $55. The switch striker/actuator is part number 906446 and costs about $5.
Door Lock/Switch Replacement Procedure
  • Unplug the machine.
  • Open the machine's door.
  • Locate the retainer spring of the seal boot retaining hoop at the bottom of the door opening.
  • Stretch the retainer spring apart then remove the retaining hoop.
  • Ease the edge of the seal boot off the lip of the door opening near the door lock/switch assembly. Remove enough of the seal boot to gain access to the door lock/switch assembly behind the front panel of the washer. Be careful not to tear the seal boot. It will cause water to leak out of the machine.
  • Remove the three screws securing the door lock/switch assembly to the front panel.
  • Slightly lift the door lock/switch assembly, pull it away from the front panel then pull it out of the machine.
  • Disconnect the wiring harness and connect the new door lock/switch assembly.
  • Reinstall the new door lock/switch assembly and the seal boot in reverse order of the procedure above.
Jan 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I cannot open the door after the finish of the
Hi There
I have found this for you to read.let me how it goes. Hope this was helpful.
F/dL Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you for writing to fix ya.
Best Regards Richard
Dec 29, 2009 | Washing Machines
Front loader door unlocks during cycles with door lock light on.
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 15, 2009 | Kenmore Washing Machines
My washing machine fuse blew. when i put new one in it came on but door lock will not activate and machine beeps. door interlock looks damaged, will a new one solve the problem?
Without testing the lock first - it's a cr@pshoot.
May 05, 2009 | Washing Machines
Self-Cleaning Failuare on Kenmore Electric Range
It appears your timer/main controller/CCU CLOCK has failed in this instance.
Aug 07, 2008 | Kenmore 91112 / 91114 / 91117 Electric...
Kenmore Elite 45986 Front Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
