Sanyo Ds25330 w/intermittent sound
Picture has been fine, surround sound works fine, it is louder in DVD than TV/VCR mode but regular TV sound is intermittent. I have tried compressed air, taking the back of checking connections to the speaker...i know nothing when it comes to tearin' into diodes & transitors. i need diagrams for that.
  • Televison & ... Master
  • 2,778 Answers
Try replacing the main board
Posted on Jan 07, 2018
  • 236 Answers
SOURCE: TV picture flickers
If your DVD player is separate from your tv, you might have a loose cable plug or connection. Depending on the type of flicker you have, a vertical circuit loose connection would cause this. If you could connect it to a cable or antenna it might tell you where the problem is located. A faulty circuit in the DVD might cause this too. Stargazer
Posted on Mar 03, 2007
snakehead
  • 1074 Answers
SOURCE: Sanyo DS27880 27" TV, Dish signal lost after tv turned off, doesn't return
checks should on your tv tuner it could be bad.IF circuit should also be check and the video section call in the tech to make checks on your tv.and to do repairs on your tv.
Posted on Apr 12, 2007
SOURCE: my sanyo tv has no picture no sound 31"color tv
my grand son unplugged my sanyo tv 32in from wall while on no wi have no picture and no sound
Posted on Aug 05, 2009
johnnydiode
  • 647 Answers
SOURCE: TV will not stay on
when you turn the TV off do you see abreif white line acroos the screen and do you feel the static on the fornt of the set when it comes on? If so
This is an easy repair if you've ever soldered and would not be too costly for a repair shop to do it for you. The problem is a bad Vertical Output IC (usually mounted on an aluminum heat sink with the part on it labeled LA78?? ) and 1 or 2 bad capacitors. Some times you can even fix the problem by re-soldering the contacts of the IC- To find the IC follow the 4 wires that come from the Yoke (which is a contained coil of wires slipped over the neck of the picture tube(s)) back to the board. 2 of the wires go to the horizontal o/p and 2 to the Vertical o/p the thinner gauge wires are for the vertical.
Posted on Sep 30, 2009
SOURCE: TV stuck on Video
I had this problem, I replaced the remote and it works now
Posted on Nov 03, 2009
RCA model rtd3266
Quick and dirty:
From the back of the RCA unit make sure you are using the auxiliary input jacks to connect to the output jacks on the TV.
You will need to go into the setup menu on your TV to select an external sound system and finally you'll need to select auxiliary on the RCA unit to hear the sound from your TV.
Hope this helps,
The Tinker
Nov 30, 2013 | RCA Televison & Video
The sound does not work on my 50H81 Toshiba rear projection HDTV, when it's in the HD mode. It was working prior to being moved & was hooked up through a Bose surround system. The sound on the TV works...
Check to see if the comp inputs have a red and black audio input. Those must be connected, second go inside the menu and make sure the inputs match..good luck..
Mar 09, 2009 | Toshiba 50H81 50" Rear Projection...
No 5.1 surround when adding a Philips upconvert player to the San
Sounds like you are getting analog signals from your componet cables and a true digital input from your HDMI into your tv.
However that unit is Analog audio input x 1 only.
So i dont think your going to get true digital surround sound.
The problem being
Sanyo =
Inputs: Analog Audio x 1 Outputs: Composite x 1 · S-Video x 1 · Component x 1 · Digital Audio Coaxial x
Feb 03, 2009 | Sanyo DWM-2500 System
Surround Sound Not Playing For TV Programs
Greetings jdm12,
I can understand your problem, I have some what of the same issues with my home theater setup when watching events. One of the only suggestions I can make is adjusting the "Dolby Pro Logic II Mode". After reviewing your owners manual it appears you should be able to change the mode by pressing the PL II Mode button found in the lower keypad on your remote. It appears the options you should have are Music - Cinema - Pro Logic - Matrix - Stereo. You may want to try Music or Stereo when watching your events. In Stereo setting it should provide sound out of the front speakers and sub-woofer only. In Music, there are more processing that is done so you could hear more then just the front speakers.
I hope this makes your next your next PPV Party a big hit!
Jon
Go Ahead. Use Us.
Jun 17, 2008 | Samsung 1200W 5.1-Ch. XM-Ready Home...
NO sound and cable signals
Looks like someone sold you a unit only partially working.
You may need to have the main board replaced, which is likely why the previous owner sold it.
My solution would be: Buy an inexpensive surround system and a VCR, Use the VCR as your tuner, and plug the audio output from the VCR into your surround system.
This way you will have a tuner (the VCR), and sound through the surround amplifier. You can also plug the audio output from your DVD player direct into the surround amplifier. This solution would likely run you less than half the cost of replacing the main board in the TV.
May 07, 2008 | Akai LCT2060 Television
DVD/VCR connect to TV sound but no picture
I am sorry to say that this does not sound like a simple solution for your problem. It is hard to be sure without examining the situation but, If the video comes on breifly and, then goes away it sounds like something is heating up and, then opening up and, disrupting your video. It could be something in the stabilization. You will need to refer this problem to a qualified repair technician. If you want to keep the TV and, since it does work in TV mode I would suggest that if you want to use the RCA type jacks to connect a VCR/DVD or what have you that you get an RF modulator to connect thru the co-ax. This way you can connect your Cable/satelite to the co-ax connector and, your VCR/DVD player to the RCA on the Modulator. These are availible at radio shack and can also be found on ebay. I hope this helps at all. don359@verizon.net
Apr 06, 2008 | Symphonic WF20D4 TV
Dvd player
you must eject the tape in order for the disc player to work
Mar 30, 2008 | Sanyo DVW-7200 DVD/VCR
Surround sound hook up
av/out on tv to av/in on vcr / av/out on vcr to av/in on home theater pls rank
Jan 23, 2008 | Televison & Video
No video in VCR mode
Could be dirty video heads. Try a cleaner....accordianman....
Jan 15, 2008 | Sanyo DVW-7200 DVD/VCR
No picture
Tvs usualy have a few ways to hook them up. One is a coax cable this is the silver one in the back that you screw in a cable. The second are RCA cables these are the ones that are yellow, red and white. Yellow is always the video and white and red are for audio. If your using the coax cable your tv needs to be on channel 3 or 4 you may have to force the tv to go to that channel by pushing 03 on the remote. If you are using the Rca cables then you need to change the tv to "video 1" or "video 2" this changes the tv from tunner mode to aux input mode. Most DVD players dont have a coax out so you have to use the rca plugs. Some tvs have the rca plugs on the front (video 2) and the back (video 1) or line in. Some tvs have line out also so you need to figure out wich way you have it hooked up. Do a search for the model of your tv and it should show a diagram on how to hook it up.
Apr 07, 2006 | Emerson EWD2003 DVD Player/VCR
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
