Question about Sharp AR-5320 Black and White Copier
SHARP AR5320 error F5-02
Copy lamp ok; cable/connector ok ; i am just change the mainboard with the new one.
  • thaungmt Feb 03, 2009
    F5-02 in new AR5316-E.
    Problem Solver:
SHARP AR 5020 error F5-02 pls canu give some tips very helpful its urgent sir
Posted on May 30, 2009
    President:
  • Sharp Master
  • 990 Answers
Try to reset, press"#","interrupt","c","interrupt' enter14 press start.
Posted on Dec 15, 2008
  • Everett Lin Dec 21, 2008
    Hello Sir; Your copier trouble has been taking care? I really concern about that, please let me know, If you need more help let me know I'm always around, good luck! and don't forget give me a good rating, THANK YOU !
ERROR CODEE7-10
E7-10 Shading trouble (Black correction)
The CCD black scan level is abnormal when shading. Improper connection of the CCD unit flat cable CCD unit abnormality MCU PWB abnormality. http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Sharp&model=AR5320
upon on extra research I've found that this problem was once solved by tightening any loose panels and screws...
Thread Sharp ar5320 error code e7
Sep 23, 2015 | Sharp AR-5320 Black and White Copier
Auto iris error what can be done no display out
open the cover , unplug the flexible cables and other cable connectors, open the mainboard, remove the IRIS motor unit, clean the gear after that put in super lube into the gear.then plug it in again. if the same problem replace the IRIS motors.
be sure to change the lamp.
Good luck, thanks
Sep 08, 2013 | Epson VS200 Multimedia LCD Projector...
IBrand new machine error f5-02 change ribben cables, ccd, lamp
copy lamp lighting abnormally. Change copy lamp
Mar 16, 2011 | Sharp AR-M205 Copier
Arm 205 display error F5 02 what this the solution for resetting ???/
the error F5 02 means that the copy lamp lighting is abnormal.
This is what is in the service manual:
F5 02 Content Copy lamp lighting abnormality
Details The copy lamp does not light up.
Cause Copy lamp error
Copy lamp harness abnormality
CCD PWB harness abnormality
Check and remedy
Check the copy lamp (SIM 5-3)
When the lamp lights:
Check the harnesses and connectors
between the CCD unit and the MCU PWB.
When the lamp does not light:
Check the harness and connector
between the copy lamp and the MCU PWB.
Replace the copy lamp unit.
Replace the MCU PWB.
Remarks Copy lamp disconnection
Cable is not attached.
You must call a tech to solv your problem.
Dec 01, 2010 | Sharp AR 201 Copier
My sharp ar5320 has an error code blinking it flashes h 4 what would i do?
On your keypad press in order # * C * .That will put the machine in diagnostics. Then enter 14 like you were making 14 copies. then press 1, then start, that will reset the machine.
Aug 09, 2010 | Sharp AR-5320 Black and White Copier
I have problem in Sharp AR-M205,and i don't know how to fix, error code F5
F5 00 Content Copy lamp lighting error Detail Copy lamp does not light despite the output of lighting signal. Copy lamp lights without the output of lighting signal. Cause DC power supply defective Control PWB defective Copy lamp defective Improper connection of harness between PCU PWB, DC power supply unit and copy lamp unit Check and remedy Check copy lamp for lighting with SIM5-3. Check harnesses and connectors between PCU PWB, DC power supply and copy lamp unit
Jan 12, 2010 | Sharp AR-M205 Copier
you reset your eror code program c#0#
May 30, 2009 | Sharp AR-5320 Black and White Copier
Sharp ar5320 copier
H2 on a Sharp machine is the fusing unit is not heating up. This could be the heating lamp. therimstor, thermal fuse of fuser control.
If you are so inclined, you could test the lamp, and fuse for continuity.
Hope this is of some help.
Ed
May 19, 2009 | Sharp AR-5320 Black and White Copier
Driver update problem.
first unistall all sharp ar5320 drivers from computer , restart computer and unplug printer cable then install printer driver( AR5320) after finiishing all then plug printer cable and power on 5320 machine
Nov 03, 2008 | Sharp AR-5320 Black and White Copier
Sharp ar5320 developer reset code
The developer doesn't have a reset code.  It uses a calibration program instead with the reset integrated into it.
Even though the copy quality is fine for now, it can change in the next few days.  You should order some developer.
Sep 16, 2008 | Office Equipment & Supplies
Sharp AR-5320 Black and White Copier Logo
1,029 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
