Question about Dell Inspiron 8200 Notebook
I have a Dell Inspiron 8200 laptop that won?t boot. The battery is dead (the latch broke shortly after I bought it), and it is plugged into the wall using the original power cord. There are three indicator lights ? the circle power light, a cylinder, and a battery. When I press and hold the power button, the power and cylinder lights light up (green) and there is a whirring sound. Also, the number and caps lock indicator lights flash green once. When the whirring sound shuts off (after a few seconds), the battery light blinks green, then orange (alternating). The visible fans in the back do not turn on. The green lights stay on and the battery light continues to blink green and orange, but nothing comes up on the screen. I have tried vacuuming the vents, unplugging to make it think there was a power outage, and reseating the memory. I bought a new laptop a few months ago, and kept putting off transferring my data because the old laptop was so finicky (this has happened for a while, but I usually get it to turn on after 10-20 tries). All I need off the old laptop is my address book and a TON of pictures of my kids (they are 4 and 2 and I don?t back up as often as I should). I recently moved to a small town, and I don?t know of anywhere I could take the laptop to get help with it (not in time to send Christmas cards anyway). Thank you!
    Master:
  • 461 Answers
Remove the battery and try it on AC only. A failed battery can keep it from powering on.
Posted on Dec 15, 2008
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
My dell inspiron mini 10 won't boot.There is just a flash of white light then a flash of amber light when I press the power button. That's it, nothing else.
Remove the main battery and try again, also! the power adapter charger should be checked for correct voltage, if okay! pull one stick of ram and test, and the second piece not forgetting to put the first one back and power up, if all this fails you will need to get it assessed.
Mar 25, 2012 | Dell Inspiron Mini Netbooks
Laptop Battery Won T Charge on a laptop dell inspiron 1525
Battery could be dead and won't hold another charge. Batteries only last for so long until you have to replace them. If you laptop is ok with the AC Adapter & Power Cord meaning it boots and allows you to work in windows, then the battery is definitely dead.
Mar 19, 2012 | Dell Computers & Internet
My dell inspiron 8200 laptop wont turn on all that happens is the leds that show power, battery etc come on for 2-3 seconds with a short whirring sound then it stops. I have tried the usual fixes of taking...
Have you tired using the electric cable instead of the battery? I presume you have. Does sound like it could be down to the power management in that case.
Nov 03, 2017 | Dell Inspiron 8200 Notebook
My Dell Inspiron 8200 will not power
remove the battery and try again with ac adapter
Mar 19, 2010 | Dell Inspiron 8200 Latitude C840 Laptop...
Dell Inspiron 1501 will not boot with battery or adapter
Take the battery out and try with AC only, if no change, then you will likely need a motherboard replacement
Jun 04, 2009 | Dell Inspiron 1501 PC Notebook
My new itouch will not boot up. It just seems to be dead
Check the wall outlet where the Power Transformer is plugged in and verify that it has current by using a lamp or something like that. If ok, then...
Check the laptop battery for charge state. The indicater light should show full or good charge. If not, the battery could be dead....
If no current from the adapter, the battery goes dead in 2-3 hours of use.
Daniel Bonnici
Mar 27, 2009 | Dell Inspiron 1525 Notebook
Dell Inspiron 8200 Battery
I assume that you have your charger plugged in as long as you use the laptop...
There are very minimal chances o the battery having been damaged, since the casing on the inspiron 8200 is quite sturdy.. i suggest you get the charge socket (the socket that leads to the main wall electricity outlet) from a qualified technician...
Feb 26, 2009 | Dell Inspiron 8200 Latitude C840 Laptop...
My Dell Inspiron 8200 won't boot up. The battery is dead (the latch broke shortly after purchase), and the laptop is plugged in to the wall using the original power cord. There are three indicator lights...
Since it has sat dead for so long, it's certain the bios battery is drained. The bios battery is a small rechargable Nimh inside the laptop, and if you leave the laptop plugged in for a day or two it may come to life for you. I can't say for sure though if that battery will prevent the unit from booting at all or not, but I would try it.
Dec 15, 2008 | Dell Inspiron 8200 Notebook
Dell Inspiron 8200 Notebook Logo
289 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
