Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Truck wireing problem
I was wanting to know what color the revres light wire is on my 97 chevy k2500
  • 95 Answers
The wire should be a green or a light green. You can look for it behind the kick panel or the sill plate on the drivers side. it should be in with the wires running towards the back of the truck.
Posted on Feb 17, 2009
Melted red wire under dash does the wire connect to the blower motor or blower resistor 1996 chevy k2500
The blower motor has 2 wires the resistor connection has 5 or 6 wires .
It sounds like the blower motor wire .Dose the motor spin this is key if the resistor wire were all bad the blower motor would still spin .
Jun 02, 2016 | 1996 Chevrolet K2500
Rear tailights bulbs replaced still no running lights 97 Chevy k2500. Solutions?
Several possibilities. Have you checked to see if current is present at the bulb sockets? If not, trace the wires backwards to the next plug in connector and check for current there and so on. I assume you have checked fuses, but you may go all the way to the light switch which itself can fail. Good luck.
Feb 26, 2015 | Cars & Trucks
Hello, When I hook up my 2007 box trailer up to my 97 chevy k2500 hitch and plug in the 4 plug u-haul flat plug the brake fuse blows, but if the hitch is not hooked up but I plug in the plug all the l
check positive wires touching the negative(ground). by getting each positive wire from the plug to check continuity to the ground.
and check or clean the plug. it may has excess wire touches to the other wire.
Aug 15, 2012 | 2000 Chevrolet Blazer
Have a kenwood stero ,putting it in a 97 chevy lumia,i need the color codes for the wireing horness.
1997 Chevrolet Lumina Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Orange
Radio Ignition Switched 12V+ Wire: Yellow
Radio Ground Wire: Black/White
Radio Illumination Wire: Gray/Black
Radio Dimmer Wire: Brown/White
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
Dec 30, 2011 | Car Audio & Video
Need order of spark plug wires
Below is a diagram which shows the wire numbers and their corresponding position. Best of luck!
1999 Chevy Suburban K2500 7.4L
Nov 10, 2011 | 1999 Chevrolet Suburban
I need to know how to wire my lights to my truck bed what color goes to what it is a 1993 chevy k2500
will this do? If not, please let me know what else you need.
turn signals/brakes are yellow, parking lights/marker lights/license plate light, are brown, ground is black. Backup lights are Lt green.
Oct 01, 2010 | 1993 Chevrolet K2500
I'm installing a gps tracking unit on one of our landscape trucks. It's a 97 gmc/chevy 2500. I need to connect it to the ignition(12v dc) and constant power (12v dc)
your looking for an orange wire for your ignition and a yellow wire for constant power i believe. it's easiest to find them behind your deck/cd changer. just cut the wires and slice into them before the connection point of your deck wiring harness
May 13, 2010 | 1997 GMC Sierra K2500
90 chevy k2500 5.7 intermittent backfire into
It may be a sticky lifter if intermitent
did you check all cdes?
the map sensor can do this as well
Feb 27, 2010 | 1990 Chevrolet K2500
My 1998 chevy 4x4 brake lights work fine with the key off but when you turn the ignition on the brake lights go off
i had the same problem with a 94 chevy truck i know they are different years but chevys are funny vehicles try running a ground wire from your fire wall to your winshield wiper motor, just pull the wiper motor off of the fire wall and put the wire in place behind the motor and you should be good like i said it is worth a shot the same exact thing happened to my 94 and after painstaking hours of following and checking every wire a buddy suggested i try this because they have ground problems and somehow are connected with each other no idea but it worked for me... thanks sam barnett lol
i hope this helps
david g
Jan 16, 2010 | 1998 Chevrolet K2500
97 color scheme for aux hok up
I could go outside and pop my dash apart real quick and tell you.Its real easy to take it off and pull the cd player and radio right out.Is your wiring harness missing or something?Is that why you need to know what it looks like?
Nov 23, 2008 | 1997 Chevrolet K1500
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
100 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
