Question about Maytag PAV2300 Top Load Washer
Washer not filling
I did several loads of laundry yesterday but will not fill today or run.
  • yamamanot Dec 15, 2008
    Thanks Huum, I did try that and it doesn't work. Hot nor cold will work. I did make sure that the hoses or the filter wasn't clogged. The light comes on to show it has power but no sound or anything. I was wondering if I could fill it from the hose by placing it in the tub to see if it would work that way? Or could it be the timer on the not working?
  • 750 Answers
Hello yamamanot
Welcome to Fixya
My name is Huum,
You said, You did several loads of laundry yesterday but will not fill today or run.
Here are a common thing that cause this problem.
Washer will not fill!
Faulty Water Inlet Valve
The water inlet valve is the device that meters water from the supply lines into your wash tub. On domestic washers, there are two lines, one hot the other cold. These valves are susceptible to mineral build-up and sediment deposits. There are two common failure modes:
Failure Mode One: Valve will not open.
If you can verify that the solenoid on the valve body is receiving the requisite voltage and the valve will not open, then it is faulty. Since the solenoids operate independently, it is likely that one side of the valve will work and the other will not. This can produce strand results such as a very hot wash when warm is selected (due to no cold water). Or the reverse in that the wash water is cold when warm is selected. If mineral or hard water deposits are a problem, you may witness a substantial increase in the time required for the tub to fill. This is caused be a decrease in the flow ware of the valve.
Failure Mode Two: Valve opens but will not close.
This is verified by a valve that allows water to flow into the tub even though no power is being supplied to the solenoid. This one is usually quickly diagnosed when the machine begins to overflow and the power plug for the washer is disconnected from the wall. However, this will not stop the water from flowing into the machine. The water must be shut off at the wall. As with the previous failure mode, the variant of this failure mode is that it may take the valve a while to completely bridge the flow of water after the power has been removed from the solenoid.
How to Diagnose?
There are a couple of ways to diagnose a faulty valve. However, there is a simple test that one can perform that will usually let you know if the water inlet valve is faulty.
Scenario:
When set to cold wash and rinse, the unit will not fill. When set to warm wash and cold rinse the washer will fill with hot water only and will fail to rinse. This is a common scenario where the cold water side of the valve does not appear to be contributing to the fill, but the hot water side does. This symptom could be easily reversed where cold water is being supplied, but never hot water.
So, how can the problem be determined? It is as simple as switching the wire harness plugs on the hot and cold side. In the example above where the cold water is never being supplied, the symptoms would be the opposite when the wiring harnesses were switched. So the machine would produce only produce cold when warm or hot is selected. No water should be present when you select cold. This verifies that the timer, wiring and switches are all in working order. Assuming this tests checks out, you simply need to replace the water inlet valve.
Thank You For trusting us with your guestion
Please remember to leave a rating before you leave!
Posted on Dec 15, 2008
  • Neil Golan
    Neil Golan Dec 15, 2008
    You need water pressure to fill it!
    You need someone to check the water valve.
    Did you check the solenoid on the valve body is receiving the
    requisite voltage ?
Whirlpool front load washer w/bulk dispenser - over several wash cycles, the dispenser slowly fills with water and dilutes the detergent.
http://producthelp.whirlpool.com/Laundry/Washers/Washer_Cleaning_and_Care/How_to_unclog_my_Front-load_Washer_Dispenser
Apr 22, 2017 | Whirlpool Washing Machines
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
Why would a washing machine fill to proper level and then stop. no action after filling.
Power was never the issue or it wouldn't have filled at all. Also the pressure switch that detects water level must be okay since it stopped filling at the proper level. That leaves the control board or a relay that the control board uses to start the drum motor.
Sep 16, 2014 | Washing Machines
I heard my Maytag Neptune shake hard today when a load of laundry was going. I assumed the spin cyle got got offline for a second. The washer seemed fine. Then I did another load of laundry. While it...
do NOT call the Blue guys from Sears,,,he told me it would cost more than $2000 to fix a machine that will wash but not spin or drain ( I could get it to do both by pushing certain buttons). It is now outside and I have a used $215 washer that is doing great.
Nov 07, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Machine filled with water but no nothing.
if you can hear the motor running but no agitation then your motor coupling has broken,,it is between the motor and tranny!
Mar 13, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Why does it take so long to run a load of laundry in my GE Profile front loading washer?
Check the water supply, if the water supply is restricted in some way it will take a long time to fill, the m/c may need to fill 4 or 5 times in a complete wash.
Nov 19, 2009 | GE Energy Star WCVH6260F Front Load Washer
I am trying to fill the washer to do a load of laundry but the water is coming out the back of the washer instead what should I do
Open the washer and make sure the tube is not sitting forward .If not then you will have to lift the top of washer up and cheak for leaking hose.Also when washer is filling look with flashlight behind it to see if there is a leak there.
May 20, 2009 | GE Profile WPRE6100G Top Load Washer
Washer will not fill to appropiate levels
If " Washer will not fill to appropiate levels " this has nothing to do with drain pump and control board is unlikely.
That sounds like a water level switch that is malfunctioning, or a badly connected control board, call back the technician and tell him to double check the job done on control board.
Jan 13, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washer stopped working
If after waiting for a while it still does not respond - most likely the motor is burnt - especially if those were all very heavy loads
Regards
Sep 17, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Maytag PAV2300 Top Load Washer Logo
151 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
