Question about Fantom Drives DVD±RW Dual Layer Burner
Can't burn cd's from itunes
My fantom drive FDDRWDF 15D is not recognized by itunes. I am running osx and downloaded the latest itunes updates. I use toast 6 titanium. Any suggestions?
  • 190 Answers
SOURCE: I have a computer running Windows 98 and it does
win 98 does not support 1TB drives, please use dvd's [or other preferred method] cos win 98 just cannot handle drives that big
Posted on Sep 19, 2009
0 characters
1 Points
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
Aug 30, 2011 | Fantom-Drives FDDRWU2P16D USB 2.0 Premier...
My Iomega CDRW64001 keeps ejecting my blank CDs. The external LED blinks for several minutes and then ejects the CD with or without a burn program open. It plays recorded CDs and I'm able to install...
Your best solution (since your USB devices and your network-adapter are not working) is to remove the disk-drive from the old computer, and temporarily connect it as a "slave" disk-drive in the new computer, and then copy all your files from "old" to "new".
Or, try a different brand of "blank" CD-R disks -- the "firmware" (software inside the CD-writer) may not be recognizing "newly-manufactured" media). Unless you can update the firmware (by downloading the latest firmware on another computer, and burning a CD-R disk, and then taking that disk to your computer), it's easiest to "move" the disk-drive to the new computer.
Jul 16, 2010 | Iomega (32885) CD-RW Burner
Hi: My computer is not recognizing my ts-h492a
Please go here and download the live update from Samsung. This software is designed to automatically update you to the latest firmware via the internet. To get this service, customers have to install the Firmware LiveUpdate program on their computers.
Please download the live update full version if you have not used this software before. See link.
Simply follow the instructions as given and your software will be updated to the latest version required to run your CD/DVD writer with your computer.
Hope this helps. If so please do leave a vote for the solution. Thanks.
Mar 01, 2010 | Samsung TS-H492A/RSWN CD-RW/DVD-ROM...
My cd-r/dvd-r rw, will not recognize blank discs. When it does recognize the disc, it burns at most two audio tracks and finalizes the cd. Then giving me an error message saying disk may be dirty or...
I suggest you try a better program. It is possible there is something wrong with your drive, but this sounds more like a silly software problem. If you are SURE you have a drive capable of burning, then try this free program. I have a blu ray player, it stopped working with most bluray discs. Found that I needed to update the firmware, but my Windows software couldn't burn an .iso disc. This software can do anything you need.
It is free and works beautifully. I was able to download the program, burn an .iso disc and update my bluray player in minutes.
Aug 29, 2009 | CD & DVD Burners
Cant burn cd - error 4450
So first off, you have a problem with your registry. This is a problem seeing as you are not an administrator and the only way to fix the registry is to be an admin. So if and/or when you are and administrator simply download the RegCure registry repair tool. also get a SpyWare scan as well and update all your system drivers. That should do the trick or just any old program off the internet that cleans out your registry really. If you want to edit the registry manually just hit start>run and type in regedit and mess with it there. unless you know what you're doing i wouldn't recommend messing with the registry though.
Jun 14, 2009 | HP (350208-001) CD-RW/DVD-ROM (Combo)...
Intermittent recognition of DVD burner
Jun 02, 2009 | ASUS (90-N801W1000) DVD-RAM/DVD-RW Burner
Toshiba ODD-DVD SD-R5272 not compatible with iTunes
go to My computer right click on cd drive properties - check digital cd playback recording - check enable cd recording on this drive driver - update or uninstall reboot your computer Good luck!
Dec 10, 2006 | Toshiba SD-R5272 DVD±RW Burner
Can not burn cd or dvd on on double layer burner
1. go to device manager / right click on cd drive / uninstall driver / reboot and windows will reinstall driver 2. go to My computer right click on cd drive properties - check digital cd playback recording - check ENABLE cd recording on this drive driver - update or uninstall reboot your computer 3. go to look for the EXACT model of your toshiba notebook a) download latest BIOS b) download the cd driver Goodluck!
Oct 03, 2006 | Toshiba (SD-R5372V) DVD RW Dual Layer...
Fantom Drives DVD±RW Dual Layer Burner Logo
64 people viewed this question
Top Fantom CD & DVD Burners Experts
Brian Sullivan
Brian Sullivan
Richard Roberts
Are you a Fantom CD and DVD Burner Expert? Answer questions, earn points and help others
