Question about Fahrenheat Electric Convector Baseboard Heater, 240 Volt
When my f2548 heater comes on the wall gets too hot touch
But the front of the heater is barely warm.
  • lensue3 Dec 17, 2008
    bought another heater still does the samething. shame my old one needed replaced
    Genius:
  • 1,199 Answers
This sounds like a short circut! Avoid useing untill it can be looked at!
Posted on Dec 15, 2008
2000s-10 4.3l temperature control how to make it push warm air when you select warm air only pushes cool air
First let your vehicle warm up to operating temp. At idle usually takes about 30 mins or take a drive for about 5 to 10 mins. With caution check your heater hoses. Should be 2 hoses going into your fire wall. Be careful cause they might be hot. Make sure both hoses are hot by gently touching the hoses. If not thermostat by be stuck open or closed. If they are hot to touch then could be your blend door not opening from your heater core. Now if one hoses is hot and one is cold your heater core could be plugged up. Hope this helps
Dec 31, 2015 | Cars & Trucks
00' yukon xl no heat in front but works fine in back
You might want to try back flushing the heater core.This is probably your problem.If you know where the heater hoses go into the back wall of the engine compartment then feel the hoses.They should both be hot to the touch with the engine at operating temperature.If one is hot and the other you can hold your hand on it all day.Then try flushing the heater core.If it warms up some or gets any better.Then this is your problem.Hope this helps.Good luck.
Feb 26, 2012 | 2010 GMC Yukon XL
Sides and front getting very hot seeming like the hot air stuck somewhere
They do tend to get warm but if it is excessively hot, the fan may not be working.
The samsung website offers questions and answers and offers good support.
As quoted from the site: -
It is normal for the exterior of your refrigerator to feel warm. There are heater pipes located throughout the refrigerator cabinet which periodically heat up to reduce condensation on the refrigerator's exterior walls. If your refrigerator is located in a damp, humid place, such as a garage or porch, this occurs more frequently.
However, if your exterior refrigerator walls are excessively hot, for example, too hot to touch comfortably, your refrigerator may have a problem and needs to be evaluated by a technician. To have your refrigerator evaluated by a technician, please click the "Create Online Service Request" button below to initiate a service request
Hope this was helpful
Aug 04, 2011 | Samsung RS2630SH Side by Side Refrigerator
My heat will not get hot
SOUNDS LIKE THE THRMOSTAT IS STUCK OPEN ID HAVE THAT CHECKED HOPE THIS HELPS
Nov 30, 2010 | 2000 Ford Expedition
2006 pontiac grand prix, heat only gets warm not hot
Have you checked the coolant level? If that checks out ok... With the engine fully warmed up touch the heater core hoses where they go into the fire wall (about the center of the firewall). They both should be pretty hot to the touch. You'll likely find one hot and one warm. If this is the case flushing the heater core will likely get your heat blowing out hot again.
Mar 07, 2010 | 2006 Pontiac Grand Prix
2005 dodge ram heater does not get hot, just barely warm. When I increase blower speed, it gets colder. Coolant level is full, air flow is good, used to get hot but not anymore. Any ideas where my problem...
First check your radiator cap to make sure theres no pressure escaping. The cooling system needs pressure to push the hot water to the heater core. You also need to look at your heater core itself. With the engine running touch the lines coming in to the heater core through the firewall. If they're both hot you may need to replace the core, if only one is hot you've got a blockage in the cooling system preventing the flow to the heater core.
Jan 06, 2010 | 2005 Dodge Ram 1500
My heater doesnt blow very hot what could be the problem? like its barely warm air, it heats up a little bit when im giving it gas.
Usually the thermostat is the problem.
You can also have a plugged heater core, plugged radiator, failing water pump or just low coolant will also affect this.
Dec 10, 2009 | 1993 Buick Century
Rinnai r70e warm not hot
This's been a cold year!
Is this an instantaneous water heater?
If it's outside or on an un-insulated wall in an unheated area this could very well be all that's wrong with it!
Is your heater well insulated?
Are your pipes well insulated?
Is it in a heated area?
If not I would insulated it real good and try moving it to an area that's heated!
Has this been helpful?
Jan 21, 2009 | Bosch 2400ES LP AquaStar 6.4 GPM Indoor...
92 Mustang Engine WIll Not Heat
Sounds like you have partialy blocked heater core,not enough flow to the heater or heater tap either not working or only partialy open.You may have to remove heater hose at the fire wall and flush with garden hose.Also check if heater hoses are clear and running freely by using the same garden hose If you put hose up removed heater hose you should get a strong run of water coming out of the heater radiator.
Oct 24, 2008 | 1992 Ford Mustang
Fahrenheat Electric Convector Baseboard Heater, 240 Volt Logo
81 people viewed this question
Top Fahrenheat Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
