FixYa.com
Tags:
Slider Kyocera SE47/ Portable Handsfree Kit Headset
My Headphone Plug is broke, How can i Replace it? (by 4 users)
By Putty - usenet poster
my Headphone Plug is broke, How can i Replace it?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by Guest, posted on Aug 11, 2008
I would like to buy some replacements for the
coby CV M29
and can't find them. Do you have any leads?
Comment by Guest, posted on Apr 19, 2008
connection is loose
Comment by KAPTOIIIKA, posted on Dec 29, 2007
I have Sony Ericsson HPR-20 handsfree (with radio) and I accidentally teared the wire away from the plug that is inserted to the phone.
So I found 6 different coloured wires in the handsfree wire (grren, red, white, blue, spiral-painted blue wire and non-insulated wire).
The problem is that there are only 5 contacts in the plug: MIC, SPK, VCC, GND and I can't read the last title - it's something like "B-".
It's clear that non-insulated wire is GND, but what about the other ones? What colour is MIC and what colour is SPK? Does anyone know it?
Best Solution
posted on Aug 08, 2005
Helpful (85)
Beresford
Beresford - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
A good set of headphones can last a lifetime, but it's unlikely that the plug at the end of the headphone cord will. If you can solder a wire, though, there's no reason you can't replace it. If you don't know how to solder, you can buy a replacement plug that uses screw-on terminals, although this will be less secure over the long run.
1. Use wire cutters/strippers to snip the old headphone plug off the cord. Purchase an exact replacement headphone plug at an electronics store.
2. Twist off the shell of the replacement plug and slide it and any insulating sleeve onto the headphone cord.
3. Using the wire cutters/strippers, remove 1 1/2 inches (4 cm) of the outer insulation from the headphone cord. You should find three wires: two insulated wires and one uninsulated wire, which is the ground.
4. Strip 1/2 inch (12 mm) of insulation from each of the insulated wires
5. Solder or screw the uninsulated ground wire to the plug terminal that is farthest from the plug tip
6. Solder the insulated wires to the other plug terminals. If you don't know which terminal on the plug is the right channel and which is the left, you can use a continuity tester (available at electronics or hardware stores) to find out, testing it first on the tip of the headphone jack, which is always the left channel.
7. Squeeze the plug clips together with a pair of pliers to secure the cord.
8. Slide the shell over the plug and screw the plug in place.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jul 13, 2008
Not Rated (0)
yeejzoo2191
Rating: 0%, 0 votes
microphone logitech is not working .
Solution #3
posted on Jun 19, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
When a headphone plug is broke, the first thing to do is help it to get a job. Once the paychecks start coming, it won't be broke any more.
Solution #4
posted on Mar 25, 2008
Not Rated (0)
donovan99
Rank:Master Master
Rating: 97%, 21 votes
What about the 6 different wires? That was the real problem!
I have a similar problem but with an Ipod to Tapedeck adapter - yeah those old school soundtape adapters. When I strip the cable I found 7 (SEVEN!!) different cables. 1 Solid Green, 1 Solid Red, 1 Solid Blue, 1 Non-Insulated, 1 Spiral Painted Green, 1 Spiral Painted Red, and 1 Spiral Painted Yellow - which looks a lot like the non-Insulated cable.
I already go another headphone jack and stripped it, but only found the traditional 4 cables - 1 Green, 1 Red and 2 non-Insulated (ground). I will first try to match the Solid Green and Red, and the single non Insulated and use Black tape to test the combination. If this combination does not work I will assume that the Spiral Painted cables are ground for each channel.
Hope this helps!
If you have any experience with these 7 cable issue please let me know.
Solution #5
posted on Jan 10, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
That was a very lame answer that didn't answer his question at all! We all NOW understand how to "put one together".
Solution #6
posted on Jan 19, 2006
Not Rated (0)
violet
Rank:Master Master
Rating: 70%, 20 votes
This Problem Also Relates To: Jensen JTH-940 Consumer Headset Motorola H500 Wireless Headset Motorola Bluetooth Hands Free Headset Wireless Headset Motorola S805 Wireless Headset Motorola HS500 Wireless Headset Midland AVPH1 Headset Motorola Logitech Mobile Bluetooth Over the Ear Headset for RAZR V3c Verizon Cell Phone (980228) Headset
Can you Help with these Headsets problems?
Headsets
cant use modile to pc internet
hello,SIR i m having MOTOROLA... Answer This...
Headsets
Nokia 5310 XpressMusic
my phone keeps turn on then off... Answer This...
Headsets
return
What is the process for... Answer This...
Headsets
microphone
there is no voice detected in... Answer This...
Repair Service
Find Headset Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
