Question about Fahrenheat LFP6152 Halogen Baseboard Heater
My 200 amp Siemens main electric box is heating
I recently changed the 100 amp breaker for the furnace because it what making a lot of noise and was very hot, and it made the main breaker 200 amp went off one morning last week. I changed the 100 amp breaker yesterday, put the furnace on and this morning the upper part of the main box was hot and ther was a smell coming fromm the box. I put the furnace back on oil, but during the day the lights were blinking a bit and the panel is still hot. Should i replace the main breaker 200 amp.
Thank you
Ray
  • 108 Answers
This is a dangerous situation! There is a short in the furnace. It is NOT a breaker problem! You need to check the current draw in the furnace circuit, This requires an Amprobe meter. If you don't have one, contact a technician at once! You have a fire hazard!
Ray
Posted on Dec 15, 2008
I have a 440v 50 amp and a 220v 30amp main breaker box outside my house. the 440 goez to the inside of the house and i have to unplug the 440 and plug in myown 440 plug i connected to another breaker box...
Some of these numbers don't make sense?
I have Never heard of 440v and 220v in a residential application, they are two different systems, 480 volt is typically 3 phase power, and 240v is typically single phase, more in likely you have a 200- 400 amp main service, and a 100- 200 amp secondary service for the welder, that can't be 110 @ 200 amps?
I would need more info, and pictures of actual nameplates of the equipment,
and then I could advise a safe NEC electrical code answer...
Mar 17, 2015 | Electrical Supplies
I have a new furnace and the breaker keeps tripping (20/30). It is a bryant westinghouse box. I think 200 amphes
1) You got a FIRE truck coming.
2) Wire is too small.
Problem is NOT circuit breaker.
3) Both 240Volt appliances on same breaker is a hazard, especially if space available in 200 amp service panel for more breakers.
4) Usually each 240V appliance has separate breaker.
5) Circuit breaker trips because of High heat on the wire.
If wire gets hot, it will start a fire inside the wall.
Electric code requires wire-size match breaker-size.
6) If you put larger amp breaker on same wire that is getting hot, then wire will get hotter.
Result: FIRE truck middle of night with folks jumping out window in glass-cut bare run across yard.
7) Each appliance has volts and watt rating on label.
EVERY appliance has label.
8) For example stove might be rated 8000 watts and 240Volt.
8000 watts divided by 240 volts = 33.3 amps
Stove would require 40 amp breaker and 8 gauge wire.
9) How to figure it out:
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/How-to-install-a-subpanel.html
10) Do same calculation for new furnace.
12000 watt furnace divided by 240 volts = 50 amps.
Use 60 amp breaker and 6 gauge wire.
11) Summary: fixya wants you to be safe, and buy stuff showing in the ads.
Use a bigger breaker ONLY when bigger wire is also installed.
Call furnace installer, the installer should know to check safe wiring before installing.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 04, 2012 | Bryant Westinghouse Bqc Quad Circuit...
Can I change a 100 amp main breaker with a 200 amp main breaker on a homeline box
NO! The main breaker in each box matches the components of that box. Although it might fit, you are looking at a major code violation and possible fire danger. Which if you wanted to sell it later, could give you problems even if it did work and you didn't get have a fire.
Each circuit breaker box it rated to an amperage level and the main breaker is sized for that rating. Find the box tag and check what it is rated at.
Jan 16, 2012 | Your One Source 100 Amp Main Lug Load...
Main breakers keeps blowing what is the reason i had the electrical company check there stuff up to the house said everything was ok no smaller breakers are blowing just the 200 main is it possible i did...
Add up all the amps from active breakers. Do they add up over 200? If not, then I suspect a bad main breaker. If they do, then you need a larger service box and or main breaker.
Sep 24, 2017 | Siemens 200 Amp Main Breaker 30 Spaces 40...
Lights get bright then dim over and over can hear buzz noise from box where the main is
Sounds like a loose connection or overloaded breaker, Please call a Electrician due to high voltage in box
Dec 20, 2010 | Siemens 200 Amp Main Breaker 30 Spaces 40...
Siemens Main Breaker 125 Amp gets warm and trips
sounds like a loose connection ,or possibly a weak main breaker.
Jul 14, 2009 | Siemens /ITE 100Amp 2-pole molded circuit...
I need to add an electric panel box!
Before you contemplate doing this I would check to see if the 200 amp wiring to your home can accommodate 300 amps. If not, I would not touch it. If it can then you can do it ever so carefully to make sure you do not light yourself up! I would kill your main 200 amp breaker and then tap into each existing branch a tap that will take at least 50 amps for each of the two legs on your new 100 amp breaker box. Good luck
Sep 22, 2017 | 2005 Peugeot 405
Fahrenheat LFP6152 Halogen Baseboard Heater Logo
261 people viewed this question
Top Fahrenheat Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
