Question about Sharp Televison & Video
Just bought a new Sharp LC32SB23U tv. THe picture is not good. It's shaky/bouncing even the picture from the TIVO. Horizontal lines flickering.
    Genius:
  • 1,199 Answers
Take it back this is in no way normal!
Posted on Dec 15, 2008
Two horizontal lines appeared near bottom of screen
You can spend $300 to $500 fixing this or just do the best thing most cost effective thing and replace the TV.
Aug 23, 2016 | Sharp Aquos Televison & Video
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
Luxor 40 914 tvb
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 13, 2014 | Televison & Video
Green and purple horizontal lines
You will most likely need what is called a scan converter/scaler. It will convert your source signal to the desired signal for you. You can find these online.
Nov 21, 2012 | Mitsubishi Televison & Video
My tv made a little noise and then the picture disappeared. The screen is black with a vertical line of picture approx 1/4 inch wide going up the middle of the screen. Is it fixable?
Generally this is not good news. Even in the event this TV is repaired, it will work very long. This TV has a horizontal problem. This is the most stressed area of any conventional TV. The Horizontal Output Transistor will need replace, the flyback transformer is bad, you have bad power supply with horizontal capacitors that are bad, and last, is a possible bad picture tube. This TV is not worth the effort or money to repair. Thanks for asking and show all hands of support!
May 20, 2011 | Sharp 32SC26B 32" TV
Its a zenith 27in the sound is good but the picture only shows a line across the screen
Make a fist with ur hand and bang on the tv bazel frame.The tv picture flickers back or bounces back to a normal picture.The tv have a vertical or a horizontal hold ics have coldsoldering joints and requiring resoldering.If u bang on the tv bazel frame picture don't flickers back or bounces back to a normal picture.The tv have a vertical or a horizontal hold ics are dead require changes those ics chips.If u don't have all the tools.Can't do a basic soldering work or able to changes those ics chips.Shop around for tv shops for estamate and repairing prices for repairing.
May 04, 2011 | Zenith C27A24T 27" TV
Vs 7070 no blueuntilwarm and has dark picture
Might be it is worth the buy a new TV,but it is not worth the money to fix it. It is a serious problem!
solutiondoct
Nov 10, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Intense white & coloured horizontal line on black background on startup
I wouldn't attempt as the capacitors on a tv store around 25000 volts this is more than enough to kill you and they keep there charge even when the tv is off. Either take it to a repair shop or put that money towards buying a new tv - Do not even attempt to open the tv. (It sounds like maybe a tube has gone or the electromagnet that makes the beam move vertically is gone.
Sep 03, 2008 | Televison & Video
Horizontal lines and screen bounce
These sets have capacitors that will go bad, but without a good ERS meater that tests these in curcuit you could be spending a lot of time doing nothing, But the most common is to find the 9 volt reg on the signal board and change all within a 2 inches of that regulator
Feb 07, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Picture bounce
I think that maybe your horizontal hold is messed up. If there is anyway you can change it with a button or dial or something on the TV that would do it but if there isn't one then there is nothing you can do but to take it to a repairman but it is really expensive. You'll probably spend more on fixing it than you for the TV itself.You're better of to get a new television.
Sep 03, 2006 | Panasonic CT-27G14 27" TV
Open Questions:
Did I install the t-con board wrong? I was having flickering on my sharp aquos and replaced the t-con board. Now I get no picture. After I thought the new t-con board (verified exact same part, ordered on tv parts today) was defective because I got no picture after installing it, I decided to swap back to the original t-con board. when I did that I still had no picture. Which made me think I installed it wrong. I undid the cables, reinstalled the ribbon and the menu appeared on the TV when turned back on. So that made me think something wasn't set right w/ the ribbons when I installed the new t-con board. So I swapped back to the new one, and after trying to make sure I set the ribbons correctly, I still have no picture. So then I went back to the old t-con board (because as I just verified, it was working after I re-installed it the 2nd time) and now I STILL have no picture. I swapped back and forth a couple more times and I can't get any picture to show up. So that makes me wonder did I possibly fry something (I was very careful, kept myself grounded, didn't get rough w/ the ribbons, etc) or is it something like the ribbons are just extremely sensitive and maybe they're still not set right (they're very hard to reach)? Any thoughts on how I could test the t-con boards to check if they're good and I didn't blow something? I saw a video that it's possible w/ a multimeter but I'm not sure where the fuses are on the board or which area to test. Thanks in advance.
Jan 15, 2019 | Sharp Televison & Video
Televison & Video Logo
50 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
