Question about Sta Rite Sta-Rite Max-E-Therm High Effiency - Propane Heater - 333,000 BTU
Lpg spa heater cuts out at 86 degrees....
Worked great up to 104* then started quitting at 94* now 86*
service heater light comes on, board indicates flue sensor error. installed new one, didn't help.
put in new board, didn't help. new thermostat, didn't help. new limit switches, didn't help. gas pressure okay at 12 column inches. in short, have swapped out every working part one by one, nothing helped. the heater repairman is stumped.
what am i missing?
  • ifixpools May 11, 2010
    Do you have an automated time system on the pool? Jandy, EasyTouch, etc.???
    If so, check the water temp on the panel inside when the pump is running. If it is not the same as a physical check of the water or the temp display on your heater, you have the solution.
    A sensor that is 10 degrees off will shot a pool heater off at 94 if it is set to 104. Most time management sensors fail early at about 8-10 degrees too high. Eventually they fail to about 130+ and the heater will not fire at all.
  • 4 Answers
Is this an indoor heater? Vent could be blocked.
Posted on Dec 04, 2009
Leisure Bay spa will not heat past 86 degrees. Element and sensors are new. Spa has excellent flow and correct voltage at terminals.
if the spa does not heat up to 104 degrees then the temp sensor is what you are going to need.
Are there error codes showing on the screen of the topside?
You will need to know the model number of the control box or the model number of the heater tube in order to get the proper sensor.
Rod
US Parts Center
888-521-6183
Feb 09, 2013 | Pool & Spa
My leisure bay spa will not heat past 86 degrees.
If your spa will not heat up to the 104 degrees or what temperature you set it at then you have a bad temp sensor.
RodUS Parts Center888-521-6183
I have an Aqualink system, spa set to 104, it will heat to 94 and stay there, temp sensor is working, took water sensor out of line, plugged line, assumed heater would just keep heating, it did heat a
The heater may be wired just fine. The aqualink uses its water temp sensor to call for heat based on what you've set the thermostat to on the aqualink. However, most heaters have built in thermostats that over-ride the aqualink. Those thermostats come factory defaulted not to go over 94. Check your heaters manual on how to adjust the thermostat on the heater. Your heater should have its thermostats set to 104 and the aqualink will control the actual temp of the water by calling for heat based on what you've set the thermostat on the aqualink for. Hope this helps.
Oct 16, 2012 | Jandy Aqualink Rs4 One Touch Control...
I have a Pentair Mastertemp 400. It worked fine for 3 years until the temp sensor went out and both (internal and external) were replaced about a year ago. It then worked fine for about another 7-8...
You might have a much bigger issue than the temp sensor. When the heater is running hold the "pool" or the "spa" button for 12 seconds. This will show the exhaust temp, if the temp is rising above 375 degrees with in 1-2 mins then your not getting the heat out of the heat exchanger.
One other thing to check would be an external by-pass. If you have an external by-pass make sure the by-pass is set correctly. Opened or closed to much can cause the problem your having.
Mar 04, 2017 | Pentair MasterTemp 400000 BTU Pool and Spa...
SPA WILL NOT HEAT PAST 94 DEGREES. i HAVE IT SET TO 103 AND IT HAS NOT MOVED PAST 94 DEGREES FOR OVER 1 HOUR EXACTLY WHAT BUTTONS SHOULD BE LIT ? IN OTHER WORDS IS THE AIR BLOWER LIGHT SUPPOSED TO BE...
if hook up to the firemans switch turn heater all the way to 104 degrees if using 4 pin connector for aqua link to heater set spa temp to 104 and make sure on aqualink spa heat is enabled and 104 degrees
Nov 30, 2010 | Jandy Aqualink Rs4 One Touch Control...
Heater reads spa water 15 degrees higher than it is
if a 3 wire system put pool at temp desired and spa at 104 if 2 wire to firemans switch run heater all the way up to 104 the system will control the temp
Feb 22, 2010 | Jandy AquaLink RS2/6 All Button Dual...
Pentair Heater shuts off prematurely when warming spa
check gas pressure could be running out or overheating
Mar 06, 2009 | Pentair MINIMAX NT TSI IGNITER
Pentair Mini-Max NT Pool Heater does not get very hot
The thermistor is a common failure on this heater. With a setting of 104 and the heater shutting off early, the sensor is bad. If you have a digital display, check the water temp with a thermometer and compare that ot the display. Odds are that they are different. The thermistor plugs into the back of the thermostat board and is a thin whire wire set or thibker yellow wire. The white wire sensors are old and most have fialed by now.
Dec 15, 2008 | Pentair MINIMAX NT TSI IGNITER
Sta Rite Sta-Rite Max-E-Therm High Effiency - Propane Heater - 333,000 BTU Logo
313 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
