Question about HP PSC 1510 All-In-One InkJet Printer
HP 1315xi all in one printer scanner copier config problem
If i open any hp program, photogallery, image zone, document viewer, I get a pop up that says: Please wait while windows configures 'hp program i open'. And then I get:
The feature you are trying to use is on a
cd-rom or other removable disk that is not available insert disk and press ok. If i push cancel i get
Error 1706 No valid source could be found for
for product 'hp program'. The windows installer cannnot continue. If i push ok it starts all over again.
If i push cancel over and over again eventually it will open and Ill have no problems with the program. Ive uninstalled and and installed everything and still i get the same thing. Any help will be appreciated.
    An expert whose answer gotĀ voted for 100 times.
  • 54 Answers
Remove the HP Smartweb printing software.
1. In the Start menu select All Programs > HP Smart Web Printing > Uninstall HP Smart Web Printing.
2. Follow the onscreen prompts.
You can also open the 'Control Panel' from the 'Start menu' and open 'Add or Remove' Programs. Select 'HP Smart Web Printing' in the 'Add or Remove' Programs window, and then click 'Remove'.
If the changes you make in the Page Setup dialog of Internet Explorer are not reflected in the Page Setup dialog of the Print Clips window and vice versa ?
This is a known problem, and not unique to HP Smart Web Printing. When printing from the Internet Explorer File menu, select File > Page Setup and make your settings there. When printing from the Print Clips window, click the Page Setup button and make your settings there.
Now install the smart web printing software from the weblink provided below:
After removing the smart web printing software, please visit the weblink and download the HP Smart Web Printing 4.05 software from the webpage.
Just copy and paste the entire link(without spaces) in the web browser and press enter.
For more information on how to install the software visit the below weblink which leads to a webpage.
After performing the steps mentioned above, check the functionality.
Posted on Sep 17, 2009
When i try to scan a photo my scanner says ''youneed to install or run hp software for this feature'' how do i do this?
Software included
HP Image Zone Photo & Imaging Software: HP Director, HP Photo Gallery, HP Image Editor, HP Instant Share, HP Photo Prints, HP Creative Projects, HP Quick 4 x 6 prints, HP Document Viewer, HP Send to Programs
The above software should be able to be run by inserting the cd-rom into your cd-rom or dvd-rom drive.
Once installed you'll be able to run the scanner.
Jul 09, 2010 | HP Officejet 7310 All-In-One Printer
How do i use my scanner
If you have loaded the software for the printer/scanner.
Go to your HP director Icon and start this program.
you should see your Scanner / printer listed under Select device.
You can place a document/picture in the document feeder on top.
OR you can place the document / picture directly on the glass.
(Lift the hinged lid to reveal the scanner glass)
Don't worry the document feeder uses a different scan wand.
Now document / picture in place select the Scan document or Scan picture icon from the HP director. Depending on which type of document you have placed in / on the scanner.
Scanner should warm up then scan presenting you with a preview image. From here you can decide what and where to go.
You are not limited to just the HP director.
Other applications can use the twain source to activate your scanner software. This will transfer the scan to your application.
Irfanview is a prime example. Image viewer that will let you "Acquire" and image from you scanner. Be sure to select the twain source.
Nov 10, 2009 | HP OfficeJet J4580 All-In-One Laser...
How do you use the scanner on the hp officejet 4315v all-in-one
With the HP all-in-ones, you have to scan from within a program, like Photoshop, HP Image Zone or the native "Paint" program. In Photoshop, go to the "Acquire" file command; in Image Zone, the scan option is at the bottom left of the task panel; in Paint, use the file command "From Scanner or Camera".
Hope this helps,
Oct 14, 2009 | HP Officejet 4315v All-In-One InkJet...
Scanner wont scan
Be sure that you have the latest scanner drivers from HP, for your system and OS. Often an easy workaround is to use Microsoft Office Suite document imaging.
The ms program can be found in the tools folder of the suite...Plus is that is almost always works on most any scanner, the minus side is that it creates only a .tif or a .mdi file. To read those, you need to set your DEFAULT program settings to call the Microsoft MSP viewer, typically located C:\Program Files\Common Files\Microsoft shared\MODI\11.0.
HP has been working on solutions to this issue. Further, HP has LIVE, free support available online, try connect to chat.
Sep 16, 2009 | HP DeskJet F4280 All In One Printer InkJet
1315xi all-in-one HP won't print documents from Word
Normal 0 Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 07, 2009 | HP PSC 1315 All-In-One InkJet Printer
Unable to scan
Make sure you have microsoft word installed i you computer.
But if you want to scan a document you can also scan it to HP Document Viewer.
First open solution center/HP Director and try to scan from document> then in the optin which says where do you want to send the scanned image> click on the drop down and check to see yu have the option of word> if yes select the option of word and try to scan.
If not Open HP Solution center/HP Director and go to settings> Scan settings> Scan to setup> Go to> Destination List> And click on Restore defaults and check to see if you have the option of word in the availabe list and front panel destination list> then click on apply ad ok and close all the windows and then try and check to see if you get the option of scan to word.
Sep 23, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Hp officejet 6213 all in one problem
Unistall HP software and install a new set of software
At this link
Jul 18, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP PSC 1510 All-In-One InkJet Printer Logo
113 people viewed this question
Ben Johnson
