Question about Krups FME2 Coffee Maker
How can I set the automatic timer on the Krups FME2 Coffemaker
Have no manual
ow do I set the automatic timer
Problem solved...
Found the manual for my coffemaker online
Posted on Dec 15, 2008
I have a Krups FME2 coffee machine and when I fill it up with water, the screen shows that the water reservoir is empty? What the heck?
If there is a water level float in the tank it may be no longer floating, if you can shove a piece of plastic under it to lift it up that should trigger it to think it now has water.
Apr 09, 2013 | Krups FME2 Coffee Maker
Krups FME2 Coffee Maker will not turn on
Please go to nearest service store.
Jan 22, 2012 | Krups FME2 Coffee Maker
How do you set time on coffee maker
Press and hold the prog button untill the display starts flashing, use the h/min button to set hours, then press the prog button again to switch to minitues, use h/min to set min then press prog again to confirm.
Nov 16, 2009 | Krups FME2 Coffee Maker
I need the Krups instruction manual for the 10 cup programable coffee maker
Go to krupsusa.com and click on "instructions". They have it there
Sep 15, 2009 | Krups FME2 Coffee Maker
SHUTS OFF AFTER 1 HOUR
Here ya go!
Setting Auto Off (units with timer only)
On models with a glass carafe, the auto off can be set to shut the coffee machine off from 1 - 5
hours after the brew cycle is complete. The factory setting is 2 hours. On models with a thermal
carafe, the coffee machine shuts off after 20 minutes.
Note : On models without a timer the coffee machine must be turned off manually. It
will not automatically shut off.
• Press the prog button (o), immediately followed by the h/min button (n).
• The display will show the time setting.
• Press the h/min button in steps to set the auto off time.
• Press the prog button to confirm the setting.
Dec 30, 2008 | Krups FME2 Coffee Maker
Krups FME2 Error Message
if you still have the receipt, you can get it repair or replace under the warranty, unless the warranty is for 90 days. in that case you are toast.
time for a new one.
replacing the parts is half the price of a new one.
Oct 20, 2008 | Krups FME2 Coffee Maker
I believe is need a new gasket for where the filter cup meets the espresso maker. I am not getting the same pressure when making coffee. It is a Krups 871 model
I have a #872 model. It is very similar to the #871.
Where the gasket is there is a small metal filter too, attached by a screw.
UNPLUG your coffemaker!!!
If you unscrew the filter and remove it with the gasket most likely you are going to find the other side of it clogged by coffee. Wash it off and wash the gasket well too with dishwashing soap. Rinse them off well.
You should try to clean off the coffemaker part to where the gasket lays. Usually it is full of burnt of coffee.
If there is no other problem with your coffemaker this should solve your problem.
Sep 28, 2008 | Krups Bravo Plus 872 Espresso Machine
FME2 Coffee Maker
From page 9 of the manual:
Setting and Adjusting the Clock
• The machine must be “off“.
• Press and hold the prog button (o) for 3 seconds: the hours will blink “88 _ _“.
• Adjust the hours in steps by pressing the h/min button (n).
• Press the prog button : the minutes will blink“ XX 88“.
• Adjust the minutes in steps by pressing the h/min button.
• Confirm the setting by pressing the prog button.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Manuals/ResultManuals.htm?SelectedService=Manuals&SelectedGuIDService={FA4AA2D9-9799-4F8F-8136-8FEB029407FD}&SelectedProdRef=FME2
Aug 28, 2008 | Krups FME2 Coffee Maker
Krups FME2 Coffee Maker Logo
391 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Ross Keen
Steve Allison
Steve Allison
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
