Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Lamp bunrt out on sony grand wega, kf42 we620
How do I remove it to put replacement in
Hi - I replaced the lamo in mine over two years ago, but I remember. You are going to remove the entire lower panel. It is about 4" tall, and runs across the entire set. Low right and low left, around the backside, you will locate 2 screws. Remove the screws and I think that whole panel comes off. From there (if I remember correctly) you will see what needs to be done about in the center of the TV towards the bottom. Bulb has maybe 4 screws, and I do not think they actually come all the way out. They are sort of "retained".
KC
Posted on Dec 23, 2008
How do i fix my sony grand wega tv kf60xbr800 with 6 blinking lights
Replace Projection Lamp/Bulb A1601-753A (XL-2000U) THIS ONE IS ON THE RIGHT FRONT COVER REMOVE THE COVER BY PULLING OUT THE LIGHT IS RIGHT THERE YOU NEED TO REMOVE 2 SCREWS Replacement Projection Lamp/Bulb A1601-753A (XL-2000U)
Nov 20, 2011 | Sony Grand WEGA KF60XBR800 60" Rear...
My Sony KF50WE610 50" Grand
You just need to replace the lamp, put the model number in a search engine and chose the best priced one for you
Jun 12, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
My sony grand wegas will not turn on no picture no sound .
Most possible cause would be broken/ dead lamp in your Sony grand wega tv. Check and replace lamp if it has not been replaced in last 2-3 years.
Do you see lamp red light on tv front or its power light is blinking? Let me know to provide you more info.
Thanks.
Jun 12, 2010 | Sony Grand WEGA KF50SX300 50" Television
Replacing lamp
Lamp replacement procedure is written in user manual,check page-17
Click Sony Support to download free copy of user manual of KDF-60WF655 if required.
There are two thumb screws at lower corners if you see tv from rear, remove these screws and take out lower front panel, in center of that space, you will see lamp cover, remove it and unscrew old lamp, pull it out and put new lamp then put things back in reveres order.
Required lamp of KDF-60WF655 is available in Sony Accessories Store for $200 under part number XL-2200
Hope these info will help you.
Thanks.
May 13, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
When I turn my Sony Grand Wega Kf-50XBR800 on,
This is symptom of weak lamp in TV, please replace lamp in TV and I would suggest to buy Sony original lamp for TV safety.
Lamp replacement procedure is written in user manual in details, click Sony Support if you want to download user manual copy.
Thanks.
Oct 18, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Replace bulb sony KF-60XBR800
When you are in front of tv grasp the right side of the front grill and pull it off, the lamp door is right behind it. Unscrew the cover and remove it, you will need the allen wrench provided with the new lamp to remove the old lamp just unscrew it and pull it out.
Sep 15, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Changing the lamp in a Sony Wega KDF46E2000
Click Sony Support to download instruction manual of KDF-46E2000that has lamp replacement info in detail.
Click Sony Support to download instruction manual of KDF-55WF655
that has detailed procedure of lamp replacement.
lamp replacement is very easy and mentioned in related instruction manual of TV. Please buy original Sony lamp from Sony Accessories Store and avoid aftermarket / cheap lamp.
May 02, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Projection lamp casing melted.
This will be covered covered under warranty by Sony. If you will call 800-282-2848 you can locate a Sony authorized servicer that should be able to repair this at n/c.
Feb 09, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony wega kf-42sx300u
I have highlighted the 2 areas where there are finger screws that need to be removed to access the lamp. It is a bit tricky the first time the cover is removed but, once done you will have access to the lamp door. This is the same as model KF-42WE610 sold here in the United States. If the lamp has never been replaced than that is the suspect. Anymore questions you can email me at tvtek(@)msn.com
Jun 12, 2008 | Sony Grand WEGA KF42WE610 42" Rear...
See owner / operator manual...if not available,can be downloaded
from our website....................T.
Feb 21, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
104 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
