Question about RIM BlackBerry 8700c Cellular Phone
Problem Pairing Blackberry 8700 w/ BlueAnt Z9 Bluetooth Headset
- Blackberry 8700 (not 8700c) with 4.2.1.96 System Software
- BlueAnt Z9 bluetooth headset
I followed the BlueAnt pairing procedure, to the letter, several times and the two devices will not pair up. "No new devices found."
Any ideas?
  • 1 more comment
  • jrobstewart Dec 15, 2008
    The problem was with the Z9 and the tip came from another FixYa user - thanks! From the power-off state you need to get Z9 into the pairing mode, in which the blue light *continuously* blinks fast. The instructions do not mention this. I forget exactly how I did it but pretty sure it was the timing of powering up the device and holding down both VOL buttons. I may try it again and send an update.
  • alexdamann Dec 31, 2008
    My Blackberry searches but cannot locate and pair with the Blue Ant. I suppose I will call customer care.
  • jars583 Jan 05, 2009
    Same issue with my 8700. I can pair my BlueAnt Z9i with my Curve, but it won't pair with the 8700. I get a "no devices found" message every time, and I've followed the pairing instructions exactly. Does anyone know how to solve this?
This problem has been solved by turning on the blue ant system then holding down the vol - and vol + buttons simultaneously for 5 secs.
Posted on Oct 27, 2009
I was recently given a blueant Z9 and I cannot get it to work with my blackberry. When I connect the device to charge my computer could not find the installation information also the USB cord provided with...
The socket on your bluetooth headset is for charging purposes only, through either one of your PC's USB ports (your PC won't recognize it as an e.g. pendrive), or the mains charger. It is not meant to be charged via your phone's port, whatsoever.
Anyway, your headset is able to pair with up to 3 devices (phones, computers, etc.). If it has already been paired to 3 devices, its memory is full. In this case, reset it, by pressing, at the same time, these 3 buttons: volume (+),. the volume (-) and the MFB, whilst in idle mode (i.e. not connected to another device). Then, it will automatically enter the pairing mode, denoted by its indicator light with a fast flashing. Otherwise, i.e. if its memory is still idle, starting with it turned off, press and hold the MFB for some 6 seconds, until the indicator light is steadily lit, and then, with a fast flashing. Either way, make your phone's bluetooth application search for new devices. After a little while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode. There could be an indication on your phone too that a headset is connected. The pairing process between any two bluetooth enabled devices should be performed just once. All subsequent connections between them should be achieved by bringing them both within each other's range, with their bluetooth radios turned on, of course. Otherwise, at most, a simple press on your headset's MFB should suffice.
Hope it works for you.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Anyway, please, let me know if you need further informations.
Regards, Carlos
Jul 07, 2011 | Blueant Z9 Wireless Headset
Clear memory on blue ant z9
  1. To reset your Z9i it must be switched on but not connected to any devices.
  2. You should already have deleted the pairing information from your phone, but if you have not, use your phone's Bluetooth menu to disconnect from the Z9i and delete the pairing information.
  3. Now reset the Z9i by holding down "Vol +" and "Vol -" and then clicking the BlueAnt button.
  4. The Z9i will refresh its memory, delete all current pairing information and automatically go into pairing mode.
Mar 02, 2011 | Blueant Z9i Bluetooth Headset
Blueant z9 fell in water , how to repair please
Go to this page, it will answer any question concerning the blueant .. including pairing to your phone .. activating your blueant etc http://www.blueant.com.au/index.phpalso gives you step by step instructions on codes, pairing etcthey also have a contact page so they may bbe able to help with repairs
Feb 20, 2010 | Blueant Z9i Bluetooth Headset
Can't pair Z9 with my blackberry 8120
Turn off your Z9
Turn the bluetooth feature ON on your 8120
Start the search for the bluetooth device
When the search starts, press and hold your ANT logo-button for about 6 seconds on your Z9.
First it will light up blue then starts flashing continuously.
Your phone should find it now with no problem!
Good Luck!
Sep 24, 2009 | Blueant Z9i Bluetooth Headset
My iPhone wont recognize my Z9 Bluetooth (blueant) headset
May 20, 2009 | Apple iPhone Smartphone
I cannot remember how to pair BlueAnt bluetooth to new devices
You will need to set the Z9 into pairing mode before your iPhone will find it.
The manual for the z9 is here
With the Z9 OFF, Press and Hold the MFB for about 6 seconds. The LED will appear a solid Blue, and then will start flashing. The Z9 is now in Pairing mode and ready to be found in searches by other Bluetooth devices. Pairing mode will be active for 2 minutes.
Enter Passkey "0000" when your phone prompts you. The phone and Z9 will now Pair.
Mar 10, 2009 | Blueant Z9 Wireless Headset
How do i get my Blueant z9i into pairing mode?
You put a Blueant Z9 into pairing mode by holding down the main (Blueant) button for 6 seconds until the light starts flashing repeatedly. On early models it will flash alternately red and blue.
Feb 26, 2009 | Blueant Z9i Bluetooth Headset
Pairing z9
Pairing Procedure
This is an example only and may differ from your phone, but the process will be the same.
Perform a Bluetooth device discovery on your mobile phone to add a new device.
Jan 29, 2009 | Blueant Z9 Wireless Headset
Good morning, my name is gayle and i am having a problem pairing my acer aspire5610z to my blueant z9 bluetooth. Any chance of some help for a littler ole grandma lady that's confused. LOL
r u installed blueant z9 bluetooth software , which opertaing system u r using , give me clarity then i can give u a perfect solution
Jan 25, 2009 | Computers & Internet
Pairing Problem with Cell Phone and Bluetooth earpiece
Not all bluetooth headsets are compatible. These are:
BlueAnt Wireless X3 micro Bluetooth Headset.
BlueAnt Wireless V12 LCD Bluetooth Headset.
BlueAnt Wireless Z9 Bluetooth Headset.
http://www.yourwirelesssource.com/buy/accessories/cat/28/model/1005_300368/accessory/291758?source=google_base
Mar 28, 2008 | Cell Phones
RIM BlackBerry 8700c Cellular Phone Logo
1,516 people viewed this question
Top RIM Cell Phones Experts
gggg
ismael castillo
George Etukudo
George Etukudo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
