Question about Epson Stylus C86 InkJet Printer
Printing double sided with epson stylus 1400
Could you tell me how to print an image on the front and back of the same piece of paper. I cannot find the option in the printing window box. they are pages in the same book.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 90 Answers
The printer does not automatically print on both sides.  You will have to print one side then reload the paper.
Posted on Dec 15, 2008
Epson 1400 will not use double sided paper
If your printer does not have a duplex unit then the printercannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn thepage upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for therest of the document.
I suggest you try a test page first, to get the printing the right way up onboth sides of the page so it reads correctly.
Mar 04, 2012 | Epson Stylus 1400 InkJet Photo Printer
Why does my epson 1400 keep loading paper straight threw instead of printing?
I have had this problem several times. The culprit is the feed wheel which can get covered with paper dust and it loses it "bite". Epson sells cleaning sheets that are tacky and when run through the printer remove this "dust". I have also resorted to taking a piece of scotch tape and carefully sticking it to the rubber take-up wheel and then gently removing it to pull the paper dust off with the sticky tape. Another problem can be because of not setting the paper type correctly. Check to make sure that the paper type set for the printer is the same as the paper you are feeding.
Nov 09, 2011 | Epson Stylus 1400 InkJet Photo Printer
My printer will not feed the paper no matter what thickness. I cleaned the heads and it still will not feed. HELP
i had the same problem every time i used double sided printing paper
i stopped using it no problem since
Dec 15, 2010 | Epson Stylus 1400 InkJet Photo Printer
Red paper and ink lights blinking
red paper light is blinked as it is indication that plz insert paper in your printer, and ink light blinks because your printer is low on ink, kindly get your printer cartage refilled.
Mar 19, 2010 | Epson Stylus 1400 InkJet Photo Printer
Printer cacelling job half way through
Try buying a new usb printer cable, just a thought - could have a dodgy connection.... Also - try a different pusb port on your computer.
Steve
www.yourhandinmine.co.uk
Apr 23, 2009 | Epson Stylus 1400 InkJet Photo Printer
Need to print banner type pictures
No, it is tells you it can print to 19", that is all it will do. I suspect buffering the image and feeding it to the print head is the problem. Make 3 x 16" and join them.
In the old days we used a dot matrix printer and continuous stationery, listing paper.
Jul 19, 2017 | Epson Stylus Photo 1400 Printer
Epson 1400 simply pulls blank paper through when I try to print
I've had the same problem. Drives ya nuts. Found that error said dvd/vcr release something or other on the epson print monitor. In any case, I found that if the front door isn't securely closed. (the front door you open to insert the dvd thingie, the paper will just feed or not feed at all. Once the door is closed on the front, the feed works fine again.
Smles,
Writenright@aol.com
Dec 14, 2008 | Epson Stylus 1400 InkJet Photo Printer
Print Heads snagging paper
well if u have a straight paper - it´s the printers fault
ask for a replacement from the place of purchase or from the manufacturer
Dec 24, 2007 | Epson Stylus 1400 InkJet Photo Printer
Epson Stylus C86 InkJet Printer Logo
1,223 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
