Question about Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum
Owners manual troubleshooting - belt slipped off - how do I replace it?
  • 1 more comment
  • Anonymous Dec 18, 2007
    HOW DO I REMOVE THE BOTTOM PLATE AND BRUSH IN A CANASTER VACUMN
  • Anonymous Sep 27, 2008
    there is a burning smell, can't remove the bottom plate to check the belt.
  • iamadolfan13 Dec 06, 2008
    have the same problem looking for a repair manual
    President:
  • 1,462 Answers
Remove bottom plate, remove brush roll. slip new belt over motor shaft then onto brush roll. refit brush roll and bottom plate. its just meccano
Posted on Mar 31, 2007
SOURCE:
Height adjustment slips out of low and medium to high carpet position
Owner's manual troubleshooting
no manual? try manuelslib.com
You may have the adjustment device loose look for a screw or bolt to tighten it but not so tight as to stop any movement.
Mar 17, 2015 | Vacuums
Very loud screeching ,continuous when turned on
Hi dfabin,
Does the screeching come from the motor area or the brush/belt area?
If it's from the motor. Turn it off. It needs repair.
If it's from the brush/belt area, most likely your belt is either slipping or rubbing on something.
Do you have an owner's manual?
If you do, and the noise come from the belts, take the belt(s) off and check them for wear, stretching, anything imbedded in them. Be sure to clean all debris out of the area. and reassemble. If still noisy, the belt may be slipping and needs to be replaced.
Here's a site where you can view the parts breakdown and order parts: http://www.vacpartswarehouse.com/Bissell-Healthy-Home-Models-5770-5990-6100-6405-s/600.htm
Hope this helps. If it does, I'd appreciate a vote. Thanks,
Handie Andie
Apr 03, 2011 | Bissell Healthy Home HEPA Bagless Upright...
How do you change the belt of the m5088520?
Hi There,
Here's step by step instructions for you on how to replace the belt on your Dirt Devil M088520 Featherlite.
Flip cleaner to expose nozzle base. Base should lay flat and face up. To remove nozzle guard, use Phillips
screwdriver to remove the two screws. Arrows (Diagram 1) show location of screws.
Lift nozzle guard off. Slide belt off motor shaft
(Diagram 2).
Lift and remove brushroll (Diagram 3). Dispose of old belt.
TO REPLACE BELT
1. Place belt on motor shaft, then slip brushroll through belt. Place belt in area of brushroll without bristles (Diagram 4).
2. With belt in place, pull and slide brushroll into nozzle (Diagram 3) making sure that the brushroll end caps are in the correct
orientation (Diagram 3a inset)
IMPORTANT: Rotate brushroll manually to make sure belt is not twisted.
3. Reattach nozzle guard. Secure by locating the 3 tabs in the base slots and replace the screws (Diagram 1).
I really hope that this was helpful to you. If you'd like to download the manual for your vacuum cleaner where I got this information, please see the link below where you may download. If you found this helpful, please be so kind and rate my repair helpful, or leave feedback for me. This is really appreciated by Fixya users.
Thanks so much.
Dirt Devil M088520 Featherlite Vacuum Cleaner
Owners Manual
Chris Jones
GoVacuum.com
May 07, 2010 | Dirt Devil M088520 Featherlite Bagged...
Brush doesn't work,red light is on says to see owners manual,belt is not broken.
The belt may have streached so that when pressure is applied to it the belt slips. The belt will not be broken just streached to far.
Mar 13, 2010 | Oreck XL Ultra Bagged Upright Vacuum
Belt is melting or burning not sure why
It doesn't matter what or why. Use your owners manual and it will show you how to change the belt. When you open it up whatever is hanging the brush roller up will either show itself or when you remove the brush roller it will fall out. Change the belt. That smell is the motor shaft slipping past the belt and burning it with friction. Either way the belt will need changing if it's had that much wear on it.
Mar 07, 2010 | Panasonic MC-V5481 Upright Vacuum
It smells like something is burning and then I saw smoke coming from the bottom, where the roller brush is.
That means that the belt is very worn and it is slipping on the motor. You need to replace the belt. Here is a link to the belts you need and a manual you can view with instructions:
Replacement Belts
Owner's Guide (3.4 KB download)
Dec 08, 2009 | Eureka Uno 2998AZ Bagless Upright Vacuum
When i vacuum it smells and so i turn it off. the
The belt is probably worn and slipping, that is why it smells. Here is a link to the owners manual which has instructions and a link to the belt you need.
Eureka Altima Owner's Guide
Eureka Altima Replacement Belts
Nov 17, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
How to replace belt
Below I have listed a link to the owners manual which has instructions on how to change your belt and a link for the belt you need. Hope it helps!
Owner's Guide
Replacement belt for Eureka 5841
Oct 30, 2009 | Eureka 5841 Upright Vacuum
I have to check the belt in the ereka powerline plus. how do I do that?
Below I have listed a link that will open the owners manual that has step by step instructions on how to change the belt. Also I have listed links for the replacement belt you need. Eureka recommends replacing your belt at least every 12 months.Hope this helps you.
Eureka Powerline LiteSpeed Owner's manual
Eureka Powerline LiteSpeed Replacement Belts
Oct 29, 2009 | Eureka Powerline LiteSpeed 5845 Upright...
New Eureka vacuum cleaner belt keeps slipping off
You may have a bad brush roll, part #61250-1, or the base itself has a problem and isn't letting the brush roll sit straight so it can be in alignment.
Jan 07, 2008 | Vacuums
Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum Logo
1,455 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Marvin
Marvin
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
