Question about E-Machines eMachines Desktop PC
Computer shuts off anytime
Have t3414 emachine Turns off and or reboots Does'nt matter where I am or what I 'm doing
  • 585 Answers
Your problem description tells me you may have a failing power supply. Or you may have problems on the motherboard in the form of failed capacitors. I would check the capacitors first. Bad capacitors can usually be found by simple visual inspection. A failed capacitor will appear to be swelled on the end as the exposed aluminum can will show a "domed" appearance instead of being flat, sometimes they will actually split. Look at each capacitor, especially in the area close to the processor/heatsink. If capacitors are the problem it won't be just one! they are replaceable by someone with the replacement parts, and sufficient soldering skills and tools. If the caps look good, I would suspect the power supply.
Posted on Dec 15, 2008
How to reboot
how to reboot a computer? well first you can do an emergency shut down by pressing and holding down the power button and after it's down you press the power button again.
Sep 16, 2012 | E-Machines eMachines Desktop PC
How to fix no boot device on emachines e442 for free
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Sep 09, 2012 | eMachines E442 E442-v133 15.6" Notebook...
Emachine t3414 restore to factory setting
Restart your computer now as soon as you hit the power button keep on holding Alt key & keep on tapping F10 key Alt+F10 it will open the recovery console select full factory restore and follow on screen instruction
(Note:this will erase all datas on the computer)
or you might try
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps you
Jan 27, 2012 | E-Machines eMachines Desktop PC
I cannot find vga, audio, & modem drivers for T3414. Where can I get them from
Access the manufacturer's web-site: http://www.eMachines.com
and click "support" and "download" for your specific model (T3414).
Oct 04, 2010 | E-Machines eMachines Desktop PC
Emachines w2828 keeps shutting down reboot/Screen Freeze
I dont thing this is a virus problem but a heat problem. if you dont mind getting inside the box see how clean it is and put your hand on the power box case .. then unplug all the hardware except the mother board then turn the unit on, if it goes on then plug 1 hardware at a time.
Sep 04, 2009 | E-Machines eMachines Desktop PC
E-machines monitor shuts down
go into the control panel and into the power options and make sure that the hard drive doesn't shut off and that the machine doesn't go into sleep mode and see how that goes.
Sep 03, 2009 | E-Machines eMachines Monitor E15T4
I think motherboard is shot
You may be able to start the system restore from the repair console if you have your operating system boot CD by following the steps here.
Hope this helps. Please remember to rate thsi information.
Thanks
Nov 16, 2008 | E-Machines eMachines Desktop PC
Emachine T3414 monitor
Turn off the computer and monitor. Disconnect the monitor. Turn on the monitor. You should get some indication the monitor is on, if not it is probably dead.
If the monitor seems to be on, try to enter the menu by using the buttons or knobs on the monitor. If the menu comes up, the monitor is probably good and you have a computer problem.
If you think the monitor is bad, hook it up to an operational computer. If it works, you definitely have a computer problem; if not the the monitor is definitely dead.
Either way try to have the problem resolved under the warranty.
Nov 01, 2008 | E-Machines eMachines Desktop PC
Where to get memory upgrade installed
open the side pannel then you will see the ram installed in slot, just put the ram module into the empty slot and gently push it, the latch in the side of the slot will close with a click sound
May 14, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
76 people viewed this question
Top E-Machines Computers & Internet Experts
Steve Allison
Steve Allison
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
