Question about Sony Grand WEGA KDP-65XBR2 65" Rear Projection Television
My Sony KDP65XBR2 rear projection tv has horizontal red lines
I have a Sony KDP65XBR2 rear projection tv. It has horizontal red lines across the entire screen. The picture has also started to oval or egg, the upper corners are starting to curve downward and the lower corners are curving upward. The picture also has borders of black and different colors on the sides of the picture screen. The picture seems to be shrinking. Also, the convergence no longer works. I was wondering if you could tell me how much will it cost (ballpark figure if possible) to get these things repaired. Or if its even worth repairing .
5 Suggested Answers
SOURCE: Faint red lines in a curved arch like pattern
To access the focus block with the screen controls, remove the 2 plugs under the speaker grille. There is a philips head screw under each plug. Remove both screws. the speaker grill is now free. Pull the bottom forward and the grille will come off. The top is just held by tabs behind the screen bezel. Be careful as there is wiring to the grille for video input 2 and the front panel controls. There is a piece of fiberboard held on by 4 screws in the center which was formerly covered by the grille. Remove the screws and the panel and the focus block is right there. Each color is labeled for both screen level and focus. Adjust the screen control of the color producing the lines until the lines just disappear.
Posted on Mar 31, 2008
SOURCE: KP-57WS500 57 in Sony Rear Projection
I had the same problem with my sony KP-57ws500 rear projection tv and thanks to the thread I fixed it in 10 minutes. At first I thought it was a white curved line but then after a closer look it was a very light green curved line. To solve this problem all you need is a flat and phillips screwdriver. Right below your speakers on the right and left side are tabs. Pull out the tabs and remove the screw on eachside. Once that is done remove the speaker cover. The two screws at the bottom are the only screws and you just have to wiggle the facing off by pulling out and down. You will see a fiber board cover in the middle of the tv, there will most likley be twist ties holding some wires, to make it easier to work remove the ties. Now remove the screws on the fiber board and pull it off.
You should see 6 adjustments screws. on the top for is focus, do not touch those.
Below the focus adjustments are the Red, Green, and Blue. The adjustment is slight so turn the correct color slowly and don't push hard on the screw. I had to turn the green to the left to get the lines to disappear and it was only about a 1/32 of a turn. Very very slight. Good Luck.
Posted on Feb 05, 2009
  • 4090 Answers
SOURCE: TV all the sudden started curving the picture
This is caused by either a flyback transformer or the IC chip that controls convergence and screen display.
This is not tuneable as a DIY from any external controls It has to be replaced and tested in situ to ensure correct alignment of the display. Don't be convinced that this is just a board swap or DIY project. So many think they will save money by swapping the board, but other elements in the circuit as yet not failed entirely have caused this to occur
Use a professional service to repair it properly otherwise the problems will continue after a time even with a replaced board.
Please rate the help++++ Thanks for using FIXYA
Posted on Oct 09, 2009
Testimonial: "Great help on the likely cause."
Ecollier2012
  • 3459 Answers
SOURCE: The picture looks like a 3D with the egges curving
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 17, 2011
Sony kp-ws500 has very fine red and blue horizontal lines across screen tried adjusting convergence, and it didn't do anything
Red and Blue Tube screen drive controls needs to be turned down some, tubes are over driving causeing drive lines.
Sep 16, 2010 | Sony KP-65WS500 65" Rear Projection...
RED SCREEN
hell yeah,
the biggest mistake I did with this tv.all tubes need to be replaced and it burns a hole in ur pocket.no guarantee on tubes,sony aware of the problem but didnot recall these defective sets.
good luck.
nanz
Oct 27, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony tv model no. KV - 19 APR 2
This is for a different model, but I had thin horizontal lines in red and had to adjust the tube for red. You may have a similar adjustment on your set.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Aug 01, 2008 | Sony KP-48V80 48" Rear Projection...
RED LIGHT
Does the light blink?
there is a
Sony Picture tube recall
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Feb 07, 2008 | Sony KP-46WT500 46" Rear Projection...
RED AND GREEN LINES HORIZONTALLY ACROSS TV
This sounds like you may have bad picture tubes. Most likely the green and red tubes. You would have to have them replaced and realigned. I would call a Sony ASC and get an estimate to verify this. An onsite service call could verify if this is what's causing your problem.
Jan 22, 2008 | Sony KP-51HW40 51" Rear Projection...
KP-57HW40 problem
Jan 13, 2008 | Sony KP-57HW40 57" Rear Projection...
LG Rear projection tv help... Red, Blue and Green horizntal line through screen.
The complaint may be dry solderig or yoke ,horizontal or vertical oscilator
Dec 29, 2007 | Televison & Video
The screen turns red after being on for about 30 minutes
or
Nov 10, 2007 | Sony KP-65WV700 65" Rear Projection HDTV
Sony Kp-65wv700 Too much red -- white looks redish
fix the red:
Nov 01, 2007 | Sony KP-65WV700 65" Rear Projection HDTV
Strong red tint with horizontal lines across screen
if you have warrenty, return it. if not, then buya new one...the video fuses are dying...hard to fix it.
Oct 06, 2007 | Akai PT4799HD Rear Projection Television
Open Questions:
Sony Grand WEGA KDP-65XBR2 65" Rear Projection Television Logo
132 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
