Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Whistling Noise A high pitched whistle has been going for the last hour after the oven was turned off, and we discontinued using the burners. Every function seems to be working. What is this?
    Master:
  • 416 Answers
Do you feel a rotten egg smell. It must be gas leak. Have your gas lines checked.
Good Luck
Posted on Dec 15, 2008
    Genius:
  • 1,199 Answers
This sounds like your control panel got some moisture in it! un plug from outlet overnight! Do not spray cleaners directly on control panel! somtimes its just from cooking steam
Sure hope this fixes ya up!
    Top Expert:
  • Kenmore Master
  • 83,054 Answers
This may be a high pressure gas leak, turn off the gas, if the noise goes away then u have a gas valve leak in the stove.
  • Marvin
    Marvin Dec 15, 2008
    the gas shut off is at the back of the stove.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 90 Answers
Is there a gas leak?  Sometimes natural gas lines get a white chalky substance buildup and make a whistling noise when the appliance is turned on.  Usually if you turn the flow of gas up it will go away.  I would immediately verify there are no leaks.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/larry_1fe25e09c54eece2
Is a high pitched whistling sound at idle a vacuum leak or what?
hissing vacuum leak at idle, louder with open throttle ...
? 1:43
https://www.youtube.com/watch?v=tFoybr865n4
Jun 27, 2010 - Uploaded by fenixus
hissing vacuum leak at idle, louder with open throttle ... i know that my camera is poor and microphone suppresses high pitch ...Hi, my kia picanto engine also sound hissing/humming duringidling with open throttle. ... Loud whistling noise 2000 jeep wrangler 4.0l - Duration: 4:01. by Nasrac72 16,158 views.Missing: vt750c
A Whistle or metal sound with firing... - Honda Shadow Forums ...
www.hondashadow.net > ... > Technical Discussion
Jul 11, 2008 - ... under load (accelerating), that there is a small whistle or even 'tap on metal' high pitch sound ... Pics of my 2008 Shadow Aero 750 (VT750C ... loose bolt vibrating
Feb 29, 2012
High pitch whine
Jul 21, 2009
More results from www.hondashadow.net
Dec 25, 2015 | Goes Motorcycles
Emits high pitched whistling after unit runs for 30 minutes
Sounds to me like the bearings are going bad in the motor. The hotter it gets the grease breaks down and the squealing starts.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 30, 2017 | Haier CPRB07XC7 Portable Air Conditioner
Whistling noise when cooling on Kenmore built in oven model #790.48783900
These types of ovens are complex to troubleshoot and repair. I would contact an appliance tech.
May 23, 2012 | Ovens
I get a high pitched whistle from my r94 rinnai. what causes this?
It's generally caused by either low gas pressure to the heater. Or what is called a "Cold Burner". If it is a :Cold Burner" ... Once the whistling starts, turn the heater off, wait 3 to 5 minutes and turn it back on and turn the flames to a middle setting. If there is no whistling, set your flame height/temperature where ever you like. The low gas pressure issue would need to checked by a qualified technician. At the same time, have them to check the air mixture control valve on the burner.
Hope this helps solve your problem. Please let me know.
Mar 15, 2011 | Heating & Cooling
Gas Oven Whistling noise
I HAVE A NEW PROPANE OVEN THAT I CONVERTED TO NATURAL GAS. NOW I GET A WHISTLE WHEN I USE THE OVEN ONLY. DO NOT GET A WHISTLE WHEN I USE THE TOP BURNERS.
Jun 23, 2010 | Maytag Ovens
Shower head is making high pitched whistling nois
The holes are probably clogged from hard water. Take the whole head assembly and dip it in a bucket of CLR for an hour or so. Then rinse off and give that a try. If your cheap, you can use a bucket of white vinegar and a little bit o water, but the smell is most disagreeable.
Feb 12, 2010 | Grohe 28444000 Chrome Movario Movario Five...
High pitched whistling
Try changing refresh frequency, color depth or resolution (wait for the whistle to appear before testing). Admittedly, you might have to give up some image quality - less colors, or less resolution. There is probably a problem in the TV syncing mechanism - if you can, try getting it replaced. "High pitched whistles" in video and TV hardware are usually harbingers of bad news.
Aug 24, 2009 | Samsung SyncMaster 245T 24 inch LCD...
My car is making a whisling sound when started.
hi ,,two things 1- water pump. but most likely check your pulleys they will make that high pitch noise one of them fixing to go bad and what will happen the belt will jam and jump lose and will lose all power ,,cause you have one belt for alt and the water pump mostly its the pulley right under the alt ,,hope this will help ....Joe
Aug 04, 2009 | 1996 BMW 318
High pitch whistling noise in engine compartment of 2005 envoy
There may be a small hole or cut in a vacum line or possibly just loose. Also make sure the air filter box and the big hose to it are secure and clamps etc are tight. Pulleys and belts can make a high pitch sound also.
Mar 22, 2009 | GMC Envoy XL Cars & Trucks
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
246 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
