Question about Toshiba 27AF43 27" TV
Problem with screen on TV
My daughter was playing with our remote and pushed something so that now while watching a DVD on Video 2 input the sound and everything comes through but the screen is black and white and goes up and down fast enough to where you can't see anything. Any one know how to easily fix the problem? Thanks.
  • 81 Answers
Does it roll on normal tv viewing? This is what we call a vertical fault. I don't believe it was because of what happened but U never know. The vertical IC or a faulty cap can also cause this problem. If it rolls on your regular tv programs then it is a fault in the vertical section of the TV
Posted on Apr 07, 2007
I have an audiosonic KM3608N DVD player and an LG TV. I have perfect sound when watching TV but seemed to have pressed something on either TV or DVD remote that has caused the DVD player to play at...
Please go to audio output menu on your DVD screen check them and when on the DVD channel check your audio input menu. You could have turned on the volume limit on your DVD settings menu
Nov 02, 2017 | Car Audio & Video
How do I access the AV1/2 channels to view my DVD player''s signal?
Normally there is an INPUT button on the remote control or on the front of the TV itself.
Just push that until it shows VIDEO 1 or something to that effect on the TV screen.
Power up your DVD player and make sure it is hooked up to the correct input connectors on your TV and then play a disk in it.
You should see the video displayed on the screen, and if not just push the INPUT selector button repeatedly until you get to the correct input mode for your DVD player.
Good luck.
Apr 21, 2011 | Televison & Video
Connected samsung ht x720 (home cinema system 2.1) to v+ box.Cant get picture when playing a DVD.Can hear the sound tough.Thanks
You probably need to change the incoming input signal on your tv.
In other words, your audio is coming directly out from your dvd player, and going directly to the audio power amp.
Your video does the same thing, except it goes to your tv. Your tv has multiple places for "incoming" signals to hook in to it. Take a look at where you're hooking your video in - the input should be marked ... something like "Component 1" "Component 2" "HDMI 1" "HDMI 2" ... something like that.
On your remove, there will be a button that says, "Input." When you push this, you will see that your TV brings up an input selection window. Pressing the "input" button on your remote should scroll through the ports on the tv. Briefly pause on each input selection to see if it begins receiving a video signal from your DVD player.
Nov 19, 2010 | Samsung Audio Players & Recorders
Cannot return to TV from DVD play
If you have a Directv receiver, and you have to be on channel 3 on the TV to watch it, then we have to get you off the video input. On a Directv remote, there should be a button toward the top left hand side that says "TV input." Try pressing this first. If that doesn't work, then look for the button on the Insignia TV remote control that says "tv/video," "source," "input," or something along those lines. Press it (some TV's make you press it several times to change the input). Just make sure that your Directv receiver is on before you start pushing buttons.
Give that a shot.
Jan 06, 2009 | Insignia 19 in. Widescreen Flat-Panel LCD...
Can't play dvd player on JVC tv; I don't have a JVC remote.
I hooked up a Pioneer DVD player to my TV and when I play a DVD the volume cannot be controlled by the TV. It just plays at one level and on the louder side. When I'm watching regular TV and the DVD player is on and playing a disc I start to hear the DVD soundtrack at the same time as the whatever I'm watching on TV. I should not be able to hear anything until I switch over to Video 1. Any suggestions?
Dec 31, 2008 | JVC AV-32F476 32 in. Television
Lost manual...I cannot get DVD or VCR to record
You need to decide which set of inputs or outputs you want to use. To record, and watch what you have recorded on your TV, you will need TWO sets of audio/visual patch cords. One for recording and the other for playing. Let's start with the recording. Look for the Line in or video in plugs on your DVD-VCR unit. Some recorders have separate inputs for the VCR and DVD. Others let you select with the remote. Usually Line 1 is at the back and Line 2 is on the front. Your remote will have "recording source" to let you select, or sometimes you can use the channel up and down arrows to select your input source. Your remote will also allow you to select either the DVD or VCR for recording. Connect the Yellow plug to the Video In socket, and the red and white plugs to audio in., Connect the other end of the cord to the TV or cable box. Yellow goes to Video Out, red and white go to audio out. Recording from the cable box is much easier because you wiull always have a signal going into the DVD-VCR recorder no matter what happens at the TV.  Now look for the Video out connection on the DVD-VCR recorder. Connect the Yellow plug to video out and the red and white plugs to audio out. Ignore the other connections at this point. They are for RGB component video. Your DVD -VCR should have one output for both functions. Use that one.
Now connect that cord to a Video one or Video 2 input on your TV.
Test the set-up. Play a DVD or a VHS tape and try to bring it in using the TV remote.
Then turn on a program and try to record it on  the DVD-VCR, then play it back.
This sounds very complicated, but all that's involved are two patch cords with three plugs on each end - 12 connections in all and color-coded. YELLOW is always video.
Dec 13, 2008 | Philips Magnavox DVD/VCR Dual Player
Direct tv hdbox & Plasma TV & DVD SSound system & DVD recorder
Need to make sure you have the red,white,and yellow rca connection cables ran from the samsung dvd player to the red,white,yellow input on the back of the dvd recorder. Once you do that make sure you put your dvd recorder on line 1 input. If you look closely on the back of your recorder it should say line 1 input. If your recorder isn't on that input you can put the recorder on line 1 input by using dvd recorder remote and pushing the input button. Make sure you don't push the tv input button the dvd recorder remote there should be a seperate input button or a way to toggle the inputs on the recorder. Once you verify all that turn on your tv and go to the input on your tv that you watch the dvd recorder on and you should see what your recording on the tv.
Nov 20, 2008 | RCA RTD155 System
Input problem
If you have the original remote, hit video, source, or input button, if it dont have them, then try to change the tv to channel 00 (zero or zerozero), if not then the channels might have to scroll to it, from channel 02 down to make it loop, if it goes to the next highest channel, then you need a remote. It may be set in the menu options to have the video source not saved to your list of saved channels. when you scan the channels, the tv might not look for the A/V source (audio / video), maybe just the RF source. The 3 DVD RCA wires are 1 video and 2 stereo, one stereo for left and one stereo for right. The TV has only 2 , 1 for video and 1 for mono 1 channel sound. This wouldnt have anything to do with why you cant use the DVD player. but try that with the original remote (or a universal remote that is set to your tv set that has either video, input, source or something similar. It is what tells the tv to change from the cable source (RF) and the AV source (the Red White and Yellow plugs, in your TV's case, 2 plugs, one yellow and the other either red or white or something). Dont really know how to explain it much more but hope it helps.
Jan 05, 2008 | Sanyo DS24205 24" TV
DS24205 TV INPUT PROBLEM
if you have a sky remote or know someone who does you could try programming it by using one of these codes, try them all one at a time
Sanyo 0159, 236, 073, 100, 064, 174, 185, 367, 039, 245, 246, 398, 241, 572, 583, 037, 132, 182, 244, 191
Dvd into vhs input
If you can watch TV normally then it should be a button on your VCR remote. It could be "Input", "Line" or "Aux". Tvs with more than one input line will may require 2 presses on that button, one for each line. This is the best answer that I can give not seeing your remote. Any questions?
Nov 07, 2007 | Hitachi VTFX685A VHS VCR
Toshiba 27AF43 27" TV Logo
69 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
