Question about Microsoft Windows XP Home Edition
Window\System32\Msconfig\System Missing or Corrupted
Started my comp. as useal got an error message that read >>> window\system32\msconfig\system file is corrupted or missing and tells me to use the boot disc CD to repair , so when i do it goes to the repair console screen and gives me (3) options,>>>repair,install,exit. So i use the (r) to repair>> than gives me an option of the only windows i have on my comep. so i type (1) and than nothing i let my comp. set ad see if it runs on its own or show me more options or something eles.....(NOTHING) so i reboot and go to the same screen and choose the reinstall XP option goes through a couple load up screens and gets to the (Searching for previous versions of windows)....................(NOTHING).i cant repair /reinstall or nothing no matter if in safe mode or anyother mode for that fact.. i beleave my only recourse will be to buy a new harddrive but i woul lose all my files and such and i really dont want too .... so any help or other tricks or options would be really gratefull.
  • 3 more comments
  • Kevin Oberst Mar 17, 2007
    Hi all- Ok i tried slution#2 it's a no go... when is used it as a slave comp.would not start at all.i even tried dif.settings on the good HD,still no go.have tried running win.XP again thinking i might have missed something but still no go.... begaining to think that i will have to buy a new HD.. hate this cause im on avery limited budget and the comment by Cupowar very thoughtfull but no go... getting very frustrated here...:)p but keeping my head up..thanks for the salutions and comments keep'em comping something my work.
  • Kevin Oberst Mar 18, 2007
    Ok,this is what i did....insert disc(restart comp.(hit any key)boot from disc>goes through load up.get to blue screen(reads) enter=continue r=repair f3=quite (press R) goes to repair screen(reads) type EXIT to quite the repair and restart the comp. a little lower it reads 1:C\WINDOWS (than) Which Windows do you wish to log in to (to cancel,press ENTER)...i then type 1 (only option)after that ....from what i have read it says DO NOT HIT ENTER so i just leave it and see what happens (started at 11:10AM)
    Ok,back again,now 12:05 no change nothing has happened it give me no other options. so cant do the other fix's you have said to do... so it is the hard drive or am i doing somthing wrong ??
    Oh,btw i did try useing my HD to another as a slave to another good HD...and the comp. refused to start....
    so maybe i do have a bad HD? of course it is 6yrs old...hehe
  • Anonymous Mar 26, 2014
    Is Picasa preventing this action?
    Scholar:
  • 116 Answers
I assume you have tried Last Know Good if you are able to get into Windows Advvanced Statup Menu (it sometimes works, because this is simply a corrupt registry file)
Your registry is corrupt, you may simply need to replace the one hive (file).
If after pressing 1 and then ENTER you do not get the recovery console prompt (which appears to be the case) then you will at very least need to reinstall windows. Below is an alternate way of backing up your data from a non-bootable drive (note requires any Vista DVD)
If you can borrow a Vista CD it is easy to boot to that and use Notepad to copy any data you want to save to an external drive or thumbdrive (if you have no harddrive to slave) (Boot to Vista DVD, select Repair My Computer, Command Prompt, type Notepad.exe, File, Open) When you see the folders in the left hand side, you can rightclick and send to external drive or thumbdrive). Once everything is backed up, you can reinstall windows.
If you do get to a prompt, but CHKDSK does not fix it see this article for how to restore you registry to a previous version fromn the recovery console.
Good luck,
Posted on Feb 09, 2009
Ok,this to let others know where im getting mad at...all the help/fix articals and ppl's tell me to put XPdisc into machine restart and get to the repair console.. i do all/everything. Ok now when i get to the options that i have i type the only otion i have and that is #1 ok. i type that in and nothing... i get no other promts/optionsi even download alitte program suggested from MS to that is suppose to start running after i type in the #1 promt. so i beleave my HD has had it....last time im asking>>>>>>>>Anyone have any other tricks or salutions to try. befor i go out and buy a new one ??
Posted on Mar 19, 2007
One thing...upon reading what you did regarding repair of system, i have noticed that you lack the right and final step to do... eventually, after typing the option (1)...the system would then give you the "c:\windows" prompt, or whatever prompt you will have...then after, you have to type in "chkdsk /f" then press enter, "f" stands for fix...or else if this doesnt solve the problem, then try "chkdsk /r" and wait for about 30 mins...meanwhile you should see the recovery processes going on...until it stop, it will then end up again with the "c:\" prompt...then type reboot.
Posted on Mar 18, 2007
Hi - i'm not much of an expert, but if you do buy another hard drive, then you may be able to use this one as a back up and still have your files intact. If it is the boot section that is faulty, when it is installed as a slave then that section is not needed for booting, and your files should still be accessible. Good luck! Cupowar@hotmail.co.uk
Posted on Mar 17, 2007
  • Matt Warcup Mar 17, 2007
    Gah! Forgot as well:
    If you can borrow a hard drive then get into the repair bit of the windows xp setup - change the drive designation to your damaged drive (when it's set up as the slave) then type FIXBOOT and then FIXMBR. Also use CHKDSK from this DOS type prompt to see if there is any physical damage or not. Definitely done now - Good luck again :D
  • 944 Answers
Best trick would be to buy a new hard drive, because that does sound like it is the problem. try and get exactly the same one and rig the old one after you have the pc set up - usually you can get your files - you were just unlucky that the file where the hd is damaged was a windows start up file or it's address. It sounds like you know what you are doing though, so I recommend taking the whole machine apart and cleaning it, then when you put it back together plug a different power lead into your hdd from the power pack. sometimes the hd problem could be a power issue, or a bad connection somewhere - swap the ide or ata cable from your hd for a new one if you can, and try the hdd on another pc if you can, ideally as a second device so that you can see if you can access any files, but also as a startup drive. If you need any help with this, and if it doesn't solve your problem, please post again with the details of your motherboard and hdd, or the whole machine if it was an off-the-shelf one. There could be bios issues, or known hardware problems that we could then try and identify for you. also go on another machine to the windows troubleshooter website and see if they have anything that makes any sense (sometimes they do) Hope this helps :)
  • Nigel Ridehalgh
    Nigel Ridehalgh Mar 17, 2007
    also if you have no luck, there are companies that specialise in recovery of data from damaged hdds, if you want more info, post again and i will hunt one down local to you hopefully
My acer one has no cd rom and has an error report windows could not start because the following file is missing or corrupt <window root>\system32\hal.dll please re-install copy of the above file
You need to repair your windows, with either using Recovery or get the external CD then reinstall operating system. Hal.dll usually still in your system32 folder but corrupted..
Aug 05, 2011 | Acer Aspire One PC Notebook
Tip
How To Fixed Corrupted or Missing \WINDOWS\SYSTEM32\CONFIG
If you get the error:
Windows could not start because the following files is missing or corrupt
\WINDOWS\SYSTEM32\CONFIG\SYSTEM or \WINDOWS\SYSTEM32\CONFIG\SOFTWARE
  1. Insert and boot from your WindowsXP CD.
  2. At the first R=Repair option, press the R key
  3. Press the number that corresponds to the correct location for the installation of Windows you want to repair.
    Typically this will be #1
  4. Enter in the administrator password when requested
  5. cd \windows\system32\config
  6. Depending on which section was corrupted:
    ren software software.bad or ren system system.bad
  7. Depending on which section was corrupted
    copy \windows\repair\system
    copy \windows\repair\software
  8. Take out the CD ROM and type exit
on Sep 20, 2010 | Computers & Internet
I'm having problem using msconfig. I encounter this message when I open msconfig.exe: Windows cannot find ''C:\Windows\System32\msconfig.exe' Make sure you typed the name correctly, and then try...
Have you tried using run? Usually windows will find it on its own since System32 is in environmental path.
To do this just hit Windows Button + R and type "msconfig" into the window that pops up.
Mar 11, 2011 | Microsoft Windows Vista Home Premium with...
Whenever i started windows it shows a warning message as can not find script file "c:\WINDOWS\system32\Rahul'sVirusprotection.vbe" how can i solve this problem? Is it a virus?
Follow below steps:
1. Click on Any folder.
2. Click Tools - Folder Options - View - Hidden Files & Folders
3. Mark Show hidden files and folders
4. Unmark Hide extensions of Known file types
5. Unmark Hide protected Operating system files (Recommended)
6. First two files were seen on my flash drive : Rahul'svirusprotection.vbe & autorun.inf
7. Click on the properties of both file and unmarked Read only.
8. Clicked Apply & deleted both files.
9. Searched for Rahul*.* on hard drives.
10. Click on the properties file and unmarked Read only deleted the file.
11. Now LORD RAHUL COOL is out of my browser.
Or try this:
If the error message is
"Cannot find script file C:\Windows\System32\Rahul'svirusprotection.vbe".
Create a new notepad document and open it, Don't type any thing in it, leave it empty and save it as "Rahul'svirusprotection.vbe".Then place this script file in "C:\Windows\System32\" and restart your PC, your error will be gone...
Oct 20, 2010 | Computers & Internet
I can't open windows xp i got this message:\r\n"unable to read file C:\windows\system32\config\software " I tried to fix it thru recovery console copying the i386 file but nothing happenned Help me please
hi You need to get a Windows XP from someone and follow these instructions: Windows could not start because the following files is missing or corrupt \WINDOWS\SYSTEM32\CONFIG\SYSTEM or \WINDOWS\SYSTEM32\CONFIG\SOFTWARE
1. Insert and boot from your Windows XP CD. 2. At the first R=Repair option, press the R key 3. Press the number that corresponds to the correct location for the installation of Windows you want to repair. Typically this will be #1 4. Enter in the administrator password when requested 5. cd \windows\system32\config 6. Depending on which section was corrupted: ren software software.bad or ren system system.bad 7. Depending on which section was corrupted copy \windows\repair\system copy \windows\repair\software 8. Take out the CD ROM and type exit
Aug 28, 2010 | Microsoft Windows XP Home Edition
Tosiba laptop could not start not even with safe mode.
The error message refer to system files it cannot load dur to either corrupted or missing files.
You can try to do a repair with your Windows CD install disk and if this does not work you will need to reinstall Windows again together with any drivers that Windows didn't install and your programs.
Note you will lose you data in this process, hoped you backed up your files.
Mar 03, 2009 | Toshiba Satellite A100-S8111TD Notebook
Start up msg
First
Open task manager and kill process wscript.exe.
Then
Delete VirusRemoval.vbs and Autorun.inf files from all usb drives.
Delete "c:\WINDOWS\system32\userinit.exe"
Then
Go to c:\Windows\System32 and delete the file VirusRemoval.vbs. It is super hidden so first go to Folder Options and check show hidden and check boxes. Also required for the above files.
Then
go to start>run and type regedit and enter
Go to HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
On the right side look for Shell which should have value of just explorer.exe.
delete anything at right side of explorer.exe if there is anything.
Under same key Winlogon also look for Userinit which should have value of
c:\WINDOWS\system32\userinit.exe,
Delete all the **** after the comma.
Then
Go to HKCU\Software\Microsoft\Internet Explorer\Main
On the right side locate Window Title and delete its value i.e. Sujin.com.np
Under the same key locate Start Page and delete its value i.e. http://sujin.com.np/
then go to Start Menu -> Run -> msconfig -> Startup tab -> uncheck .vbs files
Restart System
Jul 23, 2008 | Computers & Internet
Error messages
hm sounds like a virus. maybe your antivirus program deleted a virus recently?. try this.
click start->run-> write "msconfig" and the click startup.
search for C:\Windows\system32\Virus removal.vbs and uncheck.
restart the computer.
dont worry about the popup window that popup first time after restart check dont show this again.
second problem.
what dvd program are u using ? try a other one.
it can be that the dvd writer have errors:S
Jul 17, 2008 | Microsoft Computers & Internet
Aspire 5100 problem
You can disable this msg through msconfig or you can restore the os through system tools, if msg is again comming then try to edit the regestry & delete the entry(you can try all this).
Feb 13, 2008 | Acer Aspire 5100 Notebook
Message displayed at startup of pc
This is a trojan that has been removed, but the startup file is still in the registry, click start, run, then type msconfig, on the start up tab in the next window look for explorasi.exe and untick it.
restert the pc, select don't show aghain when the window pops up and it shouldnt show any longer
Oct 19, 2007 | Computers & Internet
Microsoft Windows XP Home Edition Logo
2,128 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
