Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Apparent green tube/bulb failure on RCA D52W20
My picture is ghosting and there seems to be a problem with the green.  When I attempt to set the convergence manually, I am offered red and blue convergence on the menu.  When I attempt to set these there is no green cross to overlap with the red or blue as it says to do in the instructions.  Any ideas?
Thanks!
  • 3 Answers
I THINK IT MIGHT BE YOR CONVERSION CHIPS IT COST AROUND 200 TO 250 DOLLARS TO GET IT DONE
Posted on Dec 20, 2008
JUST LOOKING FOR INSTRUCTIONS ON CHANGING THE LAMP.
the d52w20 rca model rca itc22 chasis is a 3 picture tube television.... it has no bulbs... do you mean to change a picture tube?
Feb 28, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I need to know what bulb to order for my RCA HDTV Model #D52W20. Do not know the model number for the bulbs for replacement. Can you help please?
that model doesnt have any replacable bulbs. there are no consumable bulbs or lamps for that model. what is the problem with the tv does it not turn on? that model was notorius for power supply failures where the tv would try to power on and get a green light on front and come on and off 3 times.
Jan 06, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Have a 52 in HDTV from RCA, if you urn it on the light comes on green then it cuts off in a few seconds, does this over and over. No sound or picture
sounds like your green tube is overloading. overdriving...this could be a number of things relating to high voltage driving the green tube. tube replacement in thes sets have become not cost effective. tube about 250 for the tube plus anothe 200 for labor. might be high voltage block or the crt driver board.
Oct 26, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
61" RCA DLP won't turn on after power blip
Hi, thank you for visit fix ya.
Do you havve problems with power supply capacitors.
Replace this:
2200uf 25V, 220uf 25V ( bowed or vented). Located beside power transformer.
Thank you
Jul 26, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
How do i replace the bulb on rca d52w20?
Your model doesnt have a lamp. your set has three picture tubes instead
Jul 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
**** tv
this is an indication of convergence failure. on this set first question i need to ask is IN you setup menu do you have the convergence option. if not this is an indication of a special fuse that has failed. if not it can be more.
Jul 26, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Ghosting in red ,blue & green
Sounds like an allinment problem with the color projection you can allin yourself via small screws on color tubes in rear. but be careful as tv needs to be on to do it.
Jul 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Red
replacement of a picture tube in a itc222 chasis is one of my least favorote things to do here at the shop. average cost for a tube is around 250... replaceing the tube takes some time and the set has to be completely disasmbled. then reassemble and adjusted. i believe union electronics offer these tubes. you have to get the tube type of the tube itself there are several tube +lens combinations that have to be considered. willie at fordtv.com
May 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 Blue Tube doesn't power on
From your description it does sound if the blue crt has failed. But it can be the crt board or a high voltage issue. intermittantly like that could be a connection problem. is there any hissing ..cracking or smells?
Dec 16, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Color Lamp
It is not as simple to replace as a bulb. This is a picture tube, and for a novice, no play it safe and have a tech have a look first. Just because the picture tube does not light up, does not mean the tube is bad. There could be several things in the solid state circuits that could cause this problem. Good Luck
Sep 30, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
220 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
