Question about GE WBSR3140DW Top Load Washer
GE WJSR2070B2WW clogged. How do I get to punp?
GE washer clogged and won't pump empty. How do I get to pump to clean?
  • davey84jones Dec 15, 2008
    Bingo. That was the ticket. Thank you so much. My clean clothes thank you too.
  • GE Master
  • 8,220 Answers
GGE WJSR2070B2WW clogged.  How do I get to punp? - 0386312.jpget the front panel off. use a putty knife and wrangle it. The electric pump will be right there on the bottom right. The pump comes apart easily. Just give it a twist. A bit of water mess. Get a washtub and put the pump in it before removing the hoses. Easy fix. The hardest part is getting the dang front panel off. :D
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 15, 2008
  • Dan Webster
    Dan Webster Dec 17, 2008
    Glad you could get it going. Makes my day!
GE washer (Model wcsr2080B4ww) will not drain or spin. The hose is clear and the "door switch" makes an audilbe click, so I assume it is still working
This is simply a problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum.
You need to locate and clean the filter. Depending on the model (not familiar which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom)
Jul 04, 2011 | Washing Machines
My front loading GE washer WSSH300 will not drain.
Don't know if this will help or not, but your owners manual is available at http://genet.geappliances.com/DocSearch/Dispatcher
Water won’t drain
Drain hose is kinked or •
Straighten drain hose and make sure washer is not improperly connected sitting on it. Top of drain outlet should be less than 8 ft. (2.5 m)
above floor. Household drain may • Check household plumbing. You may need to call be clogged a plumber. Plumbing this washer directly to a pipe is hard on the motor. Usually the drain hose elbow is inserted in a stand pipe, meaning the washer would drain water on the floor is the stand pipe is clogged.
Several items can cause the lack of draining.
If you can get to the drain hose, try lowering to a point that it will drain into a bucket. If it drains the system is not clogged. If you advance the timer and the washer drains this maybe the culprit. The motor can overheat and shut off. I would advance the timer to spin and listen for a hum in the motor and then quiet, a sign that the motor has overheated. If the water drains it sounds like the timer is at fault.
I would first make sure the drain hose is properly installed and not kinked somewhere. In earlier GE's the water drain pump could clog, your manual doesn't indicate that as a defect. Regardless timer, motor and pump are in the cycle to empty the washer water.
Jul 10, 2010 | GE WSXH208A Front Load Washer
I can't get the water to spin out of the cylinder. I think it is clogged with feathers from a down blanket I tried to wash. Is there a filter that I can clean out?
You can TRY to blow the clog backwards into the washing machine... by packing a "blow" canister vacuum cleaner or a shop vac on "blow". If the pump is clogged, the reverse pressure will force the clog into the washer... and then you can mix it with some water and try to let it go out in the normal way.
The machine must have the water turned off and the machine must be set to the "drain" setting. The pump will clog sometimes (rare) and I have used air pressure to clear them before.
Only other solution that I know if is to lay the empty washer on its face and access the pump from underneath... disconnect the exhaust hose and try to "fish" out the clog.... good luck
Jan 08, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Machine will not drain water or spin
hi..Most washing machine have a drain filter that can become
clogged over time.Front load washers typically have a small
removable panel about the size of a half sheet of paper on the
bottom front of the machine.the filter is inside.
check it out..
thank u..
kindly rate my response..
May 09, 2009 | Hotpoint Aquarius WF210 Front Load Washer
GE Profile washer will not drain. (DOES SPIN)
take the front off the washer take the two hoses off the pump youll probably find where its stopped up
Apr 24, 2009 | GE Profile WPRE6100G Top Load Washer
WJSR2070B2WW GE Washer will not spin
does it drain.and lock the door.. if it don't drain check you drain pump if it can't drain if will not spin...
if it will not lock the door it will not spin check the door lock..
if it locks and drains it is a motor control...
hope it helps
Aug 13, 2008 | Washing Machines
Fixing a clogged pump on GE Profile washer
waht u need to do is get a bucket now take the outlet hose and place it into it low to the ground if water comes out then it will be that your pump is faulty and needs replacing but if it doesnt the only way to do it is towels on the floor and with a low pan place this under the sump hose which should be in the middle of your drum which then leads to the pump pull slowly but not enough for the water to push the hose of do this until empty the only other way is to take it outside and pull the outlet hose of this is the quicker and dryiest out of them all but do do the first part to c if the pump is faulty m8
Dec 12, 2007 | GE WSM2480DWW Unitized Spacemaker Washer...
GE WBSR3140DW Top Load Washer Logo
500 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Gerry Harvey
Gerry Harvey
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
