Question about Compaq Keyboard
Sony Viao keyboard - certain keys got wet & no longer work
Tea splashed on Sony Vaio keyboard! Keys not working: enter/return; z; x; b; m; right shift and Pg Dn. Is this something I can fix or can it be fixed in a repair shop? Thanks for your help
  • jtchan83 Dec 21, 2008
    diet soda spill on one side of he keyboard resulted in keyboard not working. is this repairable?
  • Anonymous Apr 05, 2009
    How do you fix it? cost?
  • 20 Answers
Well the damage is pretty much already done however you may try dabbing your keyboard with alcohol you can use quite a substantial amount use Que tips to get in between the keys.
I suggest getting it fixed
Posted on Dec 15, 2008
Enter, backspace, delete, shift keys not working in sony vaio E series backlit keyboard with BIOS version R0170E5
At all? anything caught underneth them? Unsnapping keys is pretty easy once you get the hang of it. Give that a try. if it's still not working check your device manager to be sure.
Apr 18, 2013 | Computers & Internet
Tea fell on the keyboard the second line of keys
No, it most probably cannot, keyboards are very inexpensive these days. They are all membrane keypads, underneath, and once liquid, get in between the layers, it is almost impossible to remove. A new KB is in order.
Mar 26, 2010 | Sony VAIO VGP-WKB1 Keyboard
Sony vaio f403 keyboard keys don't work to navigate bios
if you have a chance to check those keys, to make sure they operate under other condition other than checking HDD!
Mar 07, 2010 | Computers & Internet
Stuck keys thanks to girlfriends Margarita.board still works but keys stick. Getting rid of her want to save the keyboard. How can I clean? new sony viao wireless keyboard for desktop.
Not sure if this is different to a std keyboard but in cases like this I'd
Turn keyboard over, remove retaining screws noting position and order and take out the plastic membrane, wash thoroughly with mild detergent and dry thoroughly. Remove keys in turn, clean with warm water dry and replace. Any other stickiness an be removed with isopropyl alcohol or similar and a q tip or lintless cloth , gently clean. reassemble.
Feb 11, 2010 | Sony VAIO VGC-LV180J 24-Inch All-in-One PC...
Keyboard error keys
you have number lock on your keyboard, just unlock it and your keyboard will work correctly it should be next to your f12 key
good luck!
Ruben
Jul 19, 2009 | Sony VAIO VGN-N320E Notebook
Hi my sony vaio vgn-sr13gn, shift key does not work at all. not even in Command promt. Both shift keys don't work. What can I do?
A friend of mine has the same problem and i stumbled on your question today. This problem occurred with the Vaio VGN-FZ11E, after very very modest usage, no scratches or damage visible whatsoever.
There's one option out there:
"I found that if you hold down both left and right shift key at the same time (did this for several seconds), it somehow solved the problem. Hopefully that fixed the issue. Also, go to control panel, click on accessibility options..in the keyboard tab, click on the settings buttons for sticky keys, filter keys and toggle keys and deselect the option to use shortcut..hopefully this will help you and other people that have had this problem."
Quoted from here
If that doesn't work, seems to me the remark of Benwabnick seems to be the solution, as posted below.
579a389.jpg benwabnick
Rank: Guru sony.gifSony Expert
Rating: 89%, 428 votes
the contact underneath the shift key itself is starting to go bad. Its a common issue with sony laptops, the keys can wear out pretty quickly. You'll have to get another keyboard.
BR
Jul 19, 2009 | Sony VAIO VGP-WKB1 Keyboard
Shift key problem
May 05, 2009 | Sony VAIO VGP-WKB1 Keyboard
Keyboard probs sony Vaio vgn-a215z
well 2 things u can do either get the mtherbrd disc from any of the local store second the way long t/s search for "how to map keyboard in xp" acc to ur keybrd specs ull be able to do tht i cant help more then tht cause i need to take remote access of ur compteru
May 22, 2008 | Sony VAIO VGN-FJ270/B Notebook
Certain keys won't function on keyboard
Could be that the connector from the keyboard to the mainboard is crooked. Try taking the keyboard off and wiggling the connector from the keyboard to the board so that it is a snugger fit.
Mar 16, 2006 | Sony VAIO M1 (VGCM1) PC Desktop
Compaq Keyboard Logo
1,118 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
