Question about Durabrand DWT2405 24" TV
Channel set how do i reset my auto channel memory settings
    Novelist:
    Champion:
  • 236 Answers
If you're on cable you need to make sure your set is in the "cable mode". After this you choose from the menu "auto program" or "auto search" and then hit the button on your remote or on the front panel and your set should go through all cahnnels and remember the ones that have a signal on them. Stargazer
Posted on Mar 17, 2007
Konka tv k1473pm
Do an auto-tune procedure. If not channels are stored with this process, make sure that the main system control memory IC to this set is faulty. Contact any service technician. Gopakumar Gopalan Google
Mar 02, 2014 | Televison & Video
How do you reset a Eaton Viking TV Channel is locked on number 2 want to change it to Channel 3 on mode number 5448-14CR
Try to direct enter channel three (03 enter) to get to that channel--if that works go into menu and find where to add the channel into the set memory.
Also can try in the customer menu to "Auto-program" which should restore ALL CHANNELS AVAILABLE to memory.
Mar 15, 2012 | Televison & Video
How to reset and tune sony bravia kdl-46X2000 television
You will have to go to the SET UP MENU and then select ALL RESET
Resets all settings to the factory settings and then displays the AUTO START UP screen.
Note, that all settings, include Digital Favourite list, country, language, auto tuned channels, etc. will be reset.
After this has been done you simply select AUTO SET-UP to select language and country/region, tune in all available digital and analogue channels and set the time.
This process will probably help you.
Jul 18, 2011 | Computers & Internet
Some channels have sound, others don't. Picture fine on all channels
Possible that the sound settings are in different modes on the TV. So check to set after selecting the channels to the required sound frequency of your service provider.
If not you will need to reset once again the memory and do a search scan IN the AUTO mode for resetting the TV channels.
Nov 01, 2010 | JVC AV-48P575 48" Rear Projection...
Factory reset was reset---now we have a no signal on the screen
Please go to tuning menu and select Auto Scan/ Auto Tuning to tune all available channels to store in tv memory.
Factory reset actually delete all data/ settings in memory chip and set tv as it was in-box.
Thanks.
Jun 13, 2010 | Olevia 237T 37 in. LCD TV
How to pre-set radio channels
After some playing!
Use 'Auto-Scan to find required channel
Select 'Memory' ; 'Memory shows on control panel
While 'Memory' still shows, press preset button for required channel number
Programme is set
Jun 20, 2009 | Venturer Audio Players & Recorders
Program channels
TV SETTING
1. Press the MENU button.
2. Use or button to select the TV setting menu, then press or button.
3. Use or button to select the Channel no. setting and use the or button
to change from AIR (over-the-air broadcasts) to CABLE (cable/satellite broadcasts).
4. Use or button to select the Tuning mode and use the or button.
5. Use or button to select the Auto tune and press or button to
confirm the selection. The unit will immediately search through all possible TV
channels and store those channels with signals in memory. After this is complete,
the unit will switch to the first channel found.
6. To exit the MAIN MENU and return to the normal screen, press the EXIT button.
Note : In DVD mode, this option is not available.
Remarks:
1. Channel no. : 2-69 channel for Air mode, 1-125 channel for Cable mode.
2. Tuning mode : Air or Cable mode are available.
3. Auto tune : Searches for usable stations and stores them in memory.
4. Skip : ON - Skip weak channels. OFF - No channel skip.
5. Fine tune : The frequency changes to allow fine tuning.
6. AFC : Auto frequency control.
7. MTS : Select the Mono sound/Stereo sound/Secondary Audio Program (SAP).
21
TV SETUP
MTS (Multi-channel Television Sound) SETTING
This feature allows reception of sound other than the main audio for the program.
3. Use or button to select MTS menu, and press or button to select the
options (Mono, Stereo, SAP)
4. To exit the MAIN MENU and return to the normal screen, press the EXIT button
on remote control.
Note:
• MTS only operates while in TV mode.
• The SAP (Secondary Audio Programs) feature allows a TV station to broadcast
other information, which could be audio in another language.
RESTORE SETTING
If you reset the TV to the factory settings, all your present settings on picture &
sound will be erased and replaced by the factory’s default settings. However, picture
setting in PC mode and parental setting will not be erased.
Jul 15, 2008 | TruTech PLV1615T 15 in. LCD Television
TV LOCKS TO ONE CHANNEL
Check menu for favorite channel setting......
activate auto-program for channel memory....
If that fails,try hard reset = unplug ac cord for a length of time,
plug in & try again..................T.
Sep 20, 2007 | RCA F36650 36" TV
Channel set
Apparently your TV is set to the "standard TV" position. Before you auto program your set, set it to the cable mode and then do the autoprogramming. In the standard TV setting, you just get off the air channels 2-13 vhf and 14-83 uhf.where as in the cable mode you get vhf channels 2-13 plus your cable channels. Stargazer
Mar 17, 2007 | Daewoo DTQ-13P2FC 13" TV
Durabrand DWT2405 24" TV Logo
77 people viewed this question
Top Durabrand Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
