Question about Toshiba Regza 32LV67U 32 in. LCD HDTV
DVD frozen in player and picture from DVD is on screen
We own a Toshiba Regza 32LV67U. We were watching a DVD when the picture started to flicker and jump around. It did this 2 or 3 times and then the picture froze. I can not remove the DVD or go back to the TV mode. Is it the player, the TV or the disc? What can I do? Please help.
  • janie_meyers Dec 18, 2008
    I tried the solution suggested by "fer_nan_14" without success. The disc did not come out of the player and the picture is still frozen on the screen. After turning on the TV I can change to the "antenna mode" to receive regular reception, but must do so evry time I turn on the set.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, it has been confirmed that the Toshiba Regza 32LV67U is not the issue. The DVD player must be unplugged from the mains for a considerable period of time to dissipate stored electrical power inside. It is preferable that all other connections (going to the TV) be likewise removed. If it were a systems glitch, then the unplugging of the DVD player should be enough to reset it back to factory defaults adn enable you to eject the disc. If it is not, then the DVD would require repair services. If the disc has to be removed immediately, then the DVD unit has to be opened up and the disc manually ejected.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 18, 2008
    Sergeant:
  • 306 Answers
Unplugged the power cord at the back of the TV and plug back in and magically it will eject once u turned the TV on!
  • 1 more comment
  • AbdulRahiman S Dec 18, 2008
    also try pushin in the front panel sumwhat hard see if u can get into unlock it self, tap on front or try slaming on front with sumthing if u can nock it back litte then it will reset itself if your lucky flat head screw driver try draging it all way open then push close again see if it resets
    this may not sound technical, but u can stuck the end of a paper clip into the opening until u could feel the dvd.....jiggle it a bit, and out it wil pop while pushing the eject button!
  • AbdulRahiman S Dec 21, 2008
    dont forget to rate it.. good luck!!
    Guru:
  • 449 Answers
Unplug the dvd player from the outlet for 10 seconds and plug it back, turn power on everything should work now. hope this help have a nice day.
  • 76 Answers
Turn off your tv then hold eject button then turn on the main power
Posted on Dec 15, 2008
Toshiba REGZA won't play DVD. Shows "disc loading" then goes to wide screen mode, but then ejects the disc. Whats up?
Sounds like the laser pickup unit to the DVD player is faulty. Contact any service technician to replace it. The disc mechanism should be taken out of it to replace this part.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 17, 2014 | Toshiba Regza 32LV67U 32 in. LCD HDTV
WHERE DO I GET A MANUAL FOR MY TOSHIBA REGZA 32LV67U TV/VCR COMBO
Toshiba has the manual for the 32LV67U at their support site. Go to http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Product%20Support and select Televisions > TV/DVD > 32LV67U in the three drop down menus. Then select the User's Guide tab. To print out the manual, click on the Printer Friendly version link.
The direct link to the 32LV67U support is http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2841881&rpn=undefined&modelFilter=32LV67U&selCategory=2797337&selFamily=2797340 .
I hope this helps.
Aug 06, 2011 | Toshiba Regza 32LV67U 32 in. LCD HDTV
The disc is stuck in my dvd player and won't eject..
Look for a small hole on the door of the DVD player. Get a paper clip, unbend it and slowly push it into the hole, apply some pressure and the door should pop open.
Mar 05, 2011 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Toshiba Regza 32LV67U DVD player won't play DVD. put dvd in, it makes 3 attempts to read then spits it out. Can I fix this or is this a take-it-in for service issue?
dvd player will only play movies for the COUNTRY in which you purchased it. There is no way to purchase a system or configure a system to play ALL MEDIA FOR ALL COUNTRIES. The country codes are specific and each country wants to prevent any other country from playing their dvds music, etc.
Jan 27, 2011 | Toshiba Regza 32LV67U 32 in. LCD HDTV
When i connect my dvd player to TV i only hear sound but no picture
hi there
your dvd player got three cable one red two white
three yellow ok here i go dvd player input plug in the yellow cable in the yellow in put @ the back of your dvd dvd player
the white cable and red cable is your sound the yellow cabe is your picture see that you have a yellow input @ the back of you tv and plug in the yellow in it then it will work
Dec 14, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Wife put another DVD in 32" Regza LCD with DVD, now 2 are stuck
Open it up. Once opened they are pretty easy to figure out.
Jun 28, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
I dont know how to turn my DVD movie on
You need to use INPUT function on your TV's remote to find the correct input for the DVD player.
Dec 31, 2008 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Toshiba Regza 32LV67U 32 in. LCD HDTV Logo
46 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
