Question about Samsung Blackjack SGH-I607 Smartphone
Phone freezes at boot up
Is there a solution for this smartphone stuck at ATT logo. Is there a hare reboot to reset?
A hard reset could fix the problem. Turn off the phone by removing the battery. Insert the battery and turn on the phone while pressing the up arrow of the scroll wheel. You will be prompted to reset the phone. This will erase all of your data (photos, videos etc). Select yes and hopefully the hard reset will default everything back to factory settings.
Posted on Jan 25, 2010
My Galaxy is stuck on Samsung logo. Why won't it switch on?
Samsung Galaxy Android Smartphone: Stuck on Samsung Logo (booting up)
Hello.. I'm assuming that you did not try to install a ROM or update the firmware in any way.. doing so and interrupting the process or if on a bad connection with WiFi, or downloading a corrupt install file can break your phone causing problems.
For whatever reason this happened try the following instructions:
  • pull your battery out
  • then re-insert after 30 seconds
  • boot into recovery mode (see attached video) [Press at same time: Power button, Volume up, and Home button.. when you see the blue words at top take finger off Power while still holding other buttons down until you get into Recovery Mode (you will see a bunch of lines of text.. if you see a little green robot says "installing system update" let it do it while taking fingers off all buttons.. it may say "error" = ignore this.. then you will see all the text]
  • wipe date, wipe cache, reboot [*be extra careful what you select: use your down volume key to scroll to wipe cache partition" use the power button to select this [you do not want to select "wipe data/factory reset" unless there is no other hope of getting back into your phone]
  • it takes less than a second to wipe the cache partition, then use the power key to select "reboot system now"
If the phone reboots fine you are done..
>> If the phone refuses to reboot, and hangs again at the Samsung Logo, then you know you have to go back into Recovery Mode and select "wipe data/factory reset" = after which you should be able to get back into your phone but it will wipe all of your data/everything clean from your phone. Your phone will be as if you just bought the phone with nothing of yours on it. You will have to setup your phone all over again.
Jan 30, 2016 | Samsung Cell Phones
It is stuck on the logo android is there anyway to make the tablet work again
Second one in three days. Seems a know issue.
  • Android tablet stuck on Android Logo Fix - YouTube www.youtube.com/watch?v=B_bJeLnlClE
    • BY RICARDO GARDENER
    • 9 MIN
    • 237K VIEWS
    • ADDED 2014-08-13
    Video embedded · Learn how to fix your tablet that is stuck on the Android logo or ... Learn how to fix your tablet that is stuck on the Android logo or Android start ...
  • How to fix an Android phone if it is stuck or frozen on ... www.smartmobilephonesolutions.com/content/android-stuck-on-samsung ... or it boots up to its Samsung logo then freezes, ... How to fix an Android phone if it is stuck or frozen on the Samsung logo
  • Stuck Android Logo - YouTube www.youtube.com/watch?v=w6tmETIerBM
    • BY KELLER KING
    • 5 MIN
    • 553K VIEWS
    • ADDED 2013-06-13
    Video embedded · This video will show you how to restore your Ekko Tablet T700 if it gets stuck on Android Logo. Este v?deo vai mostrar-lhe como restaurar o Ekko Tablet ...
  • Android Tablet Stuck at Boot Screen - Stack Exchange android.stackexchange.com/.../android-tablet-stuck-at-boot-screen Android Tablet Stuck at Boot Screen. ... Samsung Galaxy tab 3 made in Korea stuck at android logo. ... T98G tablet stuck on boot screen.
  • Dec 29, 2015 | Tablets & eReaders
    My daughters my tablet2 by bush has,frozen what do I do
    if you can remove the battery start there. is not try to hold the power button for 1min. if that still doesn't work follow the bellow instructions
    When Hard Reset is Necessary for Smartphones or Tablets ?
    1. Forgotten Pattern Lock on Android Tablets or Smartphones.
    2.Too many pattern attempts / Reset user lock.
    3. Tablets PC,Smartphones stuck on Gmail account.
    4. Android Tablet PC stuck / freeze on Android logo.
    5. Tablet Android or Smartphones hang on start-up / Multiple errors generating by OS.
    6. Android market having problems or generating errors.
    7.Upgrading to new Android version.
    Make sure to charge battery upto 60%.
    How to Hard Reset Argos CnM TouchPad Android tablet pc ?
    • Make sure the tablet is charged up to 60%
    • Turn off the tablet completely .
    • Press Volume + button , while holding Volume + button , plug in charger.
    • Release the volume + button.
    • Press Volume + again and press Power button to boot the CnM Tablet.
    • When Android logo appear , release the volume + button.
    • Press Power Button again and press volume + button , Recovery Menu will be appear .
    • Press the volume down and select "wipe data/factory reset"
    • Power button to select it
    • You will see "Yes - delete all user data"
    • Select "Yes"press "Power" button to select it
    • Formating will start. it will delete all user data .
    • Few seconds later, you should see the recovery menu again. Select reboot.
    • It will take approximately 2 to 3 minutes to take you back to its factory (out-of-the-box) state .
    you are done.
    This Hard Reset method will work with all models of CnM touchpad tablets.
    Jul 25, 2014 | Audio Players & Recorders
    As soon as i turn on my gps it starts to boot up
    I can help you reset and fix your Garmin Nuvi 265W.
    Getting stuck on the flashing Garmin logo, or a message about not finding any maps, or freezing and rebooting, are indications that the firmware / system software inside your GPS has been corrupted.
    There are three steps to take to get your Nuvi 265W running like new:
    1. Back up your Favorites.
    2. Perform a Hard Reset.
    3. Download and then run Garmin WebUpdater to replace its firmware / system software.
    I hope that helps.
    _____________________________
    Nuvi 265W Manuals here.
    Jan 24, 2010 | Garmin n?vi 265WT Car GPS Receiver
    Phone freezes when booting up when at windows logo stage...wat to do? phone has no antivirus, I have cleared storage for two times,taken out battery and tried to reboot but didnt work.
    hard reset the phone, try;
    If you cannot run program to hard reset form "Expert" folder. Turn off your phone, then press both *SOFT KEYS* and *POWER ON* device. After moment release both soft keys. On the black screen asking for confirmation press *GREEN PHONE BUTTON* and wait couple minutes for phone to initialize.
    Oct 21, 2009 | HTC S710 Smartphone
    IPhone stuck on Startup logo
    Reset the iPhone by holding the sleep/wake button at the top right of the device and the home button at the bottom center of the face at the same time. Hold them both until you see the screen go black and the white Apple logo appear. When this happens, you can let go - the iPhone is rebooting.
    Resetting the iPhone should not remove or delete any data or settings.
    Aug 08, 2009 | Apple iPhone Smartphone
    IPhone 2G hangs at "slide to unlock" - restore not helping
    2g solution
    3g solution
    if it still gives you problems then you have a hardware issue, apple won't touch a jailbroken iphone so hopfully you have the apple care protection. Restore it to factory settings and try to take it in for service.
    Feb 04, 2009 | Apple iPhone Smartphone
    I have an iphone that does this at times too! I have to reboot it periodicly, seems more often when I use it a lot. I have found several issues with winterboard and plugins for it to cause some of my problems. might try changing your screen to normal and see if it still acts this way.
    Dec 20, 2008 | Apple iPhone Smartphone
    Blackjack Frozen
    I ran into the same exact issue. Here is a simple fix:
    With the phone off, hold UP on the center D-pad and then power on. It tells you to press 1 to reformat and reboot, or press any other key to skip. Note that this process will erase all files (contacts, 3rd party applications, calendar entries, pictures, videos, etc.) and settings on your Blackjack and make it as fresh as the day you bought it. The hard reset fixed the problem in about 30 seconds.
    If you talk to ATT person, they will simply ask you to get a new phone. I had debated getting a new phone but finally searching on the web helped find another person who had the exact same issue and mentioned it. So I thought I would share with others. Good luck.
    Jul 07, 2008 | Samsung Blackjack SGH-I607 Smartphone
    Hard re-boot
    1) Power Off Phone
    2) Hold center (select) button
    3) Power On Phone while holding button down
    4) Master Reset menu should come up
    Mar 17, 2008 | Motorola Mobility Q9m Smartphone
    Samsung Blackjack SGH-I607 Smartphone Logo
    193 people viewed this question
    Top Samsung Computers & Internet Experts
    asber
    270rexton
    270rexton
    Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
