Question about Rex RX-518
REX blindstitch hemming machine motor quite hot. Locking stitch
I recieved my Rex blind stitch hemming machine and just set it up today, the machine did not run..there is no support number in the book... when I ran the machine I heard the motor running but it did not turn the gears to work the machine. Anyway since there is no support number for this machine and after contacting overstock.com who did not have any support info, i decided to try and trouble shoot. At first I thought it was an oiling issue so I put the oil to the machine and pressed the presser foot along with turning the handle manually in hopes to prime the gears... it caight a little but would not run smoothly. Anyway I decided to take the side cover off the machine to find that the motor which is located on the baxk was loose hence the belt was loose hence would not work the machine, the motor itself was working fine.... I tightened the motor up and the machine works wonderfully. The motor feels hot, so i am wondering if this is normal or is it becaue i was trying to make it work that is hot?? I want to know if i should go ahead and return it, hopefully I can get away with that but if anyone feels that the motor should not be hot while running please ket me know.. it is quite hot... I will see tomorrow if it is the same now that the machine is working propley. In the manual it says something about filling a resevoir with oil, but then it only shows six holes to prime with oil.. is there a resevoir for this machine? Th last isssue is how to lock the stitch, i have gone by the instructions but the stitch does not lock and then it can unravel?? Thank you for any help with tis machine, it has great reviews so I am hoping it is plain sailing from now on. Also does anyone have any other support / troubleshooting for this machine?? Thanks Fiona
    Welcome Back:
    Visited the website for 2 consecutive days.
I know this is a VERY late answer, but I hope it can help others. The direct wholesale importer for the REX RX518 blindstitch hemmer (and the same company who is possibly involved in its manufacture) is Artek Sewing Machine Supply in Brooklyn, NY (800-221-9440).
Artek seems to be the only company with whom to speak about this machine. They sell and "service" the RX518 (which may mean throwing them away and giving out another if they feel like it)! It is a company that does business as both "REX" and "Artek." This is not as good as dealing with Viking, Bernina, etc. for sure, but at least it's something!!
Posted on Aug 20, 2009
How to do blindstitch hem with a pfaff 1035. I have the blind stitch foot
You need to also have a blindstitch stitch on your machine. It looks something like this:
-------V--------V--------V-------
The straight stitch segment is stitched on the hem fabric, but the V portion zags over and catches a couple threads in the fold on the wrong side of the garment fabric.
Blind Hem Stitch with sewing machine Make It and Love It
Feb 22, 2017 | PfaFF Sewing Machines
Rex b/s 900-pb1 wondering how heavy of a fabric will this machine stitch, particularly cordura 1000d for hiking backpack
This will depend on using the proper needle and thread on this commercial machine.
Cheers,
Embroidery Services
San Diego, CA
Jun 14, 2016 | Rex Sewing Machines
How to adjust timing for Rex blindstitch hemmer
As long as your machine is not skipping stitches the timing should be fine. Three things to check: take your thread tension assembly apart so you can remove the discs and clean. Debris often gets between them and causes irregular tension. Next check the point of the looper to see if has a burr. If so take 600 sandpaper or crocus cloth and remove. Last-Check the upright pin that the looper passes--it too may have a burr.
Mar 24, 2015 | Rex RX-518
Need a downloadable instruction manual for Rex RX-518 blindstitch hemmer sewing machine please!!
No luck findong your but Go to www.reliablecorporation.com. Under products check out the MSK555 blindhem machine. It is the same as the Rex 518. To the right of the page is a category to download the manual. It is very helpful.
Good luck
Thanks
Apr 11, 2011 | Rex RX-518
How do you adjust timing on Rex commercial blind stitch?
I was just researching the same issue, only for my Lewis Blindstitch. I found a copy of the US Blindstitch maintenance manual on the mansew.com webstite. It looks like the setup is very similar to my machine, so maybe you can adapt the information to yours also. Good luck. Sorry, I was not able to post the hotlink, but this is it spelled out, exactly as it shows.
http://www.mansew.com/US BLIND/USBlindstitch_Maintenance.pdf
Apr 30, 2009 | Rex RX-518
Timing problem on Rex commercial blind stitch
retime your hook with relation to your needle the hook is slightly out of time causing it to "slip the loop" the hook should hold the loop until the needle retracts forming the chain
REX blind hem how to lock the stitch
When I purchased my blindstitch machine, I was also told to kind of snap the fabric as you pulled it our of the machine. Like you, I found that to be a little risky. Sometimes I'd just unravel what I'd sewn. I have found the most dependable thing to do is: Before removing the fabric from the machine, snip the thread between the fingers of the looper as it approaches the needle. If the loop is broken, the chain stitch will not pull out. If you cut the loop as it approaches the needle, you will get a bit longer tail so the needle doesn't come unthreaded on the next run. If you find you need a bit longer thread tail, you can pull a bit on that loop before cutting. As long as the needle has passed through the loop on the previous stitch, you'll be fine.
Dec 29, 2008 | Rex RX-518
REX blind stitch hemming machine motor quite hot. Locking the sti
When you tighten the belt it is a problem if it isn't adjusted right. You need to loosen the belt again. When you are pushing on the foot control the motor will begin to run. At the same time you can adjust the belt by carefully moving the motor. You will notice the motor speed will change as you do this. Stop adjusting the motor belt when you hear the motor speed at it's highest speed. Tighten down. Now, give it a try.
Feb 27, 2017 | Tacsew T500
HOW TO THREAD
Go to www.reliablecorporation.com. Under products check out the MSK555 blindhem machine. It is the same as the Rex 518. To the right of the page is a category to download the manual. It is very helpful. I have the Rex518 with the original instructional manual, but the translation into English was very poor. The MSK555 is published so you can understand the manual, and figure out how to use your machine. I too am a first time user of a blind hemming machine.
Good Luck.
May 29, 2008 | Rex RX-518
Rex RX-518 Logo
508 people viewed this question
Top Rex Sewing Machines Experts
Jim Goldsmith
Jim Goldsmith
deaususa
ray gallant
Are you a Rex Sewing Machine Expert? Answer questions, earn points and help others
