Model eied55hiwo
SOURCE: What is Electrolux Dryer Code
Error E63 in your Electrolux Dryer indicates that the temperature inside is too hot/overheating, to start with, check the vent and try to clean it. If still it's not resolved then the issue is with the thermal fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel.
SOURCE: electrolux dryer error code e63
I have ann E63 code on my Electrolux dryer. THe vent pipe was somewhat clogged but now is cleaned.What do I do?
SOURCE: Electrolux dryer has code of
The error code E63 is a high temperature warning
If you dryer is under warranty, take advantage of it. If not it may be a failing sensor or possibly a control board.
Good Luck and please accept the answer
Hello Curtis - Typically, error code E61 indicates a Heater Relay failure. At first the heater was grounded, and now possibly the heater relay. When the heater grounded it could have shorted the relay as well. Generally it is a good idea to have a professional take a look at it to get to the root cause. Cost of parts and technical expertise entailed in these types of replacements can be a bit tricky.
Hello - Typically 88:88 on an Electrolux dryer indicates a generic power failure code. Try resetting the unit by unplugging it or flipping the household breaker off. Wait approximately ten minutes.
